PassionFord
Go Back   PassionFord > Main area > General Car Related Discussion.
Register Forgot Password?
Sponsored by Cartown
Click Here
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 20-11-2009, 10:52 PM   #1
steves24V's
steves24V's's Avatar
Trader Score: (7)
steves24V's is an unknown quantity at this point
Send a message via MSN to steves24V's
Question Help - non start mk 4 astra
Hi i'm hoping there is some vauxhall experts on here that can help me as i've seached the net and can't find any help,
I've just got a S reg mk 4 astra 1.6 8v the car has been sat for nearly 3 years and when i picked it up it had no battery on it,
well ive been trying to get it going but the fuel pump doesn't run (no earth to the relay) and it has no spark, thought it may have an immobiliser fault as its cut of both things
any help would be great, cheers steve.
__________________
B ^^^ RANGE ROVER P38 2.5 DSE ^^^^
steves24V's is offline   Reply With Quote
Old 20-11-2009, 10:54 PM   #2
Rossco
Rossco's Avatar
Trader Score: (0)
Rossco is an unknown quantity at this point
Send a message via MSN to Rossco
As its sat for so long maybe the key and the ECU arnt talking to each other, does the remote centrol locking work?
Rossco is offline   Reply With Quote
Old 20-11-2009, 10:59 PM   #3
carfixz
Trader Score: (0)
carfixz is an unknown quantity at this point
Send a message via MSN to carfixz
have you opened the key and replaced the battery in it? If you have then theres a good chance you have lost the transponder for the immobiliser, it usually sits inside the key
carfixz is offline   Reply With Quote
Old 20-11-2009, 11:12 PM   #4
steves24V's
Trader Score: (7)
The remote central locking is working fine,
Took the key apart tonight to check if the transponder was still there and it is,
getting stuck at this stage was hoping to get it going this weekend.
__________________
Old 20-11-2009, 11:40 PM   #5
Rossco
Rossco's Avatar
Trader Score: (0)
Have you tried plugging a fault reader in, just a warning though Vauxhalls are very picky on which readers they let read them though.
Old 20-11-2009, 11:45 PM   #6
Ginge
www.virtualseason.net
Ginge's Avatar
Trader Score: (0)
Ginge is on a distinguished road
Oldsevlow Bowlbag
Send a message via MSN to Ginge
__________________
Quote:
Originally Posted by RS Grant
I'm sure if someone shaved their head, wore a shirt with flames on it and booked under the name "Chip" then they'd be in for a right angry fuck.
Ginge is offline   Reply With Quote
Old 21-11-2009, 12:00 AM   #7
Rossco
Rossco's Avatar
Trader Score: (0)
Didnt know the good old hair clip still worked on more modern Vauxhalls.
Old 21-11-2009, 12:35 AM   #8
steves24V's
Trader Score: (7)
I'll try getting the code reader from work tomorrow and see what that shows up. The thing is when I first got it home I gave it a crank over and didn't start so thought I'd listen for the fuel pump and I'm sure it was going, so I put it down to bad fuel but when I went to try it with fresh fuel it didn't run so I looked a bit further.
__________________
Old 08-03-2010, 06:19 PM   #9
steves24V's
Trader Score: (7)
Hi again i've still not got this going, not that i've spent much time on it over last few months due to a new born baby.
right the fault code was 1231 and said fuel pump primary circuit high what ever thats ment be be.
Any idea's passionforder's i just want this gone so i can get my new project.
__________________
Old 08-03-2010, 06:21 PM   #10
RichieST
RichieST's Avatar
Trader Score: (2)
RichieST is on a distinguished road
Send a message via MSN to RichieST
My old focus had that fault code. It needed a new pump. Maybe where its been sat for so long the pump had siezed? Try giving it a clout with a hammer to see if it will unstick!
__________________
RichieST is offline   Reply With Quote
Old 08-03-2010, 06:29 PM   #11
steves24V's
Trader Score: (7)
Fuel pump work's fine and looks good pressure as i took the pipe off the spi unit and linked the fuel pump reply and fuel came out.
__________________
Old 08-03-2010, 06:31 PM   #12
RichieST
RichieST's Avatar
Trader Score: (2)
Does a quick spurt of fuel come out when you turn the ignition on? If not then could be a knackered relay?
__________________
Old 08-03-2010, 06:38 PM   #13
steves24V's
Trader Score: (7)
no fuel pump doesnt purge at all, fuel pump relay seems for work ok, but not sure if there is another relay thats not working like a ignition relay as i dont have a spark,
been told that the engine management flashes like mad if its the immobiliser and it dont so getting stuck.
__________________
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
mk4 astra van engine manigment light flashing and won't start? diesel Technical help Q & A 6 31-12-2008 05:09 PM
2004 astra diesel fuel filter change prob-wont start Steve F Technical help Q & A 1 07-06-2008 01:51 PM
Anyone know about kxf 250 - wont start, where to start ? PeterLucas Motorcycle chat and sales 14 23-01-2008 02:29 PM
using easy start to start an rs turbo!!! fordsportjay General Car Related Discussion. 13 02-10-2006 06:05 PM
Pain to start my hot RS. Having Cold start valve plugged in. L33 BYT Ford Escort RS Turbo 2 30-09-2003 06:48 PM
