battery drain
Boost Builder
battery drain
Well cos is back out for a while soon and needs another battery already, if left to stand for a week the battery is completely dead (brand new)
What ways are there to find drains on bat and how is it done?? any tools needed and rough price if do..
Bet its the alarm
Bet its the alarm
1 Post
trackers can be a favourite, interior lights sticking on, boot light, central locking motor tryin got continue to motor shut when locked, any amps that are powerd up and not controlled by the remote will use some, what capacity (amp-hour) battery have yuo fitted?
1 Post
is it a new battery? old ones can just die and go fooked, have you checked the electrolyte levels in the battery? if they are low it wont hold charge?
i fitted a big 75 a/h one to mine as it stands for quite long times at once in the garage, the std spec one is a 60 a/h one IIRC, have you checked the charging voltage with the engine running. when off, the coltage across the battery should be around 12 volts, when the engine is running (and charging) it should raise this to around 14 volts .
easy to test m8 , have yourself a mulitlmeter that reads dc amps , the higher the better ,
remove keys from ign , dont arm alarms etc, disconnect the neg batt terminal and place the mulimeter between the batt lead and the batt terminal , the reading on the mm will be the current being drained from the battery , when all the timers are off , int lamps etc etc then you wanna be seeing no more than 0.10amp for general car useage m8 !!
Originally Posted by TIFF-C20WTH
I bet the light in the boot is staying on and draining the battery
I was thinking my battery wasnt holding its charge as long as id thought it would.Checked light in boot and it was on So just took it out,was roasting aswell
Anyway,cheers mate!
Boost Builder
bet it isnt tiff
Markk its your old cars so wat you done to the fucker
If its reading hi can i test individually each fuse connector to find the drain?
Danny@RADesigns,
i removed the old shonky alarm and had it replaced , the night that i bought it (funny the same with my 1st sapphire) locked it , alrmed it , 4am of it goes
while you got the mm on it , if you trun off all int lamps etc , best to remove the door pin switch when door is open to disable int lamp circuit , all if workin in the car , but the same with the bonnet pin switch , unplug it , then remove each fuse one by one until the drain disappears , the follow what ever is on that circuit !!
hth
mark
07-10-2015 12:56 PM
