PassionFord
Go Back   PassionFord > Main area > General Car Related Discussion.
Register Forgot Password?
Sponsored by Cartown
Click Here
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 14-12-2009, 09:40 PM   #1
Isaac.Hunt
Trader Score: (0)
Isaac.Hunt will become famous soon enough
Default Mondeo Turbo Diesel Cambelt Cover + Weird Cam Follower failure.
Car: 1.8TD MK2 Mondeo (Endura-DE engine)
Slightly weird question but I tried to remove the cambelt cover on my car tonight, I found two clips at the top of the cover which were prised off and also two bolts at the bottom of the cover (access by removing a plastic wheel arch guard). As far as I can see there are no other fixings but I'll be damned if the cam cover will budge ... it seems to be caught up near the fuel pump - am I missing something obvious like another bolt or is it just being awkward?
It was fairly dark when I was doing this so it may just be down to me missing the obvious!
On another note, the reason I am removing the cambelt cover is to remove the belt and camshaft. A few nights ago whilst pulling off the driveway and at very low revs the engine spluttered, made a very strange noise and stopped. I tried turning the engine over to restart but the starter couldn't turn the engine.
On further inspection it would appear that one of the cam followers has failed in that the walls that form the "bucket" section of the follower where the shim is held have broken away, effectively making the follower flat topped and allowing the shim to float around the head - in this case right under one of the cam lobes, meaning the engine can't turn.
Seems somewhat of an unusual mechanical failure, has anyone ever experienced this before?
Many Thanks
Isaac.Hunt is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Cambelt failure after 2 weeks off been changed by dealer RickyLee53 General Car Related Discussion. 18 01-09-2008 11:57 PM
Repeated cambelt failure - Vauxhall C20NE Cossiep General Car Related Discussion. 14 13-12-2007 12:14 AM
Alloy cambelt cover, turbo, manifold etc boost mad Ford RS Cosworth parts for sale 9 02-06-2007 05:12 PM
Warning to those with cambelt failure NMS Badboy^NUTTER^ General Car Related Discussion. 20 02-07-2006 08:29 PM
206 cambelt failure, Waht damage? Oranoco General Car Related Discussion. 8 28-09-2005 07:26 PM
