| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| General Car Related Discussion. To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Sponsored by Cartown |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
#2 |
what oil you using not 5w-30 or 5w-40 are ya?
__________________
![]() 416.1bhp STORMTROOPER I am the real doug! |
#3 |
was on 10 40 for running in but it was like piss so i ditched it and went back to my regular 15 60 which i know ppl are going to have varying opinions on so soon after a rebuild but it's what i've used for years without trouble and wanted to illiminate the thin oil from being the cause of the tapping.
#4 |
![]() BANNED |
Did you check the oil galleries when doing the tappets, does it sound like a rear one/s tapping, esp on exhaust side ?
tabetha |
#5 |
it's front inlet side, used the old screw driver to the ear method and it's loudest on the inlet manifold on 1 and 2
#6 |
i just had similar problem,put new tappets in and it was still noisy and didnt clear even after 130 miles,turned out to be a blockage...i took the bungs out of the head and cleared it thru with a gallery brush,loads of sludgey shit came out..put it back together and it is spot on.i also put the genuine tappets back in as the pattern ones i bought were faulty and 3 fell apart.
hope this is of some help. james |
#7 |
grayzo
out of interest are the cams old and the tappets new if so cam could be worn a bit causing a bit of tap
#8 |
inlet cam is new and the complete head has just been overhauled by cylinder head developments so i would hope there's no major shit issues in there but i do have to wonder if there is maybe a bit of swarf just restricting things a bit.
#9 |
back up for the morning crew to have a look at.
#10 |
#11 |
Football Cwazy
Did you use genuine followers? or the cheaper alternatives?
I would say that you have an oil supply problem, but whether thats due to poor pressure, blocked oilways i dunno.
__________________
Martin ^^^Invisible Pic of BMW M5^^^^^^^^^ EVO GONE!! M5 POWER ALL THE WAYYYYYY! Chipipedia - Knows EVERYTHING. |
#12 |
they're ina followers so shouldn't be a quality problem. Oil pressure is cock on, 82psi on start up, 34psi hot idle and when driving sits between 65 and 80psi
#13 |
Football Cwazy
oil pressure sounds pretty good then, but obviously it doesn't mean that the supply up to the head is adequate.
I seem to remember a batch of INA followers being sold on the cheap that were actually VW golf or some other fitment. I got mine from Karl Norris for about Ł100 from memory, may have been slightly more. Its hard to say exactly what you're problem is, but i'd definitely be tempted to take it to a specialist to check it, as oil supply problems could prove mega costly!
__________________
#14 |
YOREVOL
are you sure its tappets? sounds similar to little end.
#15 |
Trader Score: (1)
Rep Power: 33 ![]() |
When i first start my cossie you it quiet as a mouse then about 10 mins later they start to tap.After about 5 mins they go quiet.
__________________
![]() NORTHEAST/NORTH YORKSHIRE ALL FORD MEET ORGANISER pm for details. |
#16 |
definately tappets as when i fitted the new set they were silent til i turned off and left it stood for a hour or so then tappy again.
#17 |
so working on the theory of it being swarf in the oil way, short of taking the head back off what are my options?
#18 |
Strip out the cams and lifters. Turn the oil pump over by hand over and over again. You should be able to see the oil come up through each oil way. It should start from the N/S/F and work towards the O/S/R with the rear exhaust side being last to be fed. Check this and get back to us.
__________________
#19 |
my fully re-built head took about 400 miles in total before the lifters were fully quite!
__________________
#20 |
thanks for that, will give it a go.
#21 |
but did the noise come and go? That's what's getting me, when it's driven it shuts up then when it's at idle it comes back.
#22 |
__________________
#23 |
well i'm now using a 15 60 which has helped the noise no end, it's 10 times quieter than it was but still there. think i'm gonna put another hundred or so miles on it and see what happens. there's not a massive lack of oil supply in the head as it's perfectly visable to see it all sloshing around if you take the oil filler cap off.
#24 | |
Quote:
get it run in m8
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| cossie noisy tappets after rebuild - could it be the oil? | john_p_b | General Car Related Discussion. | 4 | 03-09-2009 12:57 PM |
| Mondeo 1.8td noisy tappets | Matt-G | Technical help Q & A | 2 | 21-08-2009 08:44 AM |
| Noisy tappets after high revs | rapidcossie | General Car Related Discussion. | 30 | 22-07-2008 10:52 PM |
| s2 noisy tappets. due to low oil pressure? | skeld | Technical help Q & A | 4 | 09-08-2005 09:48 AM |
| Noisy Cossie Tappets on start up... | Just on Boost | Technical help Q & A | 2 | 23-07-2005 06:14 PM |
