PassionFord
Go Back   PassionFord > Main area > General Car Related Discussion.
Register Forgot Password?
Sponsored by Cartown
Click Here
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 04-01-2010, 01:57 PM   #1
Paulo P
Paulo P's Avatar
Trader Score: (0)
Paulo P is on a distinguished road
Default Handbrake freezes on in the cold weather, any ideas why?
My wife has a mark 3 golf gti and the handbrake has frozen on a couple of times now First time was when it snowed 2 weeks ago and it did it again last night
The mark 3 has disks on the rear and I fitted new rear pads to it about 6 weeks ago and I cleaned up the surfaces and copper slipped the sliders & carriers before fitting the new pads. When it froze the other week I managed to drive the car but it was dragging the rear wheels on the snow like the handbrake was partially on which means it's not the pads stuck to the disk It took just over 1 mile of rather gentle driving before it cleared, this was more than likely caused by the heat generated trying to limp it home
My question is why is this happening? She has had the car nearly 4 years and up until this winter there hasn't been a problem, it is something on the car or the fact that she now parks on it on a gravel drive maybe? I'm wondering if the moisture under the gravel is being drawn up and then freezing.
Anyhow anyone got any ideas please?
Thanks
__________________
Paulo P is offline   Reply With Quote
Old 04-01-2010, 02:03 PM   #2
CalibreDan
Trader Score: (0)
CalibreDan is an unknown quantity at this point
If I remember rightly quite a few VAG cars have problems with the handbrake cables letting water in and freezing
CalibreDan is offline   Reply With Quote
Old 04-01-2010, 02:04 PM   #3
Paulo P
Paulo P's Avatar
Trader Score: (0)
I was thinking either linkage or cables because of the way if feels, do you know if it's possible to get wd40 into the cables?
Thanks
__________________
Old 04-01-2010, 02:06 PM   #4
Andy_R
Trader Score: (3)
Andy_R is an unknown quantity at this point
I was taught that handbrakes are only used in this weather for turning
I tend not to use the handbrake for parking at all in cold conditions - simply park in gear, saves the sort of situations your experiencing.
__________________
Andy_R is offline   Reply With Quote
Old 04-01-2010, 02:11 PM   #5
Paulo P
Paulo P's Avatar
Trader Score: (0)
You haven't been to Wycombe then It's all on hills around here
__________________
Old 04-01-2010, 02:41 PM   #6
cozzy jeff
cozzy jeff's Avatar
Trader Score: (3)
cozzy jeff is on a distinguished road
got in my van this morning to find my handbrake siezed on, its a vauxhall combo, been stood for over a week,it took a little freeing off by pulling forward and reversing,when i got home i just left i in gear.
cozzy jeff is offline   Reply With Quote
Old 04-01-2010, 04:16 PM   #7
Glenn.
Glenn.'s Avatar
Trader Score: (1)
Glenn. is on a distinguished road
simple solution dont put the hand brake on. There will be water that has frozen in the handbrake cables.
Glenn. is offline   Reply With Quote
Old 04-01-2010, 05:05 PM   #8
Paulo P
Paulo P's Avatar
Trader Score: (0)
Quote:
Can't really do that because I live in a hill and my driveway is on a hill I could park it opposite the house in gear with a wheel against the kerb but you can guarantee the first thing my wife would do is pull the handbrake to do a hill start
I'm going to take a look at it and see if I can somehow get wd40 into the cables and then grease the ends, shame I can't dry them out because I think that's the only real way of curing it
I'm not giving up the garage for a golf and leaving the cossie on the drive
__________________
Old 04-01-2010, 05:11 PM   #9
R4N S S
R4N S S's Avatar
Trader Score: (6)
R4N S S is on a distinguished road
my astra does this in really cold weather.
did it last year but i just put it down to the abuse the car was getting in the snow
Then it did it this year and again put it down to the snow abuse.
However, my old man took the car to work last night and was complaining this morning that the hand brake was stuck on oddly enough I just done a trip to Dam and back this weekend and the car was fine.
Plenty of meat on the discs and pads too. I have ended up parking it in gear.
__________________
RAN
Middlesex RSOC Treasurer
Moonstone 3dr gone
White 3dr Track car being built and restored
http://passionford.com/forum/restora...abuse-car.html
E36 325i Drifter
R4N S S is offline   Reply With Quote
Old 04-01-2010, 09:53 PM   #10
Ginge !
just finding my feet
Ginge !'s Avatar
Trader Score: (0)
Ginge ! is on a distinguished road
its prob cause you live 4000 feet above sea level !!!!, sod driving round where you live when it snowed !!!
ps: cheers for sorting out the linkage,,,, mates scooby is now mint again !!!
__________________
Quote:
Originally Posted by zetec-Sam View Post
Just think 'what would Charlie Sheen do?'
Ginge ! is offline   Reply With Quote
Old 04-01-2010, 09:54 PM   #11
bad boy rs
bad boy rs's Avatar
Trader Score: (7)
bad boy rs is an unknown quantity at this point
my transporter does the same in this weather, i always forget to not use it though and by the morning its to late
__________________
395 bhp & 410 lb/ft
bad boy rs is offline   Reply With Quote
Old 04-01-2010, 10:07 PM   #12
RUPERT THE BIG HAIRY BEAR
Trader Score: (0)
RUPERT THE BIG HAIRY BEAR is on a distinguished road
alain rupert fitton
the outer cable ends will have warn a bit and let some moisture in and its then frozen simple dont use hand barke leave inn gear and for a bit more if ur worried the front wheels will slide put a few bricks under them
RUPERT THE BIG HAIRY BEAR is offline   Reply With Quote
Old 04-01-2010, 10:28 PM   #13
bil_s2
bil_s2's Avatar
Trader Score: (0)
bil_s2 is on a distinguished road
I had the same problem with a 944. The sleeve on the cable was worn/perished in places and water was getting in and then freezing. I got the cable replaced and it was fine.
__________________
____________________________________________
1990 s2 - 2.1 ZVH & 1987 s2 w/ s1 kit & stripes
bil_s2 is offline   Reply With Quote
Old 05-01-2010, 12:06 AM   #14
Paulo P
Paulo P's Avatar
Trader Score: (0)
We couldn't move at all in the snow due to the hills, it was gridlocked around here and my wife didn't even make it home That main road up to mine wasn't gritted so there were abandoned cars everywhere.
Glad you sorted it
__________________
Old 05-01-2010, 12:12 AM   #15
Paulo P
Paulo P's Avatar
Trader Score: (0)
I inspected the car tonight and I found that the rubber sleeve on the nearside handbrake cable wasn't covering the cable and the cable was slightly corroded. I cleaned everything up, ran some wd40 down the cables, refitted the rubber sleeve and coperslipped the cables. I'm not sure if it will make a difference but it's the best I could do tonight
Thanks for your help and suggestions I have never experienced it before and didn't realise it was so common!
__________________
Old 06-01-2010, 01:37 AM   #16
Paulo P
Paulo P's Avatar
Trader Score: (0)
Update.
It was still frozen the following morning so my wife took my car to work
When it thawed I ended up leaving her car in gear with a wheel against a rock on the drive but then it snowed like crazy lmao
__________________
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Cold weather Problems jamie.patrick Technical help Q & A 0 15-11-2007 11:51 AM
fooked handbrake any ideas please???? turbo.jon General Car Related Discussion. 10 04-06-2006 07:38 PM
Oil - Cold weather selection oilman General Car Related Discussion. 11 25-11-2005 07:31 PM
cold weather and turbo's Westy General Car Related Discussion. 34 19-11-2005 05:39 PM
how's your 'RS' finding all this cold weather? RSCossieGaz General Car Related Discussion. 55 28-02-2005 12:14 PM
