PassionFord
Go Back   PassionFord > Main area > General Car Related Discussion.
Register Forgot Password?
Sponsored by Cartown
Click Here
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 31-10-2009, 06:10 PM   #1
bigcam
Trader Score: (0)
bigcam is an unknown quantity at this point
Default mondeo clutch
hello can anyone give me some advice.. iv got a mk3 2000. x reg tddi mondeo, it has just started vibrating and jolting the clutch pedal, its also making a knocking noise now.. iv have been told its got a dual mass flywheel if thats correct, because i havnt got a clue what one of them is, is it possible the clutch has gone or is it the flywheel.. can it all be changed for a standard flywheel and clutch. any advice i would appritiate. shaun...
bigcam is offline   Reply With Quote
Old 31-10-2009, 06:41 PM   #2
Burnzybubbles
Bubbles
Burnzybubbles's Avatar
Trader Score: (0)
Burnzybubbles is on a distinguished road
yea i'm pretty sure it's a dual mass jobbie, i can't remem what there all about google it and you'll find what the crack is with them, i don't reckon you can have them changed over unless you changed the box too cos i can imagine the slave cylinder will be in the right position for the DMF, i'm not 100% on this knowledge but it's a start
__________________
mk5 esco dead
Burnzybubbles is offline   Reply With Quote
Old 31-10-2009, 09:45 PM   #3
bigcam
Trader Score: (0)
thanks very much i will google it and see if i can find out more.. i dont want to be spending 500 pound on clutch when thats all i paid for car..
Old 31-10-2009, 11:20 PM   #4
dojj
Resident Wrestling Legend
dojj's Avatar
Trader Score: (3)
dojj is a jewel in the roughdojj is a jewel in the roughdojj is a jewel in the roughdojj is a jewel in the rough
lots of money, you need to change the dmf as ell as the clutch
you can get a solid replacement, i knwo that ginge used to do them but he's stoppped posting, even though he's still aorund
dojj is offline   Reply With Quote
Old 01-11-2009, 12:23 AM   #5
st3v3
Trader Score: (0)
st3v3 is an unknown quantity at this point
duel mass flywheel plus clutch will all need to be changed.
The knocking for sure is the DMF, i had this exact problem 18 month ago, eventually it could screw up the started motor aswell, as all the iron filings get in to it and fook it up good and propper, although a good clean out now might save it, as it did mine.
You can get solid one piece flywheels now but im unsure where from, but there is a company doing them, just cant think who (too much beer) without changing the gear box either.
My 3 piece clutch from Ford including fly wheel was £327.28 (discounted by my mate) getting it fitted was the bit that hurt, whilst youre there, i would get the rear crank shaft pulley seal replaced, about £2.00 from ford as they start to weep at some point and if you leave it and it does, then its all gotta come out again(£££)
The fitting on mine cost me another £400 but with that i got a full warrantee on ALL parts and i knew i was paying over the odds but the garrantee was a good one, so if the slave cylinder went not only would i be coverd by Ford but the mechanic would cover his work for something i bought, so it did seem worthwhile, as even with Ford parts some DMF can go inside 12 months.
Another issue is that whoever does the job re-alines the front subframe that has to come out, if they havent done this right, the car will drive like a dog.
One tip for you- get it done sooner than later, if only to save the stater motor.
__________________
cheers
steve.
"Everyone is a Genius,But if you judge a fish by it's ability to climb a tree-It will live it's whole life thinking it's stupid"-A.Einstein
st3v3 is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
mk2 mondeo clutch change Burnzybubbles General Car Related Discussion. 24 26-07-2009 04:15 PM
mk mondeo clutch change :s Burnzybubbles Technical help Q & A 0 10-07-2009 01:34 PM
question about mondeo clutch lammylama General Car Related Discussion. 6 12-05-2007 04:36 PM
Mondeo Flywheel and clutch on a fiesta? Sunil_FiestaRS1800 General Car Related Discussion. 12 15-03-2006 09:33 AM
mondeo clutch cable replacement 1.8 td nthorpey Technical help Q & A 0 09-01-2004 07:36 AM
