PassionFord
Go Back   PassionFord > Main area > General Car Related Discussion.
Register Forgot Password?
Sponsored by Cartown
Click Here
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 16-01-2010, 01:07 AM   #1
reisskahn
Trader Score: (0)
reisskahn is an unknown quantity at this point
Default '02 Focus Zetec Non-Starter Help
Long story short:
keys missplaced
new key cut but not coded
get into car
open the bonnet
find orginal key
Now car won't start all ignition lights turn on and the red (i presume) immobiliser light above the CD Player is just blinking
No turn or effort from the starter at all
Was told car runs and drives prior to the original key being lost
Any ideas?
thanks
reisskahn is offline   Reply With Quote
Old 16-01-2010, 01:53 AM   #2
CosworthGuy
3dr Cosworth owner
CosworthGuy's Avatar
Trader Score: (0)
CosworthGuy is on a distinguished road
take it to ford or a ford specialist for key reprogram. I just had it with a 406 i've had years. Pulled a fuse. Put it back. Light on but no start.
CosworthGuy is offline   Reply With Quote
Old 16-01-2010, 01:59 AM   #3
reisskahn
Trader Score: (0)
Thought it could be that but too tight to pay up's
Though i've read up because i've put the uncoded key into the Ignition and switched it on its erased all the codes from all the keys
Is that possible?
Old 16-01-2010, 08:08 AM   #4
DangerousBryan
Trader Score: (0)
DangerousBryan is an unknown quantity at this point
shouldn't have done really. what does the immobiliser light do when you put the key in the ignition? when you put the ignition on it should go solid and then go off. if it keeps flashing then its an immobiliser fault.
__________________
bryan
e36 m3 evo 4 door. 13.81@102 1/4 2.1sec 60ft
and a tranny diesel 76bhp
9.21 bridge to gantry. 14 laps
DangerousBryan is offline   Reply With Quote
Old 16-01-2010, 09:12 AM   #5
Glenn.
Glenn.'s Avatar
Trader Score: (1)
Glenn. is on a distinguished road
modern technology strikes again. I would of said the keys need coding. How many original keys have you got with the car. Is it just the one.
Glenn. is offline   Reply With Quote
Old 16-01-2010, 11:35 AM   #6
reisskahn
Trader Score: (0)
Immobiliser is flashing when ignition is on and when trying to start it
Only 1 Original key i believe... Looks like ill have to get it coded
Old 16-01-2010, 12:04 PM   #7
martysmartie
Trader Score: (1)
martysmartie will become famous soon enoughmartysmartie will become famous soon enough
Shoulden't have any effect at all the original key should still work, the new one won't as it hasen't been paired with the car.
Did you try starting with the new key before you found the original? To put ECU into learning mode to program new key you need a working key to start with.
Martin
martysmartie is offline   Reply With Quote
Old 16-01-2010, 05:39 PM   #8
Trader Score: (0)
tabetha will become famous soon enough
As said a new key won't erase or affect anything, it just won't work.
Assuming it's the same as earlier mondy etc with the RED master key, then you simply inser this key first, take out then have a certain time to insert new key and it reads the code and remembers it, something like that anyway.
As you will not have to take it to a ford dealer, ask them to delete the old keys, get yourself another cut, and ask them to programme a red master.
Shop around a lot for prices if you have local ford garages, but beleive some mobile locksmiths can do this as well now.
I had a new black key supplied and a red master supplied/coded and all the old keys deleted and it cost me £60 ish, but that was about 6 years ago.
tabetha is offline   Reply With Quote
Old 16-01-2010, 11:53 PM   #9
reisskahn
Trader Score: (0)
No didn't try starting it with the new key just turned on igintion and unlocked the steering wheel.
Tried to start it with the supposedly original that i managed to find
Disconnected the battery - no joy
left the original key in the barrel with the ignition on for about an hour somewhat hoping itll re-code lol but no joy
And no its not like the earlier mondeo's these models need the specalist computer to program them
Got a very cheap and resonable quote so will keep you posted on what happens
thanks
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
