| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| General Car Related Discussion. To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Sponsored by Cartown |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
#2 |
#3 |
Team HOTHOT!
![]() Trader Score: (0)
Rep Power: 27 ![]() |
Put the fuel injectors in from an RS2000 and that will give you some driveability back untill you can sort it properly - the injectors on the 2.3 are slightly larger cc wise and with the RS2000 ECU expecting smaller injectors for smaller engine capacity as per the map, it fires as per the rs2000 and not the Granada injectors.
Its only a temp fix but it will help a bit for the time being.....
__________________
#4 |
he wanted the rs2000 ecu as its a better ecu and mapp and he would have had to change the ignition as they have coded keys so he totally got rid of that made a complete new loom and rewired the ecu plug from the granada to the rs2k ecu hes tring to find a 91-92 rs2k ecu so he can check that the ecu isnt faulty if any 1 has 1
#5 |
ill let him know about the injectors but im not sure that will work as its overfueling on idle and the as soon as you touch the throttle it goes massivly lean like its shutting the fuel off as if the flood clear is kicking in
#6 | |
YES I KNOW I CANT SPELL
Quote:
__________________
" im special,, excuse my spellings" |
#7 | |
Quote:
Mark |
#8 |
Team HOTHOT!
Regardless what RPM the engine is running, the ECU is expecting a certain flow rate from the injectors - the bigger injectors are firing more fuel in at all revs not just idle - start as you mean to go on, change the easy things first.
Of course, if you don't want my advice (I put a turbocharged RS2000 engine in my old XR4x4 a few years ago so it's safe to say I'm pretty clued up) then don't take it - I couldn't give a cuntyfuck either way
__________________
#9 |
no all the advice is more than welcome i had enough problems with my own and it was only by asking people i managed to get my rwd 3.1 saph twin turbo running right on a stand alone management
#10 |
were would he get a better map for that ecu from
#11 |
i think hes using the granada map sensor
#12 |
The RS2000 ecu runs the 2.3 no problems and will run a bit lean but be perfectly driveable with the RS2000 injectors.
Check the wiring for mistakes and make sure the map sensor is connected to the loom and the signal line to the plenum. Mark Last edited by Mark V8; 16-06-2009 at 11:13 PM. |
#13 |
yea just spoke to him yea the mapp sensor is connected and the he had the loom made by some 1 in aircraft grade s/s wiring the only bit he wired up was the ecu plugs but hes been over that x amount of times i think this is why he thinks the ecu may be trashed but you never know
#14 | |
Quote:
#15 |
with the 2300 you have to make a bit to go on the block were the sump goes as youll have to put a rwd gearbox on and theres a few other things you have to do to get it in depends if you have some 1 to make the bits zetec is a lot simpler if thats any help
#16 |
The RS2000 engine would be much easier than the 2.3 as it has no balancer shafts in the sump and the block is based on the 2 litre twin cam Sierra engine so the engine mounts, flywheel, sump etc from the 2 litre Sierra will turn it into a fairly easy job. You will probably have to do something with the thermostat housing as it is at the back of the engine when fitted to RWD and the RS2000 inlet manifiold also points the wrong way.
Mark |
#17 |
i was gonna get the rs engine, but wasnt sure if it would be worth it for an extra 25 bhp. still havnt made up ma mind what to put in it, will be using it as my runaround until i find a decent saff to do, its a hb ! had a v6 and it was good but it wasnt great ! cant stop thinking about an xe !
#18 | |
Quote:
Mark |
#19 |
i was thinking that, just hope its a bit better on the gas than the auto, had a loan of ma uncles scorpio and couldnt keep it goin on fuel, and the petrol gauge didnt work ! must admit it went well tho !
#20 | |
Quote:
Mark |
#21 |
Trader Score: (0)
Rep Power: 29 ![]() |
agreed 24v for fit n forget 200bhp
__________________
'52 530D Touring M-Sport
#22 | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| RS2000 16V video? | TM RACER® | Pictures, video & Photoshop Forum | 6 | 18-04-2009 12:35 AM |
| 160bhp rs2000 16v | theburns1 | Ford Rs Parts For Sale (Not cosworth, or Cvh Turbo) | 5 | 15-02-2009 12:00 PM |
| rs2000 16v engines? | theburns1 | General Car Related Discussion. | 34 | 11-02-2009 07:52 PM |
| mk1 rs2000 16v | johnston-evo3 | Technical help Q & A | 1 | 06-05-2008 07:54 PM |
| mainfold Rs2000 16v | MK5RS2000 | Cars & Parts Wanted. | 0 | 04-09-2006 10:07 PM |
