PassionFord
Go Back   PassionFord > Main area > General Car Related Discussion.
Register Forgot Password?
Sponsored by Cartown
Click Here
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 21-09-2009, 12:18 PM   #1
bigbill
Trader Score: (0)
bigbill is an unknown quantity at this point
Default Can you re-use standard head bolts on a 2wd cossie?
As above really or do I need new ones? If so where is the best (cheapest!) place to get them? Also what is the best torqueing sequence?
cheers
bigbill is offline   Reply With Quote
Old 21-09-2009, 12:22 PM   #2
Twellsie
Twellsie's Avatar
Trader Score: (1)
Twellsie is an unknown quantity at this point
no you cant re-use them as they stretch
__________________
Twellsie is offline   Reply With Quote
Old 21-09-2009, 12:28 PM   #3
bigbill
Trader Score: (0)
Cheers. Where is the best place to get new ones? Im not hearing good things about ARPs!
Old 21-09-2009, 12:40 PM   #4
Trader Score: (0)
tabetha will become famous soon enough
Loads of places sell these ford or pattern ones will be fine, don't re-use.
ARP are fine if certain precautions are taken, though they work better with fibrous gaskets than steel.
tabetha is offline   Reply With Quote
Old 21-09-2009, 04:01 PM   #5
costina
Mike and Keith Rock!!
costina's Avatar
Trader Score: (1)
Location: In the Garage..Drives 2wd saff cosworth powered by MSD and cortina cosworth undergoing full resto!!
costina is an unknown quantity at this point
And NOT with a 205 block as they crack
Matt Lewis
woodford
Paul
__________________
Powered by M.S.Dclosed loop,coilpacked etc etc
Built by me
costina is offline   Reply With Quote
Old 21-09-2009, 04:04 PM   #6
cossie4i_
TT T38 Power
Trader Score: (11)
cossie4i_ is an unknown quantity at this point
Send a message via MSN to cossie4i_
Just got a new set from PJ Motorsport and they was half the price of everybody else.
Steve
__________________
TT T38, AB07 Cam, Ported Head, Hart Inlet, Spec-R intercooler, Air Injectors, Gripper Diff , Turbosystems Mapped.
cossie4i_ is online now   Reply With Quote
Old 21-09-2009, 04:14 PM   #7
pacwest
Puller of the Wrench
pacwest's Avatar
Trader Score: (0)
pacwest is on a distinguished road
Quote:
Matt Lewis
woodford
Paul
Let's hear some more on this. What head bolts should we be using for up to stage III? Or is the ARP stud kit the way to go on a 205?
__________________
1988 Sapphire 2WD - 1985 Merkur XR4Ti.
http://jasonhollister.com
Breaking a 2wd saff? Click here to see my wish list
pacwest is offline   Reply With Quote
Old 21-09-2009, 05:39 PM   #8
Trader Score: (0)
I've used ARP on well over 30 205 blocks, not a crack in sight.
Any problems are normally due to the fastener(ARP) bottoming out due to being a tad too long, which I must admit I have found more than once, I always measure hole depth.
If they bottom out further tightening can indeed crack the block, it's sort of and sort of not the fault of the arp, depends how you look at it.
Ideally if ARP made them say 5mm shorter it would be ideal.
I've also used these in 202 blocks.
Old 21-09-2009, 06:51 PM   #9
RWD_cossie_wil
RWD_cossie_wil's Avatar
Trader Score: (8)
RWD_cossie_wil is an unknown quantity at this point
Send a message via MSN to RWD_cossie_wil
Why use £130 of ARP block crackers when the standard £30 headbolts are a lot better, or you can get proper mountune WRC long studs for under £300? Just isn't an option in my opinion, why save a few quid on doing the job properly and risk a 4k+ engine?
__________________
Quote:
Originally Posted by Lambchop View Post
Jim, does Swiss semen taste any different to Mr Rbird's?
WANTED- 2WD AND 4X4 BROKEN/ CHEAP REAR DIFFS, CASH WAITING!! PM ME!
RWD_cossie_wil is offline   Reply With Quote
Old 23-09-2009, 05:25 PM   #10
costina
costina's Avatar
Trader Score: (1)
Quote:
Wise words
will dig the pic out soon
Paul
__________________
Built by me
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
arp or standard head bolts PAZ Ford Sierra / Sapphire / RS500 Cosworth 12 28-11-2007 08:03 AM
4x4 head bolts v 2wd head bolt torque? gmzez Ford Sierra / Sapphire / RS500 Cosworth 6 05-09-2006 01:16 PM
Genuine WRC Head Gasket and Standard head bolts?? Damo V General Car Related Discussion. 10 15-06-2005 10:11 PM
setting 4 standard cos head bolts GUZZLER General Car Related Discussion. 3 12-02-2005 09:04 PM
cossie 2wd standard head and piston specs Mark_w Technical help Q & A 1 26-09-2003 02:37 PM
