Now where to modify rear beams ?
Rally nut
Now that Brom can't modify the rear beams anymore, who can do the job at good price ? Brom had to make me a new beam with new arms, all adjustable, for less than 900£ grand with new parts.
I have seen Adrenaline Race & Performance are doing the job too, but not less than 1 grand, on an exchange basis with my old beam, and no new arms.
Anyone knows another man doing the job at lower price ? Have the choice for a real group A rear beam with mag arms and flanges, but that's 1500£, so finally not far away from 1200£ (adrenaline beam with new parts).
Rally nut
Looks nice. Is it possible to have a strapped version "solid mounted" like Brom was doing ? And most important, at which price with new parts (not on an exchange basis or old parts) ?
Cake lover!
Xen A proper Grp A beam is only 9 Degree's. That is not optimum as they had to work within the rules or so i am told. The beams Ahmed and Danny do are 6 Degree's which is better, thats how i understand it anyway.
Theres a Massive thread about it in here if you have a look about.
Rally nut
Originally Posted by Cosworth Rallyesport
£1500 for the real deal,this is a no brainer!!!!!!!!!!!!
Rally nut
Originally Posted by andrewg
two on ebay for sale ahmed type or adreniline
another option.
Former Sponsor
i would only ever use a group A beam or a wrc cradle with links,heard to many horror stories to risk anything else,but then i dont just go on road and do trackdays so my uses are abit more intense.
Rally nut
Cosworth Rallyesport so is ur type a excate copy of a wrc multi link! or is it somthing u have developed? Also whats the cost involved for the kit and fitting (if its not a direct replacement which im sure its not!)
here's another copy of a wrc cradle which takes the 7.5" diff and didnt cost thousands of £s. much easier to set up than a group a rear beam aswell.
Rally nut
Yes but then you have to look for all the arms and arm connection on the hubs. At the end it will cost more than a group A setup. Will have an even better adjustement, but unsure of the difference on the performance side.
Caraholic
You have already been told by Ryan . The Grp A rear beams are only 9°, whereas the Ahmed / Adrenaline ones are better, due to not being constrained by rules, so have been built to the 6° optimum. The Ahmed one is £1k exhange and can be bought through me . Please be aware that the Ahmed one is fully adjustable for camber AND toe, whereas I believe the base Adrenaline version ONLY does camber. Therefore make sure that you are always buying like for like when comparing prices .
Testing the future
i have never understood why people spend so much money on modifying a shit rear beam into a slightly less shit rear beam
if the cradle and double wishbones had been developed years ago they would not cost much by now
Former Sponsor
You can say the same about the whole Car though can't you?
We spend grillions on making shit cars slightly less shit!
Testing the future
but if you're spending that much on changing something, change it for the best.
http://www.adrenaline-race.com/forum...opic.php?t=530
Caraholic
Rally nut
Modified standard beam (Ahmed, adrenaline, ...)
+ Better 9° setup than group A setup (is it really right on a rally stage or how bad is the difference ?)
+ Less expensive
+ More spare parts
+ No need to use extra special parts to have the rear end of the car fixed
Group A
+ Stronger than the standard one setup
+ Lighter
+ Was build for rally instead of the standard beam so must be better at the end
- Comming hard to find the parts
- 6° (unsure, if it is still a - hard - disadvantage ?)
WRC setup
+ Fully adjustable
+ Stronger than all previous systems
+ Easier to change the wishbones when you have one cracked
+ Lastest evolution in the rear end of the Cossie cars
- Most expensive system, even if doing the arms would be quite "simple" like using tubes with some work to each end of it
- Not easy to find, but could be "home-made" (unsure of the final result tho)
Feel free to comment/modify that small review of the different setup. I still don't know if I should go for a standard-modified rear beam (which I red there can have more adjustement than a group A item) or a group A rear beam which has been proven to be a real advantage over the standard one (used on rallies, so can't be bad). Won't go for the WRC type rear cradle for some reasons.
Caraholic
The point I was making is that don't go comparing the Stage 1 version of the Adrenaline beam with the £1k Ahmed one, and thinking that there was a huge price disparity with the two, when Ahmed's one should only be compared with the Stage 2 Adrenaline version, as Ahmed does only one version and that is fully adjustable .
Originally Posted by maxrs16
does anybody no what hub carriers you would use withe the diff cradle setup
Without going down the 909 part route the only options that spring to mind would be to do the same as the rs2000 4x4 / mondeo 4x4 these have the same lower 3 link setup, the only difference being the angle of the tie rods. The hubs used on the rs2000 where just the front hubs of a mk3 fiesta, not sure on the mondeo but it shouldn't be to hard to find out the fins number for the part and see if it unique to the mondeo 4x4 or shared with another car.
Testing the future
my opinion on it is why limit yourself to something that was used on a competition car that had to adhere to certain regulations when you have the freedom (for probably not much different money) to go for something much better and fully adjustable?
while you're at it, make it use a better diff
