PassionFord
Go Back   PassionFord > Main area > General Car Related Discussion.
Register Forgot Password?
Sponsored by Cartown
Click Here
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 11-01-2010, 11:33 AM   #1
Fil
ELASTIC BAND
Trader Score: (0)
Fil is on a distinguished road
Default How do you tell for sure if a headgaskets gone? Now with photo!
Ford Ka 2001 on 90K, boils off all its water after 4 or 5 miles, fan is working, car has no heat working, this is in the frezzing cold conditions.
Ive not been able to find a leak ( due to wet and snow covered floors ) , just alot of steam coming from the water expansion / filler tank, leaving it empty.
Now the oil filler has the water / oil mayo substance, tho not excessive, just a smear really , compared to my mk3 fiesta that has loads but has been like that for years and hardly done in water!
I have a compression tester, tho will need a bit of guidence using it, if that can be used to diagnosed a headgasket?
Really i would like to prove its the head gasket before taking it apart ( barking up the wrong tree etc )
cheers
__________________
S4 gone replaced by a Navara !
www.trance.fm
31/3/12 ASOT 550
30/6/12 HD fest
25/8/12 SW4
Fil is offline   Reply With Quote
Old 11-01-2010, 11:37 AM   #2
**caz**
**caz**'s Avatar
Trader Score: (0)
**caz** is on a distinguished road
KindaKrazyCaz
hmmmm...is there any of the gunk on the filler cap or dipstick? or oil in the water?
x
__________________
member of the Daytime pf talk bollocks and random shite club #69
XBOX 360 Gamertag - KindaCrazyCaz
**caz** is offline   Reply With Quote
Old 11-01-2010, 11:37 AM   #3
wirralphil
Trader Score: (0)
wirralphil is on a distinguished road
is the water pump working properly?
wirralphil is offline   Reply With Quote
Old 11-01-2010, 11:41 AM   #4
Fil
ELASTIC BAND
Trader Score: (0)
Quote:
good point, off in the cold to take a look!
__________________
www.trance.fm
31/3/12 ASOT 550
30/6/12 HD fest
25/8/12 SW4
Old 11-01-2010, 11:42 AM   #5
Fil
ELASTIC BAND
Trader Score: (0)
Quote:
I
Quote:
x
oh and nothing at all in the water tank
__________________
www.trance.fm
31/3/12 ASOT 550
30/6/12 HD fest
25/8/12 SW4
Old 11-01-2010, 11:43 AM   #6
xHayleyx
xHayleyx's Avatar
Trader Score: (0)
xHayleyx is on a distinguished road
milky/chalky oil filler cap, bluey coloured smoke pouring from exhaust.. loosing water..= headgasket
x
xHayleyx is offline   Reply With Quote
Old 11-01-2010, 11:44 AM   #7
BM08
BM08's Avatar
Trader Score: (0)
BM08 is on a distinguished road
My dad had his water pump go, and by the time he realised there was a big problem the engine was already stuffed.
BM08 is offline   Reply With Quote
Old 11-01-2010, 11:47 AM   #8
wirralphil
Trader Score: (0)
Just take the return off the header tank when the engine is running, if the water comes out of the pipe the pump is ok.
Old 11-01-2010, 11:51 AM   #9
Fil
ELASTIC BAND
Trader Score: (0)
sounds like a plan, cant even see the pump itself! its jam packed in the engine bay on the belt side
__________________
www.trance.fm
31/3/12 ASOT 550
30/6/12 HD fest
25/8/12 SW4
Old 11-01-2010, 12:03 PM   #10
Fil
ELASTIC BAND
Trader Score: (0)
Water coming out, so pumps ok then i suspect?
__________________
www.trance.fm
31/3/12 ASOT 550
30/6/12 HD fest
25/8/12 SW4
Old 11-01-2010, 12:08 PM   #11
Chip
*** Sierra RS Custard ***
Chip's Avatar
Trader Score: (3)
Chip will become famous soon enoughChip will become famous soon enough
Do the compression test on all 4 cylinders and post the values you get here, should be pretty obvious if the gasket has gone on the fire ring.
If its just gone between an oil way and a water way, then looking for fixed fluids is only option really.
__________________
Sometimes its more fun not to care if things make sense, and just do them anyway!
Vauxhall Nova, Mid Engined, RWD, 457bhp, Autronic SM4, GT35R, Quaiffe ATB Diff
2.0 16v - DIY Specced, DIY Built, DIY Mapped, DIY Abused
www.VauxSport.com
Chip is online now   Reply With Quote
Old 11-01-2010, 12:12 PM   #12
wirralphil
Trader Score: (0)
Yes.
Quote:
Run the engine until it reaches normal operating temperature. Tests done on a cold engine usually show lower readings. Remove the HT leads and take out all the spark plugs. The ignition system MUST then be disabled. If this isn't done it will continue to generate high tension voltages into the HT leads which will have nowhere to go with the plugs out. These high voltages will find another route to earth and can damage the ignition system or even the car's ECU. Unplug the low tension connections to the coil or to the distributor. If you aren't sure how to disable the ignition system on your own car then check with a dealer before you start. It is also good practise to unplug the fuel injectors or disable the fuel pump, especially on cars fitted with a catalytic convertor. This prevents unburned fuel getting into the exhaust system during the test. Screw the gauge into cylinder 1 and rest it somewhere you can see the dial while you crank the engine. Open the throttle fully either by pressing the accelerator or wedging the linkage open under the bonnet. If the throttle isn't open then air can't get into the cylinder and the readings will be far too low. Crank the engine until the gauge stops rising and count the revolutions while you do so. It should normally take no more than 10 engine revolutions (5 compression cycles) to get a full reading. You can count the cycles by watching the gauge too - each jump of the needle is one compression stroke. Write down the final reading and also make a mental note of how quickly the gauge rose on the first few cycles. Then just repeat for the other cylinders. Make sure that each cylinder reaches its highest reading after the same number of engine revolutions. If all readings are good then the test can end there. If any cylinders are low then a "wet" test can be done. This involves squirting a few ccs of oil into the cylinder and repeating the test. The oil will help seal bad rings and increase the reading but won't affect it if the problem lies in the valves or head gasket.
Old 11-01-2010, 12:12 PM   #13
.Ross.
.Ross.'s Avatar
Trader Score: (2)
.Ross. will become famous soon enough
Get a Coolant pressure tester, Pump 5psi in and start the motor .. If the Pressure climbs off the bat, Chances are the HD has shit the bed.
.Ross. is offline   Reply With Quote
Old 11-01-2010, 12:33 PM   #14
Fil
ELASTIC BAND
Trader Score: (0)
just run the car for 10mins, with about 5 of that driving it and yep all the waters steaming out the water filler cap!
No blue smoke or smells of burnt oil?
Not signs of any leaks, and the water system is pressurised.
So think i was barking up the wrong tree with the head gasket?
Can it be anything to do with the Ł10 thremostate valve? being stck shut? simple but ive not looked at that?
__________________
www.trance.fm
31/3/12 ASOT 550
30/6/12 HD fest
25/8/12 SW4
Old 11-01-2010, 01:50 PM   #15
dug112y
passionford pro
Trader Score: (1)
dug112y is on a distinguished road
If the water system is pressurised either the gasket is fooked or theres a crack in head or block.....get the tools out mate heads coming off
__________________
Never argue with an idiot,they bring you down to their level and beat you with experience.
TRACK FIESTA http://passionford.com/forum/restora...-new-pics.html
dug112y is offline   Reply With Quote
Old 11-01-2010, 01:53 PM   #16
martynhomer01
martynhomer01's Avatar
Trader Score: (1)
martynhomer01 is on a distinguished road
check the wires to the reverse switch too. sometimes they break
.................sorry..........wrong discussion.....
...........dont worry........i'll leave now
__________________
I WOULD RATHER PUSH MY FORD THAN DRIVE A VAUXHALL!!!!
Last edited by martynhomer01; 11-01-2010 at 01:55 PM. Reason: put it in wrong discussion.......nob
martynhomer01 is offline   Reply With Quote
Old 11-01-2010, 02:03 PM   #17
wirralphil
Trader Score: (0)
Just check the pipe after the stat when the car gets upto temp as with this cold weather you will be able to feel if the thermostat is working.
Old 11-01-2010, 03:11 PM   #18
Fil
ELASTIC BAND
Trader Score: (0)
well i took the stat off to have a look, and the gasket fell apart, so had to fit a new one anyway!
Still no good tho, just overheating?
__________________
www.trance.fm
31/3/12 ASOT 550
30/6/12 HD fest
25/8/12 SW4
Old 11-01-2010, 04:07 PM   #19
martynhomer01
Trader Score: (1)
i would say that the h/g gone if you have sludgy creamy stuff in the oil matey.
__________________
Old 11-01-2010, 04:10 PM   #20
Fil
ELASTIC BAND
Trader Score: (0)
drained a bit of oil from the sump, all seems normal? black and oily
__________________
www.trance.fm
31/3/12 ASOT 550
30/6/12 HD fest
25/8/12 SW4
Old 11-01-2010, 04:16 PM   #21
spinus
Trader Score: (0)
spinus is an unknown quantity at this point
same thing happened to my sis in laws, kept boiling and throwing all the water out of the header tank no gunk in oil though,changed water pump thermostat and header cap all good now. that was a 2003 ka with 50,000 miles 1.3
spinus is offline   Reply With Quote
Old 11-01-2010, 04:36 PM   #22
BigChuck
BigChuck's Avatar
Trader Score: (0)
BigChuck is an unknown quantity at this point
maybe take it to a garage that has the tester for gasses in the water system? sorry can't remember the name of the test.
BigChuck is offline   Reply With Quote
Old 11-01-2010, 04:39 PM   #23
t4 and greys
cosworth gimp
Trader Score: (5)
t4 and greys is on a distinguished road
just put it in nuetral and give it full throttle on the limiter for 10 mins
this way you can be 100% sure it will be the head gasket ,,,,,, well if the bottom end lasts !!!!
i always say best safe to be sorry ... at least this way its garanteed to show any weak spots
t4 and greys is offline   Reply With Quote
Old 11-01-2010, 04:51 PM   #24
RUPERT THE BIG HAIRY BEAR
Trader Score: (0)
RUPERT THE BIG HAIRY BEAR is on a distinguished road
alain rupert fitton
lmao i like that theory mr t4 and greys
RUPERT THE BIG HAIRY BEAR is offline   Reply With Quote
Old 11-01-2010, 04:58 PM   #25
wirralphil
Trader Score: (0)
Quote:
Not all the time, some breathers block and you get the mayo.
Big Chuck it's called a Sniff test.
Old 11-01-2010, 04:59 PM   #26
Fil
ELASTIC BAND
Trader Score: (0)
Ok back in 10mins....
__________________
www.trance.fm
31/3/12 ASOT 550
30/6/12 HD fest
25/8/12 SW4
Old 11-01-2010, 05:13 PM   #27
AaronsKa
Trader Score: (0)
AaronsKa is an unknown quantity at this point
Send a message via MSN to AaronsKa
Id say its just a nakered headertank cap. my ka kept over heating with its zetec lump, replaced the cap and its not happend since!
AaronsKa is offline   Reply With Quote
Old 11-01-2010, 05:20 PM   #28
.Ross.
.Ross.'s Avatar
Trader Score: (2)
Quote:
Ha Ha Ha .... Maybe ... Its desinged to open at like 6psi or summit?
Old 11-01-2010, 05:27 PM   #29
dug112y
passionford pro
Trader Score: (1)
did it freeze up solid at any time? was there anti freeze in it?
__________________
Old 11-01-2010, 05:29 PM   #30
Fil
ELASTIC BAND
Trader Score: (0)
Quote:
dont think so, as it allways started and ran through all the snow and cold mornings,
as for anti freeze doubt it had any? hasnt been serviced for over 50k too!
BTW its not my car
__________________
www.trance.fm
31/3/12 ASOT 550
30/6/12 HD fest
25/8/12 SW4
Old 11-01-2010, 05:30 PM   #31
Fil
ELASTIC BAND
Trader Score: (0)
Hmm ill take a look in a bit to whats fitted to it and the fiesta may swap them over and see what happens
__________________
www.trance.fm
31/3/12 ASOT 550
30/6/12 HD fest
25/8/12 SW4
Old 11-01-2010, 05:32 PM   #32
dug112y
passionford pro
Trader Score: (1)
BTW its not my car
did your fingers in the water and taste it...you will know if it has anti freeze in
__________________
Old 11-01-2010, 06:00 PM   #33
Fil
ELASTIC BAND
Trader Score: (0)
Its had several refills in the past week, so the origianll stuff its long gone
__________________
www.trance.fm
31/3/12 ASOT 550
30/6/12 HD fest
25/8/12 SW4
Old 14-01-2010, 06:13 PM   #34
Fil
ELASTIC BAND
Trader Score: (0)
Well it dont look like its gone, but the water ways are pretty blocked up in the gasket, what that cause the overheating in 3 - 4miles of driving then? i guess so.
__________________
www.trance.fm
31/3/12 ASOT 550
30/6/12 HD fest
25/8/12 SW4
Old 14-01-2010, 06:36 PM   #35
T3ORA
Trader Score: (0)
T3ORA is an unknown quantity at this point
right can i ask wot engine is in it, the HSC 1.3 thing
did you say that the heater was cold
did you check the heater valve or the stat
__________________
T3ORA is offline   Reply With Quote
Old 14-01-2010, 06:42 PM   #36
Fil
ELASTIC BAND
Trader Score: (0)
1.3 endura
Quote:
Have changed the thermostat, and cold/heat valve.
pulled the water bottle return pipe off whilst engine is running, getting water returning, so pump is working.
poured water in the rad and it runs out the bottom, so not blocked.
Also fan is running.
Now there oil filler has a slight minimal bit of mayo'ness to it, but the cars allways only used for short journeys, drained some oil out and it looks reasonable, black and smells right!
swaped the water tank cap with a known working one.
__________________
www.trance.fm
31/3/12 ASOT 550
30/6/12 HD fest
25/8/12 SW4
Old 14-01-2010, 06:46 PM   #37
T3ORA
Trader Score: (0)
my bad must read posts
head gasket then
__________________
Old 14-01-2010, 06:48 PM   #38
Fil
ELASTIC BAND
Trader Score: (0)
head gasket then
but cheers for looking
__________________
www.trance.fm
31/3/12 ASOT 550
30/6/12 HD fest
25/8/12 SW4
Old 14-01-2010, 07:11 PM   #39
t4 and greys
cosworth gimp
Trader Score: (5)
take some pics of the bores for us and also pics of the cylinder head combustion chamber
personally put monet on a cmpression-water jacket blow( goosed headgasket)
should be able to tell if this is the case as hot steam cleans up the problem bore nicely
ie... the cylinder that is blown should be visibly cleaner than the others .....
also could very well be a cracked head or block if its had no antifreeze
just dont understand why people dont understand that water freezes and EXPANDS which cracks head /block etc !!!
so its a gasket or a crack (not the female variety either )
good luck
might be worth finding out how much scrap value per tonne is locally imho
Old 14-01-2010, 07:15 PM   #40
Fil
ELASTIC BAND
Trader Score: (0)
__________________
www.trance.fm
31/3/12 ASOT 550
30/6/12 HD fest
25/8/12 SW4
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
