WATER IN DRIVERS FOOTWELL/FORD PUMA
HI ALL
WHEN IT RAINS I GET WATER IN THE FOOTWELL OF MY PUMA AND I DONT KNOW WHERE ITS COMING FROM, EVEN THOUGHT THE CAR IS PARKED ON THE DRIVE DOES ANYONE ELSE HAVE OR HAD THE SAME PROBLEM AND ANY HELP WOULD BE APPRECIATED...
driver or passenger side? if passenger try up behind the glovebox and see if it coming through their as there is a plastic cover and it may of been disturbed
as said above sun roof blocked or if you open the passenger door there maybe a rubber grommit there (happened to my mate on his focus)
if you have instlled ICE then cances are it maybe where u have fitted he cable through
Water in the passenger foot well is probably either a) dislodged air-con pipe or b) water coming in through main wiring loom grommet behind fuse box. If its leaking through the grommet then get it fixed asap as it tracks down the loom and can enter the ECU...
Mark RS
12-10-2015 06:01 AM
