rear pads on an 07 passat with electric handbrake
Old 02-12-2009, 04:02 PM
DangerousBryan
DangerousBryan's Avatar
Default rear pads on an 07 passat with electric handbrake
anyone done any? any knack or sequence to disable the handbrake ?
or do you need a special tool?
thanks
Old 02-12-2009, 04:04 PM
Mattie
Mattie's Avatar
You need to plug it in to wind back the pistons.
If you force them in manually, you will mess the calipers up mate
Old 02-12-2009, 04:44 PM
and i think you have to buy new calipers which i hear are about 500 quid
cheers james
Old 02-12-2009, 04:53 PM
Rossco
Rossco's Avatar
And risk losing your finger tips.
Old 02-12-2009, 05:34 PM
DangerousBryan
bugger. not worth it for one set of rear pads then. cheers all.
Old 02-12-2009, 06:50 PM
Miller 3
Miller 3's Avatar
use an angle grinder
Old 02-12-2009, 06:51 PM
andy130
andy130's Avatar
Old 02-12-2009, 06:53 PM
studabear
studabear's Avatar
Its possible to wind them back with a power probe, but this will not reset them and theres a chance you can end up with locked on rear brakes, diagnostic tool is best option
Old 03-12-2009, 09:34 PM
keith ambler
keith ambler's Avatar
hi mate you have to plug in diagnostic tool vw5052 or 5051b it then releases the motors
you can then push the pistons back in the normal way change the pads then go back to diagnostic tool this then winds the motors back up to the newly fitted pads im sur you can get aftermarket diagnostic tools to do it also regards keith vw master tech
Old 19-05-2010, 12:22 PM
DangerousBryan
a mate of mine is now doing some.lol. He has got the diagnostic tool and heard the motors wind in but he cant push the piston back in? does the piston push straight back like a front caliper or do you have to wind it back like a normal rear one?
Old 19-05-2010, 03:30 PM
Matt Baxter
Back in black!
Matt Baxter's Avatar
still wind the pistons back, all the diagnostic tool does is wind off the motors, he will also need to reset the motors after its all fitted back together
Old 19-05-2010, 04:25 PM
RichieST
RichieST's Avatar
What a load of modern car SHITE. While he's under there tell him to rip the fucking motors out, stick a cable on and put a lever on the other end. Job jobbed.
Old 19-05-2010, 05:30 PM
DangerousBryan
little update.he had to open the bleed nipples to wind the pistons back. there was no way they would go back without doing that. now it is all back together he has a long brake pedal like there is air in the system. he is going to try bleeding them to see if it improves.
yatta
21-05-2016 10:31 PM
Kam B
24-09-2015 10:40 AM
S3an
13
13-09-2015 10:01 AM
focus2351
09-09-2015 09:33 PM
cossirob
03-09-2015 09:17 PM
Quick Reply: rear pads on an 07 passat with electric handbrake
