PassionFord
Go Back   PassionFord > Main area > General Car Related Discussion.
Register Forgot Password?
Sponsored by Cartown
Click Here
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 26-12-2009, 03:18 PM   #1
lee2cossies
Trader Score: (1)
lee2cossies is an unknown quantity at this point
Default E36 BMW M3 Diff on cossie beam?
Anyone know whats involved in fitting one to a cossie rear beam? It doesnt look to much hastle to make it fit,obviously custom shafts etc,but unsure of the ratios and that.Any ideas? would it be worth doing?
lee2cossies is online now   Reply With Quote
Old 26-12-2009, 05:34 PM   #2
GARETH T
GARETH T's Avatar
Trader Score: (0)
GARETH T is an unknown quantity at this point
Send a message via MSN to GARETH T
why?
__________________
GARETH T is offline   Reply With Quote
Old 26-12-2009, 06:05 PM   #3
STUCOS
Trader Score: (8)
STUCOS is an unknown quantity at this point
Know a guy who runs m3 evo g/box and rear diff in his cossie powered mk2 escork ,WHY because much better and cheaper than wank ford stuff
cheeRS stu
__________________
FULL OD RACK
STEER FAE THE BACK
STUCOS is offline   Reply With Quote
Old 26-12-2009, 06:12 PM   #4
GARETH T
GARETH T's Avatar
Trader Score: (0)
is it really stronger i dont know?
but im sure once you paid for someone to make you up a set of one off shafts, and bought the diff, you'll be up to the price of a nice re-built uprated unit
__________________
Old 26-12-2009, 06:17 PM   #5
STUCOS
Trader Score: (8)
Garath m3 evo produces a fair amount of torque,this guy used a complete m3 rear end,so oe shafts,but understand what toy are saying on cost
cheeRS stu
__________________
FULL OD RACK
STEER FAE THE BACK
Old 26-12-2009, 06:21 PM   #6
Mike1
Trader Score: (0)
Mike1 is on a distinguished road
Quote:
cheeRS stu
Is it this Escort?
Mike1 is offline   Reply With Quote
Old 26-12-2009, 06:24 PM   #7
GARETH T
GARETH T's Avatar
Trader Score: (0)
cheeRS stu
is the evo diff different from a normal m3? as i know someone whos done a few in!
__________________
Old 26-12-2009, 06:27 PM   #8
STUCOS
Trader Score: (8)
Yes mike,thats rich's car,
__________________
FULL OD RACK
STEER FAE THE BACK
Old 26-12-2009, 06:31 PM   #9
james kiely
Trader Score: (3)
james kiely is on a distinguished road
is the diff physically bigger than the 2wd cossie one?
cheers james
__________________
cheers james
james kiely is offline   Reply With Quote
Old 26-12-2009, 07:02 PM   #10
turbotoaster
turbotoaster's Avatar
Trader Score: (0)
turbotoaster is an unknown quantity at this point
Send a message via MSN to turbotoaster
i think the guy on driftworks ran his m3 turbo up to nearly 800bhp and he uses it as a drift car, from what his spec said hes running standard box and diff, so might be a cheaper setup that a tremec and 9" diff if you can get a good deal on them
__________________
It's a basic truth of the human condition that everybody lies. The only variable is about what!
turbotoaster is offline   Reply With Quote
Old 26-12-2009, 07:22 PM   #11
fuzzy
11000+ post super hero
fuzzy's Avatar
Trader Score: (0)
fuzzy is an unknown quantity at this point
asadf ucker.com evilfuzzy2011
a bmw lsd will cost about Ł300. a custom prop about Ł200 plus custom driveshafts another couple of hundred quid. Ł700 before you start. how much is an uprated cosworth diff?
my standard e30 lsd took alll the cosworth 330bhp abuse i could through at it for a couple of years no problem..
__________________
stage 3 cosworth converted bmw e30 touring.
xbox live evilfuzzy2011
fuzzy is offline   Reply With Quote
Old 27-12-2009, 10:45 AM   #12
GARETH T
GARETH T's Avatar
Trader Score: (0)
they sounds good in general then! i would say that if you can make up all the fitting bits yourself then have a go, but if you have to pay for all the bits to be fitted then you might aswell go down the route of tried and tested, as im sure it would work out better on the pocket in the long run
__________________
Old 27-12-2009, 01:20 PM   #13
lee2cossies
Trader Score: (1)
I was looking at a few of the maltese cossies they use them for drag racing.Can buy one for Ł300 and their rated to 600hp aparently,my cossie will only ever be 500 so it should be fine.I could modify the beam and shaft myself,only thing i would have to do is pay to have them balanced,just an idea thats all,before i go and pay loads for a quaife diff. Oh and i should be able to do proper dounuts then unlike the crap sierra diff! Anyone know the diff ratios? And how they would work on a 2wd cossie?
Old 27-12-2009, 01:35 PM   #14
fuzzy
fuzzy's Avatar
Trader Score: (0)
ive heard of a few ratios for e36 diffs . 2.79 , 2.93 ,3.25 ,3.64 ,3.73 ,3.91 and 4.1. usually the m series diffs are lower around the 3.25 mark. i had a 3.91 lsd on my cossie bmw and the acceleration was quite savage for a stage 3 also using a t5.
__________________
Old 27-12-2009, 01:35 PM   #15
alanfordtw-15
alanfordtw-15's Avatar
Trader Score: (0)
alanfordtw-15 is an unknown quantity at this point
the best bmw diff to use would be an e39 m5 diff, rated for 1000hp standard. not sure on avaliablity/price though.
the m3 diff would be a stronger diff than a ford one anyway, as im sure bm diffs are mild steel casings and ford ones are alloy
__________________
alanfordtw-15 is offline   Reply With Quote
Old 27-12-2009, 01:47 PM   #16
lee2cossies
Trader Score: (1)
Interesting.Think its definetly worth having a play about with.Ford diffs are crap and bmw ones always seem to be good,and havnt heard of many breaking even with huge power.Had a look at whats about but cant find any m5 diffs to see what they look like but seems to be plenty of e36 m3 diffs around.Il do a bit of research on the diff ratios and try and work out which one is best.Does anyone know if the casing for a normal e36 bmw diff is the same as a m3 casing? if so il just get a cheap normal dif to have a play around with my spare beam.
Old 27-12-2009, 02:19 PM   #17
fuzzy
fuzzy's Avatar
Trader Score: (0)
not to clued up on e36's . e30's were my thing.
__________________
Old 27-12-2009, 04:27 PM   #18
dojj
Resident Wrestling Legend
dojj's Avatar
Trader Score: (3)
dojj is a jewel in the roughdojj is a jewel in the roughdojj is a jewel in the roughdojj is a jewel in the rough
the diffs look remarkably similar when you get them side by side, even the bolt holes in the output shafts look like they may be a close enough fit to be useable
dojj is offline   Reply With Quote
Old 27-12-2009, 06:08 PM   #19
m4rkl
Trader Score: (0)
m4rkl is on a distinguished road
mark longbottom
e36 m3 evo uses the biggest diff in the 3 series range with a 3.23 ratio.
m4rkl is offline   Reply With Quote
Old 27-12-2009, 06:42 PM   #20
GARETH T
GARETH T's Avatar
Trader Score: (0)
and there was me thinking it was torque that breaks diffs, not the amount of work its done
__________________
Old 27-12-2009, 07:30 PM   #21
DangerousBryan
Trader Score: (0)
DangerousBryan is an unknown quantity at this point
m3 evo diff is different to m3 diff as well. m3 diff is 3.15 and evo diff is 3.23. 325 and m3 diffs are the same size. evo ones are bigger again.
__________________
bryan
e36 m3 evo 4 door. 13.81@102 1/4 2.1sec 60ft
and a tranny diesel 76bhp
9.21 bridge to gantry. 14 laps
DangerousBryan is offline   Reply With Quote
Old 28-12-2009, 05:41 PM   #22
lee2cossies
Trader Score: (1)
What would be the best ratio diff to use on a sierra on 18" wheels? and would a normal m3 diff be able to handle 500hp?
Old 28-12-2009, 06:04 PM   #23
fuzzy
fuzzy's Avatar
Trader Score: (0)
for acceleration or top end? my 3.91 was savage in accelerating but ran out of go about 130mph on 17's and 2wd t5.
i tried a 3.64 for a short time but it definately lost the edge in accelerating.
__________________
Old 28-12-2009, 06:08 PM   #24
Paul_RS
Paul_RS's Avatar
Trader Score: (4)
Paul_RS is an unknown quantity at this point
Send a message via MSN to Paul_RS
By the time you mess about custom making bits and pieces you'd be better off buying an uprated Ford diff that fits straight in. I've had no issues with my standard 7" diff and its had quite a few full bore launches!
__________________
Paul_RS is offline   Reply With Quote
Old 28-12-2009, 06:11 PM   #25
lee2cossies
Trader Score: (1)
Would like to keep the ratios similar or as close as possible to as they are.
Old 28-12-2009, 06:14 PM   #26
lee2cossies
Trader Score: (1)
Quote:
Il have 500hp one day when i finish my car and dont think the standard diff will cope.Iv got a spare beam im going to chop up and have a mess around with anyway to make it adjustable so a bit more fabricating is fine,and secondhand quaife diffs areŁ700+.
Old 28-12-2009, 08:34 PM   #27
GARETH T
GARETH T's Avatar
Trader Score: (0)
if your going to chop a rear beam,, i would also think about rear suspension geometry at the same time
__________________
Old 28-12-2009, 08:36 PM   #28
fuzzy
fuzzy's Avatar
Trader Score: (0)
i thought new quiaffe diffs were about Ł700?
__________________
Old 28-12-2009, 08:43 PM   #29
JonnyBravo
Trader Score: (0)
JonnyBravo will become famous soon enough
Quaife or plate diff they still use the original cwp which IS a weak link.
Either go 9" or as your saying find something thats more suitable from another car.
Some people don't break the 7.5" units, I guess thats as their either not that hard on their car or its not making the power they thought.
I've only known one person personally with a genuine 500+hp engine in a Saph and that would smash ANY Cosworth diff you put in it with the way he drove it, a 9" was the only solution for him but that doesn't mean there aren't cheaper options available
__________________
JonnyBravo is offline   Reply With Quote
Old 29-12-2009, 06:07 PM   #30
lee2cossies
Trader Score: (1)
Just looking for a cheap alternative really and dont mind messing around to make things fit.Iv been told that the m3 diff will handle up to 600hp and is a much better diff than a cossie one.They are popular in malta with drag racing on sierras.
As for the suspension geometry,im just looking to improve the camber,once i have finished il have it all checked properly and set up by someone who knows what their doing.
Old 29-12-2009, 06:53 PM   #31
Glenn.
Glenn.'s Avatar
Trader Score: (1)
Glenn. is on a distinguished road
interesting thread. Do bara not make diffs or do they only do gearboxes.
Glenn. is online now   Reply With Quote
Old 29-12-2009, 07:23 PM   #32
lee2cossies
Trader Score: (1)
Think they do diffs also but probably cost a lot more than what it would cost me to make a bmw one fit.
Old 29-12-2009, 07:48 PM   #33
dojj
dojj's Avatar
Trader Score: (3)
surely you don't mean jb
Old 29-12-2009, 08:20 PM   #34
janvanv
www.rallyanarchy.com
Trader Score: (0)
janvanv is an unknown quantity at this point
The 5 series BMW diff I have sitting on the shelf has a ring gear a good step smaller than that a Ford 7 1/2' one but the diff is a nice strong ZF 4 pinion diff.
Halfshafts are about same diameter as 2wd, and the CV joints are the 4x4 or Scorp smaller diameter CVs but with M10 bolts.
MOST BMW ratios are crazy 2,87 or maybe 3,08 for their larger powered cars which seems odd but then again their box ratios are often 4.2 or so for 1st gear so it works out for them, Combing a BMW box and Ford diff or BMW diff and ford box is going to be weider than weird.
I've seen some really far-sighted and brilliant , and dashingly handsome guy way out in the far north West of America using Toyota MkIII Supra 8" diffs with honkin' huge stub shaft diameter and easy to fit and find and he made some sweet adaptor plates to allow using either 2wd Cossie or 4x4 sized CVs.
Stock ratios are 3,9 for early, 3.73 for later manual box and 4,3 for autotragique slush box.
__________________
John Vanlandingham
janvanv is offline   Reply With Quote
Old 29-12-2009, 10:59 PM   #35
lee2cossies
Trader Score: (1)
Thanks for that,at last a valid bit of info! Could you give me any email adress or web site or anything for this guy? As i said im considering all options just trying to get some info before i go and buy something and make it fit.
Old 30-12-2009, 12:06 AM   #36
scoooby slayer
Trader Score: (4)
scoooby slayer is an unknown quantity at this point
i think you must be refering to glyn ?
__________________
widebody doluck mkiv supra, 900 hp on a t51r spl bb 134 mph in the 1/4 mile so far
new project im building a dragster for pod http://passionford.com/forum/restora...r-is-born.html
scoooby slayer is offline   Reply With Quote
Old 30-12-2009, 12:14 AM   #37
JonnyBravo
Trader Score: (0)
Yep, I have never been in a car driven like that to this day
He's crackers, but also has a unit full of spares so isn't afraid of having to go down the route that some would consider to be OTT
Good idea shown above though
__________________
Old 30-12-2009, 12:28 AM   #38
pacwest
Puller of the Wrench
pacwest's Avatar
Trader Score: (0)
pacwest is on a distinguished road
Quote:
Remember, GMT -8.
John Vanlandingham
Sleezattle, WA 98168
USA
CALL =-> (206) 431-9696 <-= CALL
www.rallyrace.net/jvab/
__________________
1988 Sapphire 2WD - 1985 Merkur XR4Ti.
http://jasonhollister.com
Breaking a 2wd saff? Click here to see my wish list
pacwest is offline   Reply With Quote
Old 30-12-2009, 12:41 AM   #39
Chip
*** Sierra RS Custard ***
Chip's Avatar
Trader Score: (3)
Chip will become famous soon enoughChip will become famous soon enough
Interesting thread, im a massive fan of using OEM parts from other cars that are up to the job, its invariably cheaper than fancy aftermarket bits and often better made.
Would be great to see someone doing an off the shelf E39 diff conversion for cossies or something along those lines
__________________
Sometimes its more fun not to care if things make sense, and just do them anyway!
Vauxhall Nova, Mid Engined, RWD, 457bhp, Autronic SM4, GT35R, Quaiffe ATB Diff
2.0 16v - DIY Specced, DIY Built, DIY Mapped, DIY Abused
www.VauxSport.com
Chip is offline   Reply With Quote
Old 30-12-2009, 12:45 AM   #40
pacwest
pacwest's Avatar
Trader Score: (0)
I'm a big fan of the supra diff. I've seen it done too many times with excellent results to look at anything else.
__________________
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
2wd diff in 4x4 beam? Moonstone Mart Ford Sierra / Sapphire / RS500 Cosworth 6 01-05-2009 11:06 AM
2wd diff into 4x4 rear beam Lloyd General Car Related Discussion. 11 13-05-2008 07:48 PM
rwd diff into 4x4 beam Lloyd General Car Related Discussion. 1 03-05-2008 06:46 PM
Wanted - 2wd Cossie rear beam / Diff / drive shafts SapphyMike Cars & Parts Wanted. 10 03-05-2007 05:16 PM
2wd beam and diff into a 4x4 jabcos General Car Related Discussion. 6 26-03-2007 08:23 PM
