PassionFord
Go Back   PassionFord > Main area > General Car Related Discussion.
Register Forgot Password?
Sponsored by Cartown
Click Here
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 21-12-2009, 10:12 PM   #1
FordMondeoMk1
Trader Score: (0)
FordMondeoMk1 is on a distinguished road
Unhappy 'Speedometer' problems, MK1 Mondeo K'93' plate
Hay there, i recently brought a Ford Mondeo 1.8 LX 115hp a couple of weeks back, first off it has been left for a few months so please take this in to account!
There are a few minor problems;
obviously the first and most important, the Speedo used to wobble but quite close to the actual speed reading but never stopped and always wobbled, but now its completly not working but i have read messages and there is no wining from gearbox, and no funny sounds, a friend assumes its a fuse, but i suspect otherwise, Please give me your opinions and advice.
i have a 5 week old daughter so i want to be responsable now.
also my windscreen washer pump seems to wind up but it isnt producing water, there is no blokage BUT the pipe has come off the pump but still no water leaking out of the pump when i look under the car after pumping the washer jet! Any advice or help would be much apreciated. i have been told by someone it might still be winding but the pump has seized, which makes as much sense as a car passing a MOT test without no exterior signaling lighting bulbs!
i have basic to average knowledge mechanicly so can manouver some assembling many thanks Colin
FordMondeoMk1 is offline   Reply With Quote
Old 21-12-2009, 10:19 PM   #2
wayne dowling
wayne dowling's Avatar
Trader Score: (1)
wayne dowling is on a distinguished road
the speedo could be the speedo drive in the box they can wear with them only being plastic
__________________
Drive it like its stolen
wayne dowling is offline   Reply With Quote
Old 21-12-2009, 10:31 PM   #3
FordMondeoMk1
Trader Score: (0)
Smile
Quote:
Any ideas what would be involved in replacing such an item, im hoping it dosent involve ripping the gearbox apart! it drives amazing though!
Old 21-12-2009, 10:37 PM   #4
Glenn.
Glenn.'s Avatar
Trader Score: (1)
Glenn. is on a distinguished road
I would try to remove your washer bottle pump and make sure the little filter isnt bloked with shit.
__________________
NORTHEAST/NORTH YORKSHIRE ALL FORD MEET ORGANISER pm for details.
Glenn. is offline   Reply With Quote
Old 21-12-2009, 10:51 PM   #5
the youth
Trader Score: (1)
the youth is an unknown quantity at this point
Send a message via MSN to the youth
Quote:
deffo sounds like the problem if you can hear the pump running
also the early mondeo's used a speedo cable still so I would suspect that that has snapped as it was starting to sieze the speedo would flicker.
steve
__________________
Mondeo ST TDCI and XR4x4 cosworth YB race car
NSSCC 2011 16th overall and 3rd in class B
Matt lewis motorsport supporting my racing in 2011
http://www.mattlewismotorsport.co.uk/
the youth is offline   Reply With Quote
Old 21-12-2009, 11:29 PM   #6
FordMondeoMk1
Trader Score: (0)
Thumbs up
steve
Curious then would this be a profesional job or would it be a fidly but able job for me to do, providing there where instructions, also, any ideas (if worse is to be) how much it would range to replace the Speedo cable if that is the suspect? i havent yet checked terminals in case of dirt or build up on both faults but now Xmas is here i have time to tinker wile the reletives are telling there life stories and the turkey is cooking! lol.
I have changed a washer pump on a Rover 200 (bubble/25/ZR shape) and involved unbolting the drivers wheel arch bumper bolts, a few under the bonnet leaver and pulling back the shit shield in the wheel arch, are mondeos just as obtainable or are they a... ... ... Ford!?!
Old 21-12-2009, 11:40 PM   #7
the youth
Trader Score: (1)
easy job really, just remove the speedo clocks(a few screws) then look at the top of the gearbox towards the bulkhead and you will see the cable undo the nut holding it on and then pull it out, remove the inlet damper for more access (the big black thing in you engine bay!)
also buy a haynes manual as with your basic skills it will help you no end
steve
__________________
Old 21-12-2009, 11:42 PM   #8
the youth
Trader Score: (1)
laso as for the washer pump, if you can hear it working and nothings coming out stick it on some ramps and then disconnect the wiring plug, then use a bigish screwdriver to prise it out, then move quick or you will get wet!
clean up the blck filter/seal then refit
steve
__________________
Old 22-12-2009, 12:06 AM   #9
FordMondeoMk1
Trader Score: (0)
Wink
brilliant i will try and have a butches over the next few days and follow up if i can whats goin on, but if any other advice can be given or things to watch out on Mondeo Mk1's please please let me know, it is the 1.8 lx Saloon
Many thanks Colin
Old 22-12-2009, 12:27 AM   #10
COLEYST200
COLEYST200's Avatar
Trader Score: (3)
COLEYST200 is an unknown quantity at this point
ian cole
getting the pipes back on the pump is a pane as they all ways seem to be on the short side . and dont forget the rubber L pipe is a one way pipe
__________________
Birmingham group
Click here to take a look at my three door project.
COLEYST200 is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Mondeo Problems... Help Please stemh Technical help Q & A 0 13-05-2009 01:51 PM
Mondeo 51 TD Problems mantamark Technical help Q & A 3 06-02-2009 08:59 PM
Mondeo Problems PhilM General Car Related Discussion. 11 04-12-2007 08:28 AM
mk2 mondeo problems webby80 Other Marques 5 25-03-2006 10:18 PM
Number plate problems.... JoeE30 General Car Related Discussion. 12 21-03-2006 10:27 PM
