| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| General Car Related Discussion. To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Sponsored by Cartown |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
My Cossie Ate My Money
__________________
![]() I WANT ANOTHER COSSIE! Self Proclaimed King Of The Shot Peeners Xbox Live Gamertag: HeavyDarka |
#2 |
Pics of the pump?? Bosch one is easier to do, it has the boost compensator on the top of the pump.
#3 |
My Bosch pump is set at 1.25 turns IN of the max fuel screw and 2.5 turns OUT of the boost compensator. Boosting 18psi. Any more and the charge temps soon get up and it gets sluggish. They come with a Garret T2, a KKK turbo and Im sure the later ones are something like a T15 for improved response. Check to make sure its boosting properly as standard first 13psi.
#4 |
the pump doesnt have the viewing window thing on the front so its a bosch
__________________
#5 |
we have seen 14/15psi in 3rd on the boost gauge
__________________
#6 |
#7 |
in 3rd at 3k rpm is where to check its boost.
Bosch pump is easy to do then. Happy days. |
#8 |
wanted to run 20 or 22psi but it seems like the charge temps will be abit on the warm side lol it is cold atm tho lol
__________________
#9 |
My actuator rod is wound in 3.5 turns. I was seeing around 14psi standard too.
Let us know how you get on fella |
#10 |
__________________
#11 |
Ha ha ha, I love my ZX's. Comfy as fook and if you stick a set of half decent rubber on them they do actually go round corners ok. My last one had 15" Saxo VTS rims on and 195/50 15 T1-R's on and it surprised me. The one I have now has standard wheels on 185/60 14 Admiral ditch finders on. Its horrendous in the wet, spins up in 3rd with a knackered clutch
#12 |
__________________
#13 |
Zetec locost driver
omg are we the three citroen ZX TD owners
i have the bosch pump too but want to fit a boost guage before i start messing with it just waiting on a real cheapie to turn up how many dash bulbs u got out? i had a look at changing them bitch of a job as you can't get your hand behind to disconnect the speedo cable from the instrument panel, after some investigation seems you have to take the drivers side heat vent tubing out of the way then u can get to the cable, might have another go at the weekend. gotta love the 50mpg though
__________________
![]() I drive a citroen |
#14 |
were at the unit now having a look, its developed a massive oil leak which we are trying to get to the bottom of, any ideas of what can commonly go?
and yes the left hand side of the dash lights dont work lol
__________________
#15 |
Zetec locost driver
oh oil leak sounds bad, still driving ok?
where abouts is the leak
__________________
#16 |
leaks at the back of the engine quite low down we think, its pissing out but e cant see where from lol
__________________
#17 |
we-hay! c'mon the zx crew!
how many rotton sfrut tops we got!!! had mine nearly a year and driven HARD pretty much every day!
__________________
..........special |
#18 |
Zetec locost driver
goes out to check strut tops.............................
__________________
#19 | |
Quote:
#20 |
PF's PFer
Omg. I never thought I'd see a Citroen ZX appreciation thread on PF. I had one as my first car, wrote it off, and then bought another one straight away. Pretty underrated cars, all the body roll in the world but more grip than you'd imagine and comfy as you like. Later I had a BX Turbodiesel, which was more of the same - only weighed around 900kg so was pretty nimble and, while I could never call it quick, it wasn't slow either!
#21 |
Zetec locost driver
was looking at the airfilter arrangement today and that looks horribly restrictive and also mounted very low
sure there is free power there
__________________
#22 |
14.7 1/4mile in a 306Diesel aint to be sniffed at.
__________________
![]() Der King Ist back |
#23 |
We managed to get it back home but it doesnt look to good for the ZX
![]() We didnt bother turning the boost up as the oil is absolutly pouring out when the engine is running how it got us back from MK i will never know lol
__________________
#24 |
no rotten strut tops or dash bulbs out here
![]() the floor however isnt as solid, and only one rear caliper works ![]()
#25 |
RE the airbox, mine has been removed, hacked the solid plastic pipe off just before the bend and rammed a filter on. It didnt seem to spool up as fast when I first did it but after hacking the pipe I had crossed the point of no return so have had to live with it. Also dont go hurtling through puddles if you put a filter on it, I forgot, it sucked in loads of water and it was belching masses of white smoke for about 1/4 mile and was flat as a fart.
#26 |
Zetec locost driver
i confirmed during my lunch hour mines completley standard (bosch pump still has tamper proof seal)
So this weekend i will be rigging up a boost gauge then having a play with the pump ![]() the airbox there are induction kits on ebay cheap for the petrol models maybe they can be modded but this is pikey modding so need something cheaper or free ![]() and my strut tops look rust free only one small patch of rust on the floor where the underseal has flaked off and even thats only surface rust. has anyone tried pug 205 wheels on a ZX? i think they will fit
__________________
![]() I drive a citroen Last edited by dlatch; 10-11-2009 at 08:49 PM. |
#27 |
Sure Ive seen 205 Gti wheels on a ZX before. No reason why they wont fit.
#28 |
Wanted to put a front mount on mine but where the intercooler mounts to the inlet would be a problem. Any ideas?? I have a Focus TD cooler, which is a common one to use Im told, and a one from a Megane 225 Trophy.
#29 |
Zetec locost driver
Ern
not hadt he standard cooler off so no idea on fitting a front mount sorry, i am guessing it will be a pain in the ass though
__________________
#30 |
Hmmmmm maybe Ill whip the cooler off at the weekend and see what can be done.
#31 |
Out of curiosity.... What does the tamper seal look like??
As mine is running 17psi.... And I have no idea if the Pump has been tweaked? Adam |
#32 |
On the bosch pump its a little metal ring around the max fuel screw.
#33 |
i Have one of these bad boys (ZX) Had it about 5years plus now as a run about ,only problem is its not a td
Just the standard 1.9d , My Heater control lights have been gone for ages never got round to sorting them as it looks abit of a pain to do...
__________________
#34 |
ZX XUD common oil leaks are,
Leaking vac pump o rings, cam cover loose, cam cover breather pipe split. Also when doing dash bulbs, disconnect speedo cable from inside engine bay and push cable through once youve loosened speedo head, much easier than trying to undo from back of head. |
#35 |
sourced a spare boost guage 2day so will have a play once its had a little service, not been done in the last year/16k!
just get in and drive! awsome! lucky gits with solid strut tops, both mine have been repaird! post some pics!!!! i will 2mo if i gets chance!
__________________
..........special |
#36 |
i dont know about these but i did a set of heater plugs on a xantia (assuming same engine) and they were a fucking pain in the arse, the worst bit was tryign to get the 8m nut on the new one behind the injector pump, my arms are hurtign from tryign to twist my hand to do it
__________________
#37 | |
Zetec locost driver
Quote:
but will try that method out ![]() is there anyway to check the bulkhead for rust do they rust honest if you know what i mean only issue i have is a badly aligned drivers door might have had a bump there at some point but i was looking at the hinges and it looks tricky to adjust anyone done them before?
__________________
#38 | |
Quote:
You cannot adjust the door hinges, there is a small screw in each hinge to take any wear play out. If door has strained on hinges use weight either top or botton to strain back!!! Oh and you maybe lucky when doing the dash bulbs, some of them had electronic speedo drives so no cable. Bulkheads dont normally rust, but remove wiper scuttle panal and check the main wiring connector on the drivers side bulkhead panal as these are prone for corrosion in the connectors! Make sure the water drains are clear aswell, each side. |
#39 |
Zetec locost driver
bouncy
yeah mine has mechanical speedo so will try the disconnect engine end to sort them bulbs was looking at hinges today and the top hinge where it bolts inside the door has two 10mm studs with nuts was wondering if i loosen them it would give me some adjustment i only need to move it a couple of mm its not that far out, with the door closed its the top left corner that needs to come down. need to remove scuttle panel to run boost guage piping so will give it a clean up then and check the drain holes too
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Tuning endura de lol.......... | dannyblackpool | General Car Related Discussion. | 2 | 15-07-2008 06:49 AM |
| Freeview tuning, help please lol | Charlie Chalk | General Car Related Discussion. | 4 | 07-04-2008 09:28 PM |
| 306 d turbo | OvaBoost | Cars & Parts Wanted. | 0 | 25-07-2007 10:05 PM |
| PUG 306 TUNING | Adam1 | General Car Related Discussion. | 8 | 23-03-2006 12:48 AM |
| 306 Turbo Derv | JimmyBoy | General Car Related Discussion. | 6 | 27-01-2006 06:21 PM |
