am i right in thinking a pinto clutch is the same as a cosworth clutch?
as title says as im trying to gather bits for mtx75 conversion but told i need a pinto clutch? cheers
works out about Ł1500 for a stage 2+ box with id be changing up the gears every 2 secs and expensive if it does bust, mtx my mate had for 2 1/2 years no problems, rated well ans same price to fit and chassis rails modded so can be removed without removing the engine like present , may have a new paddle for you soon mate as i have to change clutch
YES I KNOW I CANT SPELL
The best thing to do is get a clutch plate for the car that the gearbox came from and try it,you only have to worry about diameter then.
regards mark
just finding my feet
cossie engines are expensive for a reason, they aint just pinto bottom ends with skimmed pistons and a 16v head
thats why they take so much power is cause they redesigned them, its also why the bottom ends where 12k from fords exchange
big_Rad
15-09-2017 09:36 AM
