PassionFord
Go Back   PassionFord > Main area > General Car Related Discussion.
Register Forgot Password?
Sponsored by Cartown
Click Here
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 12-12-2009, 10:01 PM   #1
Mark RS
Mark RS's Avatar
Trader Score: (10)
Mark RS is an unknown quantity at this point
Default oil temp sensor
Were is the best place to put the stack sender to get the most accurate reading?in the sump or get a sandwitch plate for between the oil filter?
__________________
Thanks Mark
NORRIS MOTORSPORT 01773836274
Mark RS is offline   Reply With Quote
Old 13-12-2009, 10:17 AM   #2
Mark RS
Mark RS's Avatar
Trader Score: (10)
__________________
Thanks Mark
Old 13-12-2009, 02:48 PM   #3
Mark RS
Mark RS's Avatar
Trader Score: (10)
anyone?
__________________
Thanks Mark
Old 13-12-2009, 02:53 PM   #4
RichieST
RichieST's Avatar
Trader Score: (2)
RichieST is on a distinguished road
Send a message via MSN to RichieST
I think the most straightforward place to put it is in a sandwich plate. Or you can put a t-piece in the pressure switch hole but this might not be very accurate as its not really in the flow, so I would think in a sandwich plate would be best!
__________________
RichieST is online now   Reply With Quote
Old 13-12-2009, 02:58 PM   #5
Christian and Beccy
#1 in Spelling Club
Trader Score: (14)
Christian and Beccy is just really niceChristian and Beccy is just really niceChristian and Beccy is just really niceChristian and Beccy is just really nice
Send a message via MSN to Christian and Beccy
In the sump is without doubt the best place. Most people can't be arsed with doing this though so they take the lazy route and put it in a sandwich plate.
__________________
Renaultsport Megane F1 230
I've earnt £450 for doing almost nothing!! Click here to see how!!
Christian and Beccy is offline   Reply With Quote
Old 05-01-2010, 09:59 AM   #6
sjoyce666
Trader Score: (0)
sjoyce666 is an unknown quantity at this point
Send a message via MSN to sjoyce666
Quote:
Why is the sump a better place than the sandwich plate ?
Asking as I am looking to fit an oil temperature sender soon and was going to go for a sandwich plate
Scott
sjoyce666 is offline   Reply With Quote
Old 05-01-2010, 10:29 AM   #7
Spiky
Spiky's Avatar
Trader Score: (1)
Spiky is an unknown quantity at this point
Send a message via MSN to Spiky
SUMP
Spiky is offline   Reply With Quote
Old 06-01-2010, 02:25 PM   #8
Trader Score: (0)
tabetha will become famous soon enough
Just drill your sump plug to 11/32 and use a 1/8 NPT tap, then put it in the sump plug.
tabetha is offline   Reply With Quote
Old 06-01-2010, 03:42 PM   #9
Shredtheibanez
Trader Score: (0)
Shredtheibanez is on a distinguished road
Send a message via MSN to Shredtheibanez
I got my sandwich plate, £20.. Expensive..
Sump is probably better, but make sure your sender reachs in enough.
__________________
Captiva: "why oh why did they put the sender in first and then build the car around it!!"
Gotta love the 1991 1.3 HCS CARB ESCORT ENCORE! Next in line, a Capri restoration!
Shredtheibanez is offline   Reply With Quote
Old 06-01-2010, 04:00 PM   #10
sjoyce666
Trader Score: (0)
Why is the sump the best place though ?
Scott
Old 06-01-2010, 05:21 PM   #11
andy escos
Capt Chaos
andy escos's Avatar
Trader Score: (1)
andy escos is on a distinguished road
Quote:
Scott
because that is where your oil is stored in the engine before it gets sucked into the pump & sent around the engine to do its job of lubricating & cooling of the engines oily bits, so to get the best idea wether your oil is upto the job or being pushed past its working limits you should ideally have the sender in the sump ,but it is harder to do i.e. welding a bung in the sump to take probe or do what tabetha said & tap your sump plug
__________________
500+BHP 4X4 ZAKSPEED ESCORT GROUP 5 FULL RESTO, SOON TO LOOK LIKE THIS,,
TAKE A LOOK AT MY GROUP 5 ZAKSPEED ESCORT REPLICA RESTORATION
Clicky
andy escos is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Temp Sensor Cosmo Ford Sierra / Sapphire / RS500 Cosworth 7 08-09-2009 09:29 PM
Temp. sensor hispetdog Ford Escort RS Turbo 2 27-11-2008 10:49 AM
temp sensor orange van man Ford Escort RS Cosworth 0 13-01-2008 08:01 PM
digital water temp gauge, correct wire for temp sensor ????? 220TC Ford Escort RS Turbo 4 27-02-2005 02:30 PM
Oil temp sensor Speedy G. Technical help Q & A 0 09-07-2004 08:51 PM
