| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| General Car Related Discussion. To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Sponsored by Cartown |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
#2 |
Unless your walls are majorly pissed I think you'll be looking at 45 degree cuts dude
![]() You can get angle finder rulers from DIY shops if you're in an old house [or one of Chip's constructions] and it looks majorly out? Then just divide the number by 2... Edited to add, when I fitted all mine I screwed them into rawl plugs in the wall, countersunk the screws into the skirting then filled in the holes. Then run some caulk along the top where it touches the wall to hide any gaps [shouldn't be any if you fix it properly] and bob's your fanny. ALSO, buy the pre-primed stuff or prime it BEFORE you fix it up as it's a cunt [I hate painting].
__________________
#3 |
You cut the outer corners at 45 degrees and scribe (copy the shape of the skirting) the inner corners and cut with a coping saw! making sure you cut the correct length.
#4 |
Paddy, it aint a new house mate and there a bit off 90 degree corners
![]() J6KYT, what do you mean the outer corners?? I fucking hate DIY
#5 |
outer corners he means external corners, quite hard to explain if your a thicko like me LOL
see here for more details and how to http://www.ultimatehandyman.co.uk/WO...TING_BOARD.htm
__________________
www.rsseatcovers.co.uk |
#6 |
bpspa cheers fella
#7 |
Picture a square. If that's your room, there are four internal corners. If you were skirting the outside, they'd be external/outer
![]() J6KYTs advice on scribing is fucking genius, wish I'd done that for a flush fit rather than using a tonne of filler
__________________
#8 |
Get a mitre saw it'll do it for you, piece of piss.
__________________
![]() Late spec 4x4 Moondust Saph E39 M5 'Facelift' Individual spec. 08' White Mazda 3 Tamura |
#9 | |
Quote:
![]() ![]() Scribing is a cracking idea
#10 |
Chief Iron Oxide Farmer.
Use 45 degree cuts when you join boards too - unless you have four very long boards or a very small room you're gonna have to join bits.
Scribing sounds cool. I must confess to just using 45 degs on all the corners and then filler to take up any slack.
__________________
#11 |
Resident Wrestling Legend
do as paddy suggests, easiest thing in the world to do
if the joints are out, a bit of builders white gunk will cover the gaps
__________________
![]() Winner: Best Thread on Passionford 2007 How to Quickshift an MT75 Box don't forget i'm dyslexic peeps winning potatoes |
#12 |
__________________
#13 | |
Quote:
#14 |
![]() Trader Score: (0)
Rep Power: 10 ![]() |
Also if you counter bore the fixing holes and have invisable caps you could have removable boards which makes fitting carpets and decorating very easy. tis what i done....Simples
#15 |
11000+ post super hero
you remove your skirtings to decorate? invisible caps? ive never seen them before.
__________________
![]() stage 3 cosworth converted bmw e30 touring. xbox live evilfuzzy2011 |
#16 |
invisible caps
we need pics i wanna router the skirting out so can run all my cables inside but no doubt the living room will be changed about at some point so some revovable skirting is a winner
__________________
#17 |
Testing the future
if you accidently drop an invisible cap when fitting it, how will you find it again?
__________________
Nick It takes me less than 9 minutes ![]() RP Lab L8 ECU 1998 Puma 1.7 / 2002 Galaxy 2.3 LPG / 2007 Honda VFR800 VTEC / 1972 Honda C90 |
#18 |
#19 |
white gunkis called.....decorators caulk
the cut your trying to describe are called...... butt and scribe and the 45 cuts are called,...........mitres google them and see |
#20 |
For Sale..Apply within.
as a tip, for filler, my dad used to use sawdust mixed with pva glue....looks less obvious if you're leaving the wood au naturel
__________________
...line my eyes and call me pretty... |
#21 |
#22 | |
Quote:
modern methods of specific colour fillers for such occasions cant really be beaten if your unable to get the joints tight in the first place.
__________________
#23 | |
Quote:
__________________
#24 |
That's the propper way to do it (how mines done) also if your using real wood that moves (not MDF) you won't have big gaps in the corner when the wood shrinks back.
__________________
![]() B ^^^ RANGE ROVER P38 2.5 DSE ^^^^
#25 |
did some in my house last week, fucking nightmare.
i started trying 45o angles but none of the walls are straight so just cut it straight and bodged it up with filler, it'll be painted so not to worry. when i took off the old skirting most the fucking plaster came off, old houses for you!!
__________________
#26 |
the glue and sawdust trick is good on joins, but not so easy to do on mitres i don't think
what we've done is removed ALL the old skirting, done the walls, fited the carpet and everything, then fitted the skirting with rawbolts that you hammer in the countersink was filled with "invisable caps" which are actually plugs cut from a bit of board with the grain going the same way so when you cover the hole your fixing has left, it looks "invisable after you've glued it in, cut it flush and sanded and painted over the top a bit of a fucker to find again when you want to remove them though
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| removing skirting board | gus | General Car Related Discussion. | 13 | 25-05-2009 04:31 PM |
| what type of skirting boards ? | Ginge ! | General Car Related Discussion. | 10 | 23-06-2007 12:35 AM |
| Skirting Board Ladders...... | BillyCabrio | Non Ford parts & other stuff for sale | 0 | 01-11-2005 10:23 PM |
| ATB Mountain Boards 2 new MBS Boards & 1 Jeep | JBcos | Non Ford parts & other stuff for sale | 0 | 16-06-2005 12:09 PM |
| New to the boards | JRODSVT | Ford Focus RS | 2 | 07-06-2005 04:17 PM |
