PassionFord
Go Back   PassionFord > Main area > General Car Related Discussion.
Register Forgot Password?
Sponsored by Cartown
Click Here
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 17-10-2008, 04:00 PM   #1
b63_rs
Trader Score: (0)
b63_rs is an unknown quantity at this point
boderz
Send a message via MSN to b63_rs
Default Ford fault codes anyone help please?????
hello all wonder if anybody can help my mrs has a streetka 1.6 duratec with the engine management light on . ive taken it to a friend who plugged it on to diagnostic machine and it came back with this code
p0030 ho2s heater control circuit bank 1 sensor 1
can any body find out what part i need to buy to rectify this fault please many thanks
__________________
PS3 ONLINE>>boderz
b63_rs is offline   Reply With Quote
Old 17-10-2008, 04:05 PM   #2
alan12112
Focus St mk2 310 bhp :D
alan12112's Avatar
Trader Score: (0)
alan12112 is an unknown quantity at this point
Send a message via MSN to alan12112
think you need a new oxygen sensor fella, is the one you've got getting hot when the car is run?
__________________
Fiesta Turbo= Awesome but not big enough
Mondeo ST = Sold on - not an old man yet!
Focus ST = Best of both!!
alan12112 is offline   Reply With Quote
Old 17-10-2008, 04:08 PM   #3
alan12112
alan12112's Avatar
Trader Score: (0)
You sure it's not a zetec?
I didn't think they put 1.6 duratec's in ka's...
Just checked pal it's a zetec badged up as a duratec 8v
There are some here pal
http://www.gendan.co.uk/oxygen_lambd..._StreetKa.html
__________________
Old 17-10-2008, 04:11 PM   #4
b63_rs
Trader Score: (0)
boderz
hello mate thanks for reply yes its definetley a duratec 1.6 8v, where am i looking for the oxygen sensor ? do u mean the plug on the exhaust manifold (lambda) i think sensor??? cheers for help
__________________
PS3 ONLINE>>boderz
Old 17-10-2008, 04:16 PM   #5
b63_rs
Trader Score: (0)
boderz
ahh brilliant thanks mate. how would i no which to replace pre cat or after cat? would that fault code tell me this ? or is there an easy test i could do?
__________________
PS3 ONLINE>>boderz
Old 17-10-2008, 05:02 PM   #6
Doug
Trader Score: (0)
Doug is an unknown quantity at this point
It requires the upstream ( Pre cat )
Regards Doug .
__________________
Doug is offline   Reply With Quote
Old 17-10-2008, 05:45 PM   #7
b63_rs
Trader Score: (0)
boderz
thanks a lot doug cheers
__________________
PS3 ONLINE>>boderz
Old 17-10-2008, 07:23 PM   #8
B19 JUB
Trader Score: (0)
B19 JUB is an unknown quantity at this point
Send a message via MSN to B19 JUB
yeah ho2s11 hego sensor is a common fault on the ka.its known as a duratec but technically its called a rocam engine.one thing i will say is that when upstream hego sensors go wrong there is a technical bulletin which requires an engine ecu upgrade too to go with the new sensor as old software can knacker the new sensor
__________________
B19 JUB is offline   Reply With Quote
Old 20-01-2010, 11:01 AM   #9
scott Pitchford
Trader Score: (0)
scott Pitchford is on a distinguished road
Gents
Can anyone help???
I have a problem with mt Ford Fiesta 1.6 TDCI sport, I have a warning message engine system fault refer to handbook, and the car starts but cuts out straight away.
Also when I started it there was a strong smell coming from the exhaust and the smoke was blue ish in colour !!!!!!!
Any ideas????
Scotty
scott Pitchford is offline   Reply With Quote
Old 20-01-2010, 11:04 AM   #10
MarkyMark
MarkyMark's Avatar
Trader Score: (0)
MarkyMark is an unknown quantity at this point
Send a message via MSN to MarkyMark
whats the fault number?
__________________
Mark
MarkyMark is offline   Reply With Quote
Old 20-01-2010, 11:07 AM   #11
scott Pitchford
Trader Score: (0)
I dont have one not had it on a machine yet local ford dealer was £91 per hour and £70 just to stick it on the machine !!!! and I have heared alot of people forking out and still have problems !
Old 20-01-2010, 11:13 AM   #12
scott Pitchford
Trader Score: (0)
Been playing up for a while now !!!
Was in garage a few weeks ago I could not start it, they said I had a split in one of the fuel pipes, they done that I drove the car home o.k parked in garage. Went to start the other day now I am getting this error code and shes cutting out !!!!!!
Old 20-01-2010, 11:27 AM   #13
MarkyMark
MarkyMark's Avatar
Trader Score: (0)
you have to have it put on a fault reader, it could be anything, i am leaning towards the seals on the injectors going but it could well be turbo or pump has gone, so go to a local garage and find one thats got a fault reader
__________________
Mark
Old 20-01-2010, 11:37 AM   #14
scott Pitchford
Trader Score: (0)
Mark nice one,
Just been out to start the car it started first time then after 2 mins warning came up again !!!
I have noticed is it normal for the turbo wushing sound as soon as you put your foot on the throttle????
Old 20-01-2010, 11:41 AM   #15
MarkyMark
MarkyMark's Avatar
Trader Score: (0)
the warning will do, the ecu will cycle see their is a fault and put the light on,
soon as you put your foot on the throttle so iam guessing the revs arent high, then no its not normal
get it to a garage fella
__________________
Mark
Old 01-02-2010, 02:14 PM   #16
scott Pitchford
Trader Score: (0)
Afternoon butty
Been a while but got the problem sorted after Its was a fuel line at back of engine that was collasping when you put your foot on the accelerator.
New pipe fitted now and running like a dream.
Scotty
Old 14-03-2010, 10:37 AM   #17
radiogareth
Trader Score: (0)
radiogareth is on a distinguished road
Default StreetKa Sensor
Hi, found this thread in response to the wifes SK throwing up the same code (after 40,000 miles). Bought a replacement sensor, easy, not so easy, getting the old one out. Not having a 22mm Box spanner (probaly a special Ford tool) I cut the top off the dead sensor using a small angle grinder, plenty of room. Got a single hex socket on it, it was VERY tight, even after soaking with WD40. Got it out to find that it's left most of it's thread in the cast iron manifold. So now I need a 18*1.5 thread restorer. Why they chose to mount it in a horizontal pocket in the cast manifold is beyond me. Anyone else had grief getting these bug**rs out, and did it end in tears, involving a new exhaust manifold etc......
Thanks
Gareth
radiogareth is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
pug fault codes Alps Pacino General Car Related Discussion. 9 28-09-2007 08:20 PM
Fault reader codes.... warleydaddy General Car Related Discussion. 15 20-06-2007 09:35 PM
Fault Blink codes on L8 richm General Car Related Discussion. 8 01-01-2007 10:34 PM
OFAC fault codes Avinitlarge Technical help Q & A 8 29-07-2006 09:09 PM
P8 FAULT CODES?? Diablo Technical help Q & A 2 18-05-2004 12:03 PM
