| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| General Car Related Discussion. To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Sponsored by Cartown |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
Post Whore
#2 |
*** Sierra RS Custard ***
Yes it could be, particuarly if its blowing in front of the lambda sensor.
__________________
Sometimes its more fun not to care if things make sense, and just do them anyway!
![]() Vauxhall Nova, Mid Engined, RWD, 457bhp, Autronic SM4, GT35R, Quaiffe ATB Diff 2.0 16v - DIY Specced, DIY Built, DIY Mapped, DIY Abused ![]() www.VauxSport.com |
#3 |
Post Whore
Well i bought a new exhaust and it only has 2 sections the cat at the front and the rear section which is very long...on the diagnostic machine it has a fault code regarding the o2 sensor...would this show up becuase of the exhaust ??
#4 |
Check for air leaks aswell mate!!
What beemer is it?
__________________
Cheers Lee 'Just Modify It' ![]() Renault 21 Cosworth, Volkswagen Bora Daily Drive, Renault Clio 172 Track Toy |
#5 |
The plastic intake is prone to spliting and causing a missfire.
__________________
O dear i have bought a BMW....that she wrote off. Now driving Octavia VRS |
#6 |
Post Whore
E36 325....
What do you mean about plastic inlets and that??? sorry im gay lol |
#7 |
O2 sensor is the lambda sensor, if that's faulty it will b causing the miss as well as overfuelling.
If the blow is before the sensor it will show the lambda too much oxygen and then the lambda will compensate with extra fuel, that's not needed. Depending on how bad the blow is it could cause back pressure problems. Ever since I decatted my m3 I've had an intermittant miss, and I've got a proper decat with resonating boxes. A remap will sort this tho. In short, fix the blow, lol to find it easily, start the car and hold a rag over the tailpipe, the gas will come out of the hole and you'll hear it.
__________________
link to my cossie powered renault 5 http://passionford.com/forum/restora...nault-5-a.html |
#8 |
Try unplugging the lambda sensor, it should run fine without it, but wont run fine with it not working correctly.
__________________
#9 |
__________________
#10 |
As bristol_fez says....
This pipe... ![]()
__________________
#11 |
just finding my feet
a hole in the exhaust or airleak will cause a missfire effect on idle, lambda sensor fucked or not will still cause it can still cause it to run rough, that also includes a leak after the lamda sensor... i now this as my clio has a hole in the exhaust and when i sealed it the missfire/slight rough idle dissapeared
also check for oil leaking from rocker cover aswell WHY did you buy a e36 325 and get rid of the jag ? |
#12 |
Me thinks the Jag was too fast for him
__________________
![]() "Judging by the car you have chosen, you are a motorist of a special breed, and you are probably no novice when it comes to automobiles." . . . 928 S4 Owner's Manual 1987 |
#13 |
me thinks maintanance/running costs was too much for him
alex,,,, can i use a later timing chain tensioner for a e36 325 on the earlier engine,, mine weeping and i want to get the car up and running again as,,,, well driving 150 miles in a fucking clio has killed my knees,,,, not to mention the the lifting of the front/loose steering at 85mph plus.... i wanna use my bm again as that loved motorways ! |
#14 |
Post Whore
I got rid of the Jag ginge as it got smashed up actually !!! sod all to do with maintanance/running costs thank you very much....i would still have it now as i loved it, i think i can afford to run 1 jag on my salary mate i dont work in Halfords ya know lol
And Alex it wasnt too fast for me at all was actually a very nice car. |
#15 |
ooooooo touchy
__________________
#16 | |
Quote:
__________________
#17 |
Trader Score: (0)
Rep Power: 10 ![]() |
Mine (320 E46) sounds as if its got a slight blow, but been under it and cant see/feel anything, but it does have a random missfire, when you pull away you have no power whatsoever... Only does it now an then, but bloody annoying!!!
__________________
#18 |
no as the later 325 E36 engine has the tensioner as a complete unit,, the ealier one you can buy it in parts like the piston, spring, washer blah blah blah
i sell the complete tensioner so can "warranty" one but we dont do the earlier one aint sure what BMW charge for it or what part i need so its easier to just buy the complete unit off the shelf |
#19 |
no power aint the same as a slight blow on the exhaust mate, get someone to cover the tail pipe ( not with hand) and get a bit of hose pipe. one part in your ear and the other along the exhaust and you will find the blow
#20 | |
FIESTAHH
__________________
![]() Quote:
#21 |
Post Whore
#22 |
Dan....theres a bloody picture there you numpty!!!
Its on the right hand side of the engine bay inbetween the airbox & the throttle!!
__________________
#23 |
Post Whore
#24 |
Exactly.....if I'd of shoved some young lads arse hole in the engine bay I'm sure you'd of found it very easily!!!
__________________
#25 |
#26 |
Post Whore
#27 |
Post Whore
#28 |
Ive seen naffed ecu's cause a misfire on these.
__________________
E39 M5 & 4x4 Cossie The 400BHP twins! |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| BMW tv people! | JTECH James | General Car Related Discussion. | 6 | 29-05-2009 09:22 AM |
| exhaust is blowing! | raziislam | General Car Related Discussion. | 0 | 13-07-2008 06:53 PM |
| Exhaust manifold blowing, easy to do? | spadey | Ford Escort RS Turbo | 4 | 02-05-2006 07:49 PM |
| mondeo st24 problem - blowing exhaust manifold and powerloss | bluescortcossie | Technical help Q & A | 2 | 28-04-2006 06:13 PM |
| blowing exhaust | haz87 | Technical help Q & A | 1 | 01-07-2005 07:47 PM |
