PassionFord
Go Back   PassionFord > Main area > General Car Related Discussion.
Register Forgot Password?
Sponsored by Cartown
Click Here
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 23-09-2009, 07:36 PM   #1
Burnzybubbles
Bubbles
Burnzybubbles's Avatar
Trader Score: (0)
Burnzybubbles is on a distinguished road
Default airbag light flashing problem on my mondy mk2 :-(
to make things worse my net is broken so can't stay on here for long, went out for a bit of a drive and in the middle of it the airbag light started flashing , anyone have any idea of what it could be could help alot thankyou i don't want airbag in face whilst travelling my 4 hour commute atm .
cheers people
__________________
mk5 esco dead
Burnzybubbles is offline   Reply With Quote
Old 23-09-2009, 07:40 PM   #2
steves24V's
steves24V's's Avatar
Trader Score: (7)
steves24V's is an unknown quantity at this point
Send a message via MSN to steves24V's
it will flash in a code prob 4 flashes then a gap then repeat it over and over. If it does do 4 it will be a seat belt pretentioner.
__________________
B ^^^ RANGE ROVER P38 2.5 DSE ^^^^
steves24V's is offline   Reply With Quote
Old 23-09-2009, 07:43 PM   #3
Burnzybubbles
Bubbles
Trader Score: (0)
na it seem to flash once then take a while to flash again but i'll have a look have you or anyone got the codes to check just incase cheers
__________________
mk5 esco dead
Old 23-09-2009, 08:31 PM   #4
st3v3
Trader Score: (0)
st3v3 is an unknown quantity at this point
The airbag warning light should come on with the ignition and remain lit for 5 seconds. After this period it should go out and not illuminate again until next time the ignition is turned on. If the light fails to come on then check the fuse for the system and then the bulb in the instrument cluster. If a problem is detected with the system then it will be indicated by a number of flashes. If more the one code is detected the system will assign priority and display the most important first.
Flashes Problem
1 Drivers airbag failure
2 Passengers airbag failure
3 Failure of both airbag units
4 Pyrotechnic seatbelt pretensioner failure (Either side)
> Common Fault - Further details below
5 Drivers airbag failure - System shorted
6 Passengers airbag failure - System shorted
7 Drivers crash sensor failure
8 Passengers crash sensor failure
Common Fault:
The airbag warning light flashing 4 times is a common fault on late Mk1 and all Mk2 mondeo's using the pyrotechnic pretensioners - especially if you have recently moved the position of one of the front seats. Turn the igntion off and allow the car to sit for 15 minutes. Underneath the front seat base, (access is best from the rear passenger footwells, with front seats furthest forward), you will find two cables wrapped in yellow sleeving. The yellow connector may have parted company with its other half - Even if it hasn't disconnect and reconnect it to ensure that it is secure. Move on to the passenger side and check the wiring there - whilst doing this ensure the cabling is slack and not badly routed resulting in it being pulled tight
__________________
cheers
steve.
"Everyone is a Genius,But if you judge a fish by it's ability to climb a tree-It will live it's whole life thinking it's stupid"-A.Einstein
st3v3 is offline   Reply With Quote
Old 23-09-2009, 09:09 PM   #5
Burnzybubbles
Bubbles
Trader Score: (0)
thankyou very much mate just what i needed i'll go check later or tmoz night, the light deffo comes back on i'll see how many flashes it has.
thanks again anyway gutted i can't stay on here longer but like arnorld say's "i'll be back"
__________________
mk5 esco dead
Old 23-09-2009, 09:16 PM   #6
PhilM
PassionBMW.com Member
Trader Score: (0)
PhilM is an unknown quantity at this point
Send a message via ICQ to PhilM Send a message via MSN to PhilM
Usually the connectors for the pretensioners under drivers/pax seats. Unplug, contact clean and remake - see how that goes.
__________________
SECS S8 - 2.1 16v Zetec Turbo
PhilM is offline   Reply With Quote
Old 02-10-2009, 05:13 PM   #7
Burnzybubbles
Bubbles
Trader Score: (0)
ok update, it was only a single flash for the airbag light and i noticed my horn stopped working too, now traveling to london everyday i need my horn for warning drivers that can't drive (there is many).
checked the connectors at horn and also sprayed it with WD and put another relay in the fuse box still no joy, so took the steering wheel out to look at the ring that takes the power from the colum to steering wheel and the connections inside it have snapped off looks like someone has been inside it for some reason and not put it back together properly afterwards, so trip to the scrappers in the morn to get another even more annoying i'v just come from there , i'll get piccies up when i have my net working on the desktop.
__________________
mk5 esco dead
Old 02-10-2009, 06:08 PM   #8
RichieST
RichieST's Avatar
Trader Score: (2)
RichieST is on a distinguished road
Send a message via MSN to RichieST
Its called a clockspring, they do fail often on focus's too! Cheap enough from ford
http://shop.ebay.co.uk/i.html?_nkw=c...ring&_osacat=0
Here's some random ones just to give you a rough idea of what to pay!
__________________
RichieST is offline   Reply With Quote
Old 05-10-2009, 10:55 PM   #9
Burnzybubbles
Bubbles
Trader Score: (0)
sorry rich my net is still down so hardly getting chance to go on atm, but cheer''s for the link and that makess me feel a bit better cos grabbed one from the scrappers for a tenner and thought i'd been overcharged slightly, all sorted now though, happy bunny again cos working in london and it's a neccesity when people aim for you
__________________
mk5 esco dead
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
why is my airbag light flashing on my m reg mk6 escort Badboybulldog Technical help Q & A 9 04-08-2009 10:19 AM
airbag light flashing ( t25 ) cosworth3d Ford Escort RS Cosworth 2 23-04-2008 09:23 PM
airbag light flashing on mk 2 mondeo littleknocks General Car Related Discussion. 2 18-11-2007 05:11 PM
Airbag light flashing Andy E Ford Escort RS Cosworth 7 23-01-2007 11:37 PM
97R 1.3 Fiesta airbag light flashing??? Len_Beach Technical help Q & A 2 13-09-2005 05:33 PM
