Now where to modify rear beams ?
#121
Originally Posted by sfhsport
are you not forgetting the shell fabrication involed for the turrets new pick up points for the cradle and then you need hubs shocks etc, making the cradle is the easy bit. I thinking of producing copys of the WRC rear end and for the cradle (to take 7 1/2"), 2x hubs (group a type), 6x latteral links, 12xrose joints ,side spacers bottom brackets etc could be supplied for around £2700 but i didnt think there would be enough call for it.
there would if you done a group buy and sold it for right money
dont forget theres alot of top people that read passion ford but they dont post on here
theres also a few people that come on here that have got track cars or rally cars that wouldn't mind modifing their cars to take the wrc set up
personally i wouldn't do it to my road going 3dr but would do it to my escort cos thats a track car or will be when it's finished
marco
#123
Testing the future
i would not want anything that uses the 7.5" diff as it is just too weak but the 9" is obviously too expensive. so it would have to be something else, but then you're talking extra cost with drive shafts, prop etc
#124
Originally Posted by miller3
I would love to make my own beam, What exactly would be needed and where from
and someone who knows what hes doing
#125
Testing the future
#128
Unknown.
welsh humor gets me
#129
marco
I personally can't see any problem with it using the 7.5" rear diff either as while not a strong as the 9" it can still take a fair amount of power, besides you can make do with less power when your actually puting it down on the black stuff .
Maybe its because of the relative cheap cost of getting power from the YB, but the whole quality suspension side of the equation seems to be somewhat lacking in the ford scene IMO , you could use the same hubs for the front, make up some compression struts / track control arms some 9092939 anti roll bar mounting brackets and the blade anti roll bar to go with them and you'll have a good front setup to go with the rear that would work on 2wd and 4x4 cars.
#130
Caraholic
You would cry if I told you how much I got the GGR beam for Martin for - it was less than the price of a normal modified standard beam . At the time I didn't want it due to still being on Konis and not wanting to modify the boot floor so the exhaust could clear the square beam, otherwise I would have kept it for myself .
This is how good it looks now :
#132
Rally nut
why no anti-roll bar on the back?
#135
Rally nut
#138
Testing the future
Originally Posted by martin-reyland
I'm thinking of going the WRC route myself
#139
I'm thinking of going the WRC route myself I Can't see why standard RWD shafts and bearing carriers can't be used in conjunction with the wrc cradle, is there a reason??
#141
The billet variety sfhsport has on his car are very nice, but the cost i'd imagine would be steep due to the size of the ally billet needed.
I think from memory when I looked at buying the bare cast uprights they were in the order of £180 a piece. Bearings as has been said are abundant for these as they can be manufactured to fit the transit wheel bearings. The last consideration is the rear fixed steering arm which on the genuine car is a forgerd item (to keep the size down). I have seen others and the tend to be larger than the originals, not a problem so much on a track car as they run 18" wheels usually but (as on mine) we have to package the hubs, steering arms and brakes behind 15" wheels, I had little alternative but go for the 909 equipment.
Mine uses M18 x 1.5 l/hand and r/hand rose joints on the lateral links and its the easiest set-up to adjust ever, even faster i'd say than a double wishbone arrangement. The lateral links need to be a fine thread as stength and fune adjustment are vital.
The turrets in the shell will probably be the bit most people will have most fear of doing, but in reality once built on the bench and carefully marked out its like fitting turrets in any car (mk2 esc, sunbeam etc) and is in fact a pretty straight forward job.
The casing are again readily available, as they are grp'a' fronts with the appropriate inserts and top mounts, the top mounts could be done relatively cheap, they are concentric spephical mount bolted to a fixed turret top. I had mine for proflex suspension in very little time.
I'd agree with gareth and I have for sometime harboured desires to develop a double wishbone system, I think perhaps the constraining parameters might be length of travel, double wishbones tend to have less travel than in particular a rally car suspension. Again this might not be an issue for track and fast road people, but it does put doubt in my mind as i would be possibly wasting my time...lol....even that said, this could still be cheaper than the wrc cradle route as some equpment is available (off the shelf) in kit car land....
The last thought I have on the subject for now is people need to consider the cradle mounting arrangement to the shell, the cage is modified with machined bosses extending and recessing into the shell, i have seen some copies which rely purely on the shear strength of the fixing bolts, this is a definate no no, the cradle needs to be spigotted onto the shell to prevent it creeping and to avoid the bolts carrying all the lateral load.
If you are serious about keeping the cossie moving forward then it's positive way to radically re-write the ford design....
HTH
Ian
#142
Engine Machinist
https://passionford.com/forum/viewto...616b0b8b095fb0
mike - i heard a rumour that someone i know supplied you with martins beam? someone with a black 500... just wondered if it was true...?
#143
Testing the future
what about a de dion setup? many of the advantages of a beam axle without the weight, and again they are available off the shelf from the kit car world
i made a double wishbone arrangement for my mk1 escort but when i sold it the new owner took it off to put leak srpings and a beam axle back on all it needed was a geometry setup and some new coilovers to get it working right
#145
K155MYRS
Originally Posted by ian sibbert
Pic of the GGR rear beam & arm combination....used on the touring cars...and I believe the one which is on Martins car...
Adreneline or similar would be able to copy this, but the cost of manufacture would outweigh demand IMO......there is a lot of man hours involved in making that set-up.....
That would be good to know how much Adrenaline would charge to make something like that.
#148
Former Sponsor
#149
Former Sponsor
your thinking of an alloy upright,and a ford one wont take a transit bearing,it will take a proper 5 bolt bearing,the copy ones take a transit bearing but they are bad quality and break so easily,the last pair of copy ones (i wont mention whos) were shocking,really crap,i would never risk them on my car.
#151
K155MYRS
#153
#154
Former Sponsor
#155
K155MYRS
I only asked because the main reply was the shafts are too short. Great answer by you though.. really helps a whole lot.
#156
If you look really closely into TF's last reply you will see he does have a point , maybe he didn't explain .....
All the permutations that 5 pages of this topic have tried to throw up are already available , designed, tested and developed by a well known motorsport company , namely Ford !
Trying to copy or emulate their parts by only using a bit here or a bit there will result in problems , not only in costs but results .
geometry is a very in depth topic ,but , the GpA & WRC cars had full extremes of droop and compression to cope with and both systems throw up compromises at their extremes , roadcars (and the occasional track day )doesnt need all this buggering about as with a decent set of dampers and base set up the car doesn't need lots of droop /compression , in fact a well sorted std steel rear axle is more than up to the job , trust me , ive been there !
If you want the expensive ford GpA parts so you can tick all the boxes , or a WRC cradle so you can tell youre mates , then fine , but it wont make your trip to the shops any quicker and wasn't designed to .
hope that helps .
hope that helps .
#157
K155MYRS
Thanks for the reply Tony I know Tim knows his shit and was hoping to get a nice in depth reply to help me and others that don't know anything about this stuff. I was just trying to figure out what else can be done. The problem here (in Yanky land) is we don't really have loads of rally cars readily available or breakers that cary this stuff.
#158
Rally nut
After 5 pages all I can see is 2 camps about the group A setup :
- those who say it is a great solution, better than standard modified beams, can do the job nicely on a track car used sometimes on hillclimb races
- thos who say there isn't a large difference with standard-modified rear beams due to the fact the group a one is "only" a 6° setup.
At the end I still don't know...
#159
those who compete - go for the pukka stuff, those who dont and drive road car/fast road mod the std stuff.
