PassionFord
Go Back   PassionFord > Main area > General Car Related Discussion.
Register Forgot Password?
Sponsored by Cartown
Click Here
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 05-01-2010, 08:15 PM   #1
1.9 xr2 on 40's
Trader Score: (0)
1.9 xr2 on 40's is an unknown quantity at this point
Default 57 tranny washer fuse
does anybody know where it is
levels fine, not frozen but no squirt or noise
no mention in the handbook or little logos on the cover of the fuse box and even the recovery man who jump started me the other day couldnt find owt
apparently is happens loads but nobody know which they change on the other trannys at work
also no 10wts are blown :doh:
cant see shit when the suns up front
__________________
1.9 xr2 on 40's is offline   Reply With Quote
Old 05-01-2010, 08:24 PM   #2
DazC
Trader Score: (1)
DazC is an unknown quantity at this point
Send a message via MSN to DazC
have you checked all 3 fuse boxes? 1 under the bonnet and 2 behind the glove box? i don't know the exact fuse number.
DazC is offline   Reply With Quote
Old 05-01-2010, 08:27 PM   #3
1.9 xr2 on 40's
Trader Score: (0)
hmm i only found 1 under the glove box, i should look again
ta
__________________
Old 05-01-2010, 08:27 PM   #4
RSGARETHW
always working
Trader Score: (2)
RSGARETHW is on a distinguished road
dont know the fuse number but its under the pasenger side foot well.take the glove box completley out. if u look where the relays are the grey compartment drops forward'' its on clips '' and behind it are quite a few fuses... your looking for A 10AMP one think its blue.. had to change mine on monday
thanks gaz
RSGARETHW is offline   Reply With Quote
Old 05-01-2010, 08:29 PM   #5
BRAM
Trader Score: (1)
BRAM is on a distinguished road
Its the fuse box behind the glovebox take the cover off then ontop of the fusebox there are 2 clips you push outwards and the front moves down and there is another fuse box behind there, its fuse 67, 10amp but it needs replacing with a 15amp job done.
__________________
BRAM is offline   Reply With Quote
Old 05-01-2010, 08:29 PM   #6
RSGARETHW
always working
Trader Score: (2)
beat ya to it
Old 06-01-2010, 05:52 PM   #7
1.9 xr2 on 40's
Trader Score: (0)
excellent cheers guys ill dig about in a bit
__________________
Old 06-01-2010, 06:17 PM   #8
dojj
Resident Wrestling Legend
dojj's Avatar
Trader Score: (3)
dojj is a jewel in the roughdojj is a jewel in the roughdojj is a jewel in the roughdojj is a jewel in the rough
push the sides of the glovebox together and pull it out totally
it will drop it's contents on the floor though but you'll be ale to see everyting
dojj is offline   Reply With Quote
Old 06-01-2010, 06:19 PM   #9
Rob..
J496AEV R.I.P
Rob..'s Avatar
Trader Score: (0)
Rob.. is on a distinguished road
Can you do that on the 05 plate one's aswell ?
__________________
www.sunrisefm.co.uk
Rob.. is offline   Reply With Quote
Old 06-01-2010, 06:27 PM   #10
dojj
dojj's Avatar
Trader Score: (3)
not sure mate, only been in later mk7's
Old 06-01-2010, 06:29 PM   #11
Rob..
J496AEV R.I.P
Rob..'s Avatar
Trader Score: (0)
Ok
wont try that on a green machine then
__________________
www.sunrisefm.co.uk
Old 06-01-2010, 06:38 PM   #12
sapph1
sapph1's Avatar
Trader Score: (8)
sapph1 will become famous soon enoughsapph1 will become famous soon enough
As said above, take the glove box out, fold the front fuse box down, its fuse 67 in the rear fusebox, passenger footwell.
Ford recommend changing the 10 amp fuse for a 15 amp one also
__________________
sapph1 is offline   Reply With Quote
Old 06-01-2010, 06:49 PM   #13
James998
Trader Score: (0)
James998 is an unknown quantity at this point
You can tell the people who work for ford on here, or the people who drive transits in their job :P
And yes, fuse 67 lol.
James998 is offline   Reply With Quote
Old 06-01-2010, 06:55 PM   #14
sapph1
sapph1's Avatar
Trader Score: (8)
Lol, i work for Ford and pretty much every other Transit that comes in at the moment is for washers inop!
__________________
Old 06-01-2010, 07:12 PM   #15
keiron01
Trader Score: (0)
keiron01 is on a distinguished road
Default transit wiper fuse
hi the fuse is behind the orignal fuse box there is a clip on it undo it and there is another fuse box behind it were you will find your wiper motor fuse
keiron01 is offline   Reply With Quote
Old 06-01-2010, 09:44 PM   #16
BRAM
Trader Score: (1)
Quote:
No you cant do that on the older shape transit if you need the fuse box you lift the top of dash where the cup holder is it just pulls out.
__________________
Old 06-01-2010, 09:47 PM   #17
BRAM
Trader Score: (1)
Quote:
Yeah i work at ford too and its the same in our place we have ran out of 15 amp fuse's the parts have had to go to out and buy some fuse's from some other motor factor.
__________________
Old 06-01-2010, 09:47 PM   #18
1.9 xr2 on 40's
Trader Score: (0)
i used to too but i spent more time smashing up the 165's
__________________
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Cossie Tranny MikeyRobbo General Car Related Discussion. 2 15-08-2009 03:57 PM
02 reg tranny 280 boothy General Car Related Discussion. 5 02-06-2009 10:16 AM
gti oil pressure switch, Washer or no washer? MK3man. Technical help Q & A 6 22-04-2009 06:09 PM
using a different box and tranny gaz_turbo1 Technical help Q & A 3 25-03-2008 06:31 PM
Fuse link wires - what amp fuse to replace??? kjc300 General Car Related Discussion. 17 17-12-2005 10:09 PM
