LOW OIL PRESSURE ,,WHERES IT GOING???
Old 09-01-2008, 02:27 PM
andrewg
andrewg's Avatar
Default LOW OIL PRESSURE ,,WHERES IT GOING???
got problem with a cossie having low oil pressure (0@ idle-15 psi @ 3000rpm) so we took off the sump all looked mint replaced bearings and pump anyway but still very little pressure.
removed cam cover and stripped out dizzy and run pump up with a drill and no noticeable oil coming to tappets.
this is checked with the cars own gauge and a proper mechanical test gauage
i know the front left head stud hole is used to carry the oil to the head thought maybe this was leaking but doesn't appear to be
This Engine Has Been Dynoed And Done Miles So It Was Fine When Built
just wondreing if anyone else has had this experiance??
Old 09-01-2008, 02:33 PM
Jasesapphy
Jasesapphy's Avatar
Got the same problem with my old engine buddy, cars not tappy, bottom end not knocking, apparently rebuilt 6K ago, bought it off here, at idle 2psi, at 2K 15psi and 22psi @ 3000rpm.
Sounded good
Took the engine out and fitted a spare, it still on my engine stand. dont know what to do with it.
Old 09-01-2008, 02:40 PM
andrewg
andrewg's Avatar
think im going to remove the sump again and run up the pressure with the drill and see if i can see where its going from underneath
Old 09-01-2008, 03:03 PM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
What oil is it?
Old 09-01-2008, 03:06 PM
andrewg
andrewg's Avatar
mobil 1 15/50
Old 09-01-2008, 03:10 PM
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
Maybe oil blanking cap blown out behind the auxilliary drive cover.
Seen that before.
Old 09-01-2008, 03:12 PM
andrewg
andrewg's Avatar
Seen that before.
ok i'll check that
Old 09-01-2008, 03:13 PM
Lloyd
escort mk4 cossy 4x4
Lloyd's Avatar
could it be a blockage in a oil gallery.try testing the pressure from the cylinder head oil gallery plug, is the oil pump drive rod worn,seen loads of these rounded off,or fitted upside down,long side goes towards the dizzy.
Old 09-01-2008, 03:35 PM
Mark Shead
Mark Shead's Avatar
andrewg
As the Cossie has a simple oil system it can only be a couple of things,
Stock oil cooler? what was the oil pressure on the dyno?
Check bigends for wear,check to make sure the oil pickup gasket is sealing, Check the oil pump clearance to block to make sure there is none as this is the most common fault I see with oil pressure.
Mark
Old 09-01-2008, 03:45 PM
andrewg
andrewg's Avatar
if it was a blockage it would still have pressure. and i have removed the dizzy and manually turning the pump with a drill
think it could be this blanking core plug.
Old 09-01-2008, 03:50 PM
andrewg
andrewg's Avatar
Originally Posted by Mark Shead
andrewg
Mark
we over filled the sump so the pump would be submerged in oil to eliminate the chance of it drawing air through the pick up
Old 09-01-2008, 04:17 PM
Mark Shead
Mark Shead's Avatar
andrewg
Mark
What about the pump to block you couldnt have put that much oil in it.
Mark
Old 09-01-2008, 04:21 PM
andrewg
andrewg's Avatar
Seen that before.
SORTED IT WAS THIS THANKS
Old 09-01-2008, 04:22 PM
Butch.
Butch.'s Avatar
well done stu
Old 09-01-2008, 04:27 PM
Lloyd
Lloyd's Avatar
Seen that before.
well done stu,jasesapphy,check your engine for this?
Old 09-01-2008, 04:50 PM
Jasesapphy
Jasesapphy's Avatar
Will do buddy
Old 10-01-2008, 08:11 AM
Seen that before.
Your Welcome Andy.
Old 10-01-2008, 08:12 AM
Ryan
Ryan's Avatar
well done stu, good call
Old 10-01-2008, 08:29 AM
Porkie
Porkie's Avatar
Seen that before.
Stu... you da MAN!
Think that deserves a hot lap or 2 in the new Focus I reckon
What a beast thats gonna be
Old 10-01-2008, 09:31 AM
The Youth.
The Youth.'s Avatar
I know where the aux drive cover is (alloy plate 3 bolts) but whats this blanking plug, anyone got a pic?
And where does the oil go if it comes out of this hole?
well done stu BTW
steve
Old 10-01-2008, 09:32 AM
Neil S
Neil S's Avatar
Back into the sump at a guess Steve
Neil.
Old 10-01-2008, 09:47 AM
Neil.
Correct.
Old 10-01-2008, 09:50 AM
The Youth.
The Youth.'s Avatar
cheers guys,
you learn something new everyday!
steve
Old 10-01-2008, 09:56 AM
RWD_cossie_wil
RWD_cossie_wil's Avatar
well done stu BTW
steve
2nd'd for a pic please
Great job Stu.
Old 10-01-2008, 10:13 AM
You can see it here...
Old 10-01-2008, 10:15 AM
PGT
PGT's Avatar
Seen that before.
this is exactly what happened to my engine whilst it was at stu's place getting mapped except mine had ZERO oil pressure. the engine had already done about 700 running in miles by then as well. caused no damage as they cleverly noticed it before starting to map it.
Old 10-01-2008, 10:18 AM
carlo
carlo's Avatar
Nice one stu
Old 29-08-2015, 12:48 PM
Ridgey
Ridgey's Avatar
Does anyone have a picture of the offending item behind the auxiliary pulley ?
I've lost 10 psi oil pressure, and want to investigate if this is starting to fail.
I have high pressure oil pump and now is giving when hot:
18 psi at idle
55 psi when running higher rpm
Thanks
Old 29-08-2015, 09:54 PM
lee2cossies
lee2cossies's Avatar
This recently happens to me ridgy I only had 5 psi of oil pressure even when revving engine, I'd imagine yours would be fine if only lost 10 psi, you don't get any oil to the top end when this pops out so top end gets damaged pretty quick!
Ridgey (30-08-2015)
Old 30-08-2015, 12:10 AM
mgtkr1
mgtkr1's Avatar
msd personell to the rescue again, have only heard good things about them.
Old 30-08-2015, 07:57 AM
Ridgey
Ridgey's Avatar
Lee
Is it like a mini core plug that blows out?
Old 30-08-2015, 09:31 AM
Adam-M
Adam-M's Avatar
Unfortunately the picture isn't displayed now, I'd like to investigate this aswell chaps.
Let's hope you don't get flamed for bringing this thread back you did the right thing mate I haven't heard of this cap problem before. Well done stu at MSD top bloke!
Old 31-08-2015, 10:28 AM
lee2cossies
Originally Posted by Ridgey
Lee
Yes mate little core plug about 10mm. It's easy enough to check but u have to take the belt off and the auxiliary pully.
Old 31-08-2015, 03:34 PM
stevieturbo
C**t
stevieturbo's Avatar
But as Lee said, if he's still seeing 58psi, no way has that core plug came out.
Old 31-08-2015, 07:27 PM
Ridgey
Ridgey's Avatar
But I'll check that it hasn't started to come out and leak some pressure
Old 31-08-2015, 08:46 PM
stevieturbo
C**t
Possible, but I'd think it would either be in or out.
Old 01-09-2015, 01:49 PM
lee2cossies
Can't see it being the plug with that pressure you lose oil feed to the top end also so engine wouldn't run for long before it would get damaged. Small possibility it's got a small hole but more than likely a weak spring in oil pump I'd take a guess at.
oilman
Trader Parts for Sale.
23-09-2015 07:32 PM
dombanks
21-09-2015 08:38 PM
Rich Coveney
Ford Mondeo Including ST
15-09-2015 05:39 PM
Tank Mike
10-09-2015 07:56 AM
CrOwSoN15
14
03-09-2015 12:21 PM
Quick Reply: LOW OIL PRESSURE ,,WHERES IT GOING???
