| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| General Car Related Discussion. To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Sponsored by Cartown |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
PF Idiot Sniper
__________________
![]() ![]() Birds shouldn't be moderators ; ) |
#2 |
Virgin-popper
Yes. If you mixed alot you will need too flush your system. Soon you will get some kind of foam in your headertank, and it may turn into jello
#3 |
My dads escort uses pink, my BMW on the other hand cant use that, ive got to use BMW spec stuff which is pale green
#4 |
Monte 087
Mixing it can be bad, drinking it can be alot worse
__________________
#5 |
AFAIK anti freeze is anit freeze is it not??
never had any problem with mixing different colours or makes. |
#6 |
PF Idiot Sniper
__________________
#7 |
he didint say mate, hopefully it did a job for you!
im only talking from experience mate. never paid any attention to what anti freeze i put in my car whether it be from halfords or the local garage or out euans shed!! best bet would be to walk into halfords and compare what it says on the back of two different bottles. |
#8 |
red/pink etc - Organic Acid Technology
blue/green etc - Glycol Ethelene The two do not mix - they attach each other and turn into a brown sludge that blocks the system - then you overhead and damage the engine. Alex
__________________
![]() "Judging by the car you have chosen, you are a motorist of a special breed, and you are probably no novice when it comes to automobiles." . . . 928 S4 Owner's Manual 1987 |
#9 |
saff is working!!!...atm
![]() Trader Score: (1)
Rep Power: 14 ![]() |
__________________
mapped by Ahmed....set up at Grove....
#10 | |
PF Idiot Sniper
Quote:
aha great answer thanks! i wouldn't have known that
__________________
#11 | |
Quote:
![]() Heres another for you, why do cars with the same/similar engine need one or the other? why cant we all run petrol engines on the same? |
#12 |
The red stuff literally eats into the metal work and forms a protective layer. So the engine needs to be designed to work with it. The advantage is that the life is about 5 years compared to the older green stuff that lasts 2-3 years at best.
Alex
__________________
#13 | |
Resident Wrestling Legend
Quote:
![]() i've got pink stuff in the mondeo, should it still be changed every few years then or CAN it last upto 5 years?
__________________
![]() Winner: Best Thread on Passionford 2007 How to Quickshift an MT75 Box don't forget i'm dyslexic peeps winning potatoes |
#14 |
__________________
#15 |
Trader Score: (0)
Rep Power: 12 ![]() |
Yep ive seen exspansion tanks full of jelly due to folk mixing anti-freeze etc
Even seen windscreen washer bottles with jelly with just mixing the wash additive Make sure system is properly flushed through with water before putting fresh coolant in
__________________
306 GTI 6 |
#16 |
I'm sure the Ford stuff now lasts 10yrs providing its not been watered down. I'd go with what ever the hand book says to use & just replace the whole lot unless your able to check the antifreeze is still up to scratch.
#17 |
Coolant every 3 years
Brake fuild every 2 years Oil every year (more if you do more miles obviously) job done!
__________________
#18 |
orion=mini saff
![]() Trader Score: (3)
wow,never knew tht,
#19 |
#20 | |
Quote:
![]() now they'v gone i've got to start forking out my own money ![]() still, kwik fit for oil, brake fluids and tryes, another guy for next to nothing cheap service work
__________________
#21 |
Okay...But, what if we've drained the green, the flushed the system with plain water, and then put the red stuff in? Will it still gel?
#22 |
Also, is there any way to clean out an installed heater core? We think the people that owned this car before us didn't know a thing about maintenance and may have mixed red and green before we got to it. Is it too late to do anything about it. Or should we go ahead and get a pro to flush it the right way?
#23 |
i didn't know this either :s the water in my header tank looks a bit brown to me but have a feeling its due to rust .... will need to flush that all out when i get a chance
x |
#24 |
neeeeeeeeooowmmmm
Just don't do what the stupid fool did when I was at work and stick washer fluid in the coolant, in a big merc thing. She came up to me and went 'I did a bo bo'
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Focus RS Antifreeze? | matt01 | Ford Focus RS | 4 | 10-02-2008 01:28 AM |
| What antifreeze/coolant??? | smudge_lad | General Car Related Discussion. | 7 | 13-07-2007 10:50 PM |
| antifreeze | zvhturbo29rs | Technical help Q & A | 3 | 10-07-2007 07:50 PM |
| mixing antifreeze? | dave_y | General Car Related Discussion. | 21 | 03-12-2005 01:08 PM |
| antifreeze question | jason len | Other Marques | 1 | 26-11-2005 01:09 AM |
