| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| General Car Related Discussion. To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Sponsored by Cartown |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
#2 |
the bracket bolts to the sump, and i bet you are running a shity 1.8 fez sump with no mounting points for it ? Cant het any pics till i get home
#3 |
Yes mate I am running a shitty 1.8 sump, but its all baffled and has take offs and returns welded all over it for different things, so I need to keep it.
Pics would be great if you dont mind. I could get something welded to the sump to carry the focus bracket if need be! I presume you are talking about the focus bracket? I have been led to believe the focus set up is smaller and stronger than the mondeo one, do you happen to know if thats true? |
#4 |
am pretty sure quaife do an exual length driveshaft extension bar thingy.
__________________
MY S2 RESTO PROJECT http://passionford.com/forum/restora...2-10-09-a.html NEED A WELDER IN PLYMOUTH!!HELP |
#5 |
I am using equal length shafts, on a MTX from a RS2000 with a Zetec turbo silvertop block, but I bought the box with everyhting already done. My 3rd driveshaft bracket bolts to the block though, not the sump?
Havent got pics at the minute as their being all rebuilt with new CV joints at my mates.
__________________
1968 Mk2 Cortina - Zetec turbo - 329bhp at 14psi so far... Classic Fords FTW! |
#6 | |
Quote:
I assume thats the mondeo one you have then, I will probably end up using the mondeo bracket just cut and shut to work correctly. Could you tell me if the bracket you are using looks like a factory supplied unit or something sombody has made up/adapted themselves? At least then I will now ther IS a bracket out there that will work! I must also admit I havnt actually lined this up on the car yet I plan to do this work at the weekned, but a lad I know who has exactly the same parts as me cant get it to work! So I am assuming (with out seeing) that I will have the same problem. |
#7 |
#8 |
Mine uses the Focus setup bolted straight to the 2 litre sump.
I'd suggest you simply swap the sump, and reweld your breather connections etc rather than welding/fabricating a bracket
__________________
Bespoke calibration and remapping, OEM & Aftermarket management
#9 | |
Quote:
#10 |
Got any pics of your crazycage?
Mine looks factory?
__________________
#11 |
Both mine and crazy's look factory - cos they are lol... We use proper sumps
__________________
#12 |
__________________
#13 |
Lukesville
You will find the Mondeo have a bracket that mounts onto the block.
As for the mount itself its in 2 half moon shapes the cast steel part which mounts to block or sump on whichever variant is avaialble new from Ford at £19.99. So you just need to pop there and buy one, saves pissing around in a scrap yard. Just give them the reg of the car the gearbox is out of. Then adapt the block bracket to fit. Ka cars also have this same mount that bolts to block but the bearing is much smaller that sits in it. Just need to make sure the half shaft you have is matched with the bracket then either make a drop bracket or if lucky it will mount straight up!.
__________________
Built @ JKM Performance - NEW SPEC 471.9 bhp ![]() thetrolley +500hp/ton - 134mph over 1/4 mile April 2011 - 11.74 @ 129.15mph |
#14 |
luca is right the mondeo one does mount to the block,the focus one mounts to the sump.
#15 |
ive got an mtx out of a mk6 escort cab. Im using a silvertop mondeo block and an equal length shaft setup off the mondeo.Its meant to bolt onto the block, but for some strange reason its like the escort mtx is different because the bracket on the shaft sits about and inch to high, and is no where near close to the mounting holes on the block?????????
anyone got any ideas? |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Equal length drive shafts on FWD fords | Johnny Knoxville | General Car Related Discussion. | 44 | 16-08-2010 06:12 PM |
| equal length drive shafts - | Luca | General Car Related Discussion. | 11 | 23-05-2008 01:16 PM |
| equal length drive shafts | jonesymk2 | General Car Related Discussion. | 22 | 21-01-2008 03:39 PM |
| Custom Turbo Equal Length Manifold Ramhorn | monkian | Technical help Q & A | 1 | 13-10-2006 04:24 PM |
| Equal length DRIVESHAFTS!!!!!!!!!!!!!! | FULLBORE | Technical help Q & A | 1 | 21-05-2006 12:02 PM |
