| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| General Car Related Discussion. To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Sponsored by Cartown |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
#2 |
injector coding, common as hell on them, get it code read then go from there, sometimes the injectors can be recoded other times new set needed&coded
#3 |
iirc the glow plug light can also flash if there's a problem with injectors on the TDCi. There's some code that says something about the injector control pressure being low? I don't know the code or remember the exact wording. I'm sure someone on here will.
We've had it happen a few times on mondeos and the X-types and I remember one fix was new injectors [they can sometimes be recoded?] but the first place to start is with a few sensors that can fail. Get it on someone's diagnostic machine and find out? Get someone decent though as in my experience most of the people in Ford are just fitters now who try different parts and spend your money until the problem stops. A decent mechanic will save you money. *EDITED TO ADD* Someone replied the same 1st!
__________________
#4 |
oh and i forgot to say cam sensor can give the cutting out faults and glow plug light flashing
#5 | |
Post Whore
Quote:
#6 |
as people have already said it could be a number of things causing the problem.cam sensor is the first thing that needs looking at as there are later type grey ones asthe early ones are black and cause problems.normally as your driving it goes out of synch with the crank sensor and shuts down for safety.
another thing could be the injection pump breaking up and blocking up the injectors.normally happens as your crusing along as the pressure build up pushes the particles to ends of injectors and blocks them up. best thing i to see what codes have been set.iirc one will be a p code saying p0251 i think hope that helps a bit
__________________
#7 | |
Quote:
You splice a new plug assy into the loom and replace the fuel sensor (this is at the end of the fuel rail), this should cure the problem. Hope this helps. Stephfezza |
#8 |
i certainly wouldnt go buy parts until you have read the codes
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Ford Mondeo Tdci 2002 | bill101203 | General Car Related Discussion. | 2 | 18-05-2010 08:28 PM |
| mondeo 20 tdci cutting out? | RobS | General Car Related Discussion. | 2 | 27-09-2008 12:06 AM |
| Recharging Air Conditioning In Ford Mondeo Lx Tdci Oct 2004 Model | wskxd14 | Technical help Q & A | 3 | 03-06-2008 08:13 PM |
| Mondeo ST Tdci or Zetec S Tdci | bud-weis | Cars & Parts Wanted. | 0 | 24-01-2008 01:48 PM |
| Ford Mondeo ST TDCi... Do they hold there value? | Benni | General Car Related Discussion. | 13 | 12-03-2007 08:53 PM |
