need a light bulb
05-11-2007, 09:57 PM
Resident Wrestling Legend
need a light bulb
it's nearly 40 cm across measured from outside to outside
rather change the bulb than rip the false celing down to change the gubbins over so where can i get one?
with that fitting?
etc?
05-11-2007, 10:07 PM
Skint Passionford User
just take the bulb into B&Q mate, they'll have them
06-11-2007, 02:19 PM
going there on my way home then
06-11-2007, 02:40 PM
most electrical wholesalers will have one
06-11-2007, 02:48 PM
knowing my luck, they'll ask me to bring it in to have a look at what size it is, and then i'll break it getting it off and end up in casualty
06-11-2007, 03:41 PM
Standard T8 circular tube, 40w if its 400mm. Only thing you need to check is if it is coolwhite or warmwhite and that will be stamped on it near the cap
06-11-2007, 05:18 PM
thanks mate
i'm assuming it will have the same plug connections yes?
06-11-2007, 05:23 PM
yes just the colour difference! i like coolwhite
06-11-2007, 05:47 PM
oh and its a lamp not a bulb lol and im not a sparks
06-11-2007, 06:00 PM
If it does work out that you want to change the whole fitting you will NOT need to take down the ceiling.
06-11-2007, 06:03 PM
Sell these things every day
Write down what it has stamped on it. It will be something like L40/23.
That determines the size, wattage and colour
It will just be pins that plug in to make the connection
07-10-2015 12:56 PM
Steve Escos
01-10-2015 06:57 AM
stevecfrst1
30-09-2015 05:18 AM
deathrider666
28-09-2015 06:12 PM
28-09-2015 10:05 AM
