PassionFord
Go Back   PassionFord > Main area > General Car Related Discussion.
Register Forgot Password?
Sponsored by Cartown
Click Here
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 14-01-2010, 07:31 PM   #41
t4 and greys
cosworth gimp
Trader Score: (5)
t4 and greys is on a distinguished road
looking at that pics it looks ok gasket wise ,but no 1 pot looks a bit done in ??
hard to tell from the pics though if im honest , might be some other issue , i would now get the head checked over and see if its cracked.....
t4 and greys is offline   Reply With Quote
Old 14-01-2010, 07:39 PM   #42
Fil
ELASTIC BAND
Trader Score: (0)
Fil is on a distinguished road
i think the camera flash is causing it to look a bit different, as visually looking they looked the same, but it was getting dark!
Getting the head checked, whats that involve then and is it a case of any garage can do it?
__________________
S4 gone replaced by a Navara !
www.trance.fm
31/3/12 ASOT 550
30/6/12 HD fest
25/8/12 SW4
Fil is offline   Reply With Quote
Old 14-01-2010, 07:46 PM   #43
tiny2white
Trader Score: (2)
tiny2white is on a distinguished road
was it missing or firing on all 4? did you notice water coming out the exhaust i had a hole behind a valve on my saph and as i was putting water in it was comming out the exhaust! as soon as the water dropped it run on all 4 but didn't show signs of steam cleaning due to the amount of water leaking in to the bore!!!!
__________________
tiny2white is offline   Reply With Quote
Old 14-01-2010, 08:19 PM   #44
dug112y
passionford pro
Trader Score: (1)
dug112y is on a distinguished road
cylinders dont look bad...gasket waterways are fooked. i'd pull water pump off it to check while its in bits ..might be corroded and fins broke off. go get head pressure tested while its off.check rad for blockage and backflush it with a hosepipe.
then build it back up and see how it goes. if it still does it blocks prob cracked and you will be fitting a new engine as its not worth the grief..a few on ebay ATM
__________________
Never argue with an idiot,they bring you down to their level and beat you with experience.
TRACK FIESTA http://passionford.com/forum/restora...-new-pics.html
dug112y is offline   Reply With Quote
Old 14-01-2010, 10:15 PM   #45
Fil
ELASTIC BAND
Trader Score: (0)
the water pump looks a nightmare to get at.
but yeah have already looked at ebay for engines, just in case
__________________
www.trance.fm
31/3/12 ASOT 550
30/6/12 HD fest
25/8/12 SW4
Old 14-01-2010, 10:22 PM   #46
scoobypete
scoobypete's Avatar
Trader Score: (0)
scoobypete is on a distinguished road
Quote:
Originally Posted by BigChuck View Post
maybe take it to a garage that has the tester for gasses in the water system? sorry can't remember the name of the test.
block tester
__________________
my mk4 track prject (AKA the legendary GAYLAND escort)
http://passionford.com/forum/restora...date-look.html
Quote:
Originally Posted by Chip View Post
Yes, converting an XR4i to RWD is easy mate.
All you need to do is the following:
Stand next to the car.
Shout "I am a cock"
It will be rwd
scoobypete is offline   Reply With Quote
Old 14-01-2010, 10:27 PM   #47
JTECH James
Passion for Fords!
Trader Score: (13)
JTECH James is an unknown quantity at this point
water pump not working?
make sure you strip and clean the rocker shaft when it goes back together aswell
__________________
JAMES
JTECH James is offline   Reply With Quote
Old 14-01-2010, 11:21 PM   #48
Fil
ELASTIC BAND
Trader Score: (0)
I think the water pump was ok as I took the return pipe of the tank and water came out whilst the engine was running
ask the oily bits are currently soaking in a cleaning tank at work will get them out in abit
__________________
www.trance.fm
31/3/12 ASOT 550
30/6/12 HD fest
25/8/12 SW4
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
