PassionFord
Go Back   PassionFord > Main area > General Car Related Discussion.
Register Forgot Password?
Sponsored by Cartown
Click Here
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 21-02-2010, 10:17 AM   #121
mark_24v_wiring
mark_24v_wiring's Avatar
Trader Score: (1)
mark_24v_wiring is an unknown quantity at this point
Send a message via MSN to mark_24v_wiring
Any chance of those voltage numbers please Tiff
mark_24v_wiring is offline   Reply With Quote
Old 21-02-2010, 11:46 AM   #122
TIFF
Chasing Radders
Trader Score: (0)
TIFF is an unknown quantity at this point
Send a message via MSN to TIFF
Sorry Mark.....my voltage tester is at work, thought it was here but it isnt......
__________________
BMW E39 530D SPORT..............
REMAPPED TO 230BHP AND 500NM TORQUE........
TIFF is offline   Reply With Quote
Old 21-02-2010, 05:12 PM   #123
mark_24v_wiring
Trader Score: (1)
Ok mate never mind no probs
Old 23-02-2010, 01:10 AM   #124
James
Trader Score: (0)
James is an unknown quantity at this point
Send a message via MSN to James
tiff, did you get my pm?
__________________
James is offline   Reply With Quote
Old 06-12-2011, 07:54 PM   #125
ni88les
Trader Score: (0)
ni88les is an unknown quantity at this point
Default I have the same problems - But where is my EGR Valve?
Hi everyone, I'm really hoping after reading this entire thread that someone out there will be able to help.
About 7 months ago I bought a 2.0 Mondeo 130bhp Tdci Ghia X and have had no end of problems with it since. Aswell as all sorts of problems related to steering my main issue was that the injectors all had to be replaced cos the car was going into limp mode all the time, which cost me a small fortune but now since then it's been great until recently when i've noticed a massive reduction in mpg and also performance. Now don't get me wrong, the performance has never been great, in fact I got the injectors all re-callobrated not long after having them done cos i thought it should have been better but now it's really terrible. At its best when the injectors were done i was getting 37 combined and 42 on the motorway when cruising at 70-80mph, I thought that was still pretty poor but now i'm lucky to get 32 combined and 36 on the motorway, and as I said before the performace of the car has dropped too, it just doesn't have the ooomph that it used to have.
After reading this article, I looked under the bonnet for the EGR valve in the location acording to the photo but I can't find mine there at all, in fact I've no idea where it is. I'm really hoping that firstly it actually has one (lol) but also, that it's that that's causing all of this and removing it and cleaning all the shit out will solve all my issues.
If anyone can offer any advice on this including where it actually is on my model that would be brilliant.
Thanks
Ni88les
ni88les is offline   Reply With Quote
Old 06-12-2011, 08:23 PM   #126
DanW@FastFord
Spelling Club King!
DanW@FastFord's Avatar
Trader Score: (1)
DanW@FastFord will become famous soon enoughDanW@FastFord will become famous soon enough
Thanks
Ni88les
On some of the earlier models the EGR is round the back of the engine, (to the right) and is much more of a pain to get at. It will look like this You can still blank them off (I'd imagine yours will be a Euro3 if it's got a rear EGR) so I'd definitely recommend doing that and seeing if that makes any difference.
Also change the fuel filter (ONLY use a Ford one) as that can also cause a surprising number of issues. A good service, if one's due wouldn't go amiss. But yours does seem particularly poor MPG wise. Does your rear bumper get sooty above the tailpipe? As that's a sure sign that your fuelling's not right.
Also, are you sure it's a 130, as I've only seen 115s with rear EGRs?
__________________
www.fastfordmag.co.uk
Try it, you might like it!
DanW@FastFord is offline   Reply With Quote
Old 06-12-2011, 08:52 PM   #127
dojj
Resident Wrestling Legend
dojj's Avatar
Trader Score: (3)
dojj is a jewel in the roughdojj is a jewel in the roughdojj is a jewel in the roughdojj is a jewel in the rough
the steering issue is down to a worn nut in the column, replaced with a torx bolt me thinks, but there are plenty of threads about them here somewhere too
dojj is offline   Reply With Quote
Old 06-12-2011, 09:55 PM   #128
Brian
Trader Score: (2)
Brian is an unknown quantity at this point
Quote:
What nuts that mate? only my ST steering is heavy when going left but is fine after a few miles
Brian
__________________
Brian is offline   Reply With Quote
Old 06-12-2011, 10:24 PM   #129
dojj
dojj's Avatar
Trader Score: (3)
Old 07-12-2011, 07:27 AM   #130
Brian
Trader Score: (2)
cheer's mate, have already greased the steering shaft but still the same am thinking now it could be the steering UJ? or possible the fluid?
Brian
Old 07-12-2011, 07:54 AM   #131
BRAMMER
GT Series baby!!!!!!!
BRAMMER's Avatar
Trader Score: (18)
BRAMMER is an unknown quantity at this point
RS Bram rs_brammer
My VW is suffering from loss in MPG right down to low 30's for short distance urban driving, not over bad but not as good as it should be for a chipped 115PD
Going to remove the EGR and see what it's like, if it's bad then i'll do the inlet too but unsure if it's worth blocking the ERG off as a couple of plates and job done but what effect does it have on the car running them blocked off?
BRAMMER is offline   Reply With Quote
Old 07-12-2011, 12:03 PM   #132
ni88les
Trader Score: (0)
Thanks for the advice... Actually, no i'm not 100% certain it's a 130, although when i first got it, prior to it having the injectors changed it was extremely responsive so I had no cause to think it wasn't. I havnen't seen any soot deposits around the rear bumper and there is no smoke (since the injectors were done). It probably could do with a service so I will ensure that the fuel filter is changed when I get that done. Funnily enough, the EGR valve was blanked off by the person who I bought the car off, when the injectors were replaced (G-Diesels in Hucknall) he un-blanked it.... I thought there could be bad repercussions of doing that?
Thanks again.
Old 07-12-2011, 12:10 PM   #133
DanW@FastFord
Spelling Club King!
Trader Score: (1)
No, there aren't really any downsides to blanking it, if you suspect it could be causing issues, then blanking it can rule it out.
I don't get great MPG on mine (average 36mpg) but most of my driving is along country lanes and in traffic.
If you PM me your numberplate I can check if it's a 115, or 130.
__________________
Old 07-12-2011, 12:41 PM   #134
saphcosmike
saphcosmike's Avatar
Trader Score: (0)
saphcosmike is an unknown quantity at this point
Quote:
Originally Posted by liarco2001 View Post
Hi mate i have a focus tdci 115 that is displayin similar symptoms. Was gettin 48 to 52 mpg then all of a sudden its dropped to between 37 and 43 no matter how i drive. What was it you did exactly? I know your engine will be slightly different to mine but any help would be greatly appreciated as i do nearly 3000 miles a month and its started costing me a fortune. Many thanks. Al
Mines the same, poor mpg, it used to do 50 - 55 I can't get above 50 now.
It's had full service.
The only fault is sometimes when you nail it it seems to hang back other times it just takes off!
It's a woory when you overtake something then it looses the boost and backs off.
No smoke though
saphcosmike is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
MK3 Mondeo 2.0 mpg ??? turbo_3dr_tommy General Car Related Discussion. 1 15-10-2009 04:15 PM
Mondeo mk3 tdci injectors RS500/364 General Car Related Discussion. 0 12-10-2009 02:22 PM
Problem with TDCI mk3 Mondeo rsjonny General Car Related Discussion. 15 30-09-2009 02:21 PM
Mondeo Mk3 TDCi Power steering Ridgey General Car Related Discussion. 1 22-05-2008 09:56 PM
mondeo mk3 tdci jaypjay General Car Related Discussion. 1 22-03-2008 04:18 PM
