PassionFord
Go Back   PassionFord > Main area > General Car Related Discussion.
Register Forgot Password?
Sponsored by Cartown
Click Here
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 07-05-2008, 08:59 PM   #1
Munch
Mr. Sparkle!
Munch's Avatar
Trader Score: (0)
Munch is an unknown quantity at this point
Default Idle Speed Valve - I4 Engine (RS2000)/Fuel Problems
Evening...
Friend of mine, has a just bought a New Idle speed valve dure to poor idling. Question is, do you just plug these inn & job done or is there some thing else we need to do?
Also, it is shit on fuel. Get about 30 miles to a tenner just cruising. You can smell the fuel badly. Any idea's to where we should be looking?
__________________
CHEERS, LEE
Onslow Loves COD!
Arguing on the internet is like racing in an impreza, even if you win, you're still a twat.
Munch is offline   Reply With Quote
Old 07-05-2008, 09:24 PM   #2
Rs Gary
Trader Score: (0)
Rs Gary is an unknown quantity at this point
the o-rings on the injectors go hard and distort which could give you your poor idle,did the car cut out when you pulled the plug on the iscv,if it kept on running then you have an air leak and the smell of petrol is because of the o-rings not seeling,it is a common fault and i have replaced the o-rings on mine and no more rough idle or petrol smell,you cant buy the o-rings from ford anymore so i got mine from B&Q doubled them up put a bit of silicone grease on them and it did the job,you will need 8 B&Q o-rings to replace the 4 ford ones,i think they are a 14mm internal diameter
cheeRS gary
AKA shrek
Rs Gary is offline   Reply With Quote
Old 07-05-2008, 09:27 PM   #3
Rs Gary
Trader Score: (0)
here is a pic of my o-rings
cheeRS gary
AKA shrek
Old 07-05-2008, 10:30 PM   #4
Munch
Mr. Sparkle!
Munch's Avatar
Trader Score: (0)
ah right, its deffo the Idle speed Valve i know it is, cos sometimes we can get it to idle fine & at the mo, it aint running an Valve. will look into the injectors too
__________________
CHEERS, LEE
Onslow Loves COD!
Old 08-05-2008, 01:07 PM   #5
Munch
Mr. Sparkle!
Munch's Avatar
Trader Score: (0)
anyone else
__________________
CHEERS, LEE
Onslow Loves COD!
Old 08-05-2008, 04:02 PM   #6
thecrust
thecrust's Avatar
Trader Score: (0)
thecrust is an unknown quantity at this point
Could have dropped into LOS because of a failed sensor? I'm told the regular gunson-type fault finders don't work on the RS ECU like they would on other I4 engines but could be worth getting it on a diagnostic tester?
__________________
thecrust is offline   Reply With Quote
Old 15-04-2009, 05:18 PM   #7
sweets
sweets's Avatar
Trader Score: (0)
sweets is on a distinguished road
rs gary your the man i have a mk3 fez with an rs2k conversion and had the stink ov pertrol and poor idle but just changed the o rings and seems good as new, you saved me a packet from taking it to garage to diagnose! cheeRS
sweets is offline   Reply With Quote
Old 29-01-2010, 03:33 PM   #8
Dursley
Dursley's Avatar
Trader Score: (0)
Dursley is on a distinguished road
ok so it looks like i need to do these o rings on my RS2000, i have all the mentioned problems....
Does anyone have a guide for a noob under the hood??
Chris
Dursley is offline   Reply With Quote
Old 01-02-2010, 02:16 PM   #9
Dursley
Dursley's Avatar
Trader Score: (0)
Quote:
Please help!! getting 20mph max, cannot afford this info pleeeeease guys
Chris
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
idle speed valve?? mpales Ford Sierra / Sapphire / RS500 Cosworth 4 19-01-2008 05:09 PM
Idle speed control valve!! andyevo General Car Related Discussion. 2 02-08-2007 04:30 PM
idle speed control valve anthony4773 Cars & Parts Wanted. 0 27-12-2006 06:51 PM
RS2000 IDLE SPEED CONTROL VALVE WANTED bigsjay Cars & Parts Wanted. 0 23-07-2006 01:17 PM
idle speed control valve davidnormanuk Cars & Parts Wanted. 0 06-07-2006 08:40 AM
