EGR ALS
#43
Originally Posted by DazC
Was just thinking about an external wastegate myself Gareth!!!
#44
Could be a minor issue to overcome.
#45
#48
Originally Posted by Electronic
Gareth,
Yes ALS is working on S8. (Called afterburner )
I suppose from the info on this thread it sounds easy in theory to use that.
you sure simon i know the menu there but i thought it is not active
#49
turboboss,
Sean,
Its active in an updated version.
Send me an email..... simon@s8ecu.co.uk and I will send you an updated
file when I am next at my work computer.
Sean,
#50
Dazc,
The old S8 has plenty of outputs as standard.
It can drive 8 injectors out the box and as Dan has only 4 injectors.....
Also has 4 user outputs which can be used.
The software doesnt support it but thats an easy mod.
Dan,
If you want this done no problem.
I have never set one up before so may need some input from Stu/Karl etc.,,
Dan,
but ill deffo want ALS of some sort
Ian, i have no idea what them tables mean, but im sure you do lol
its all 0's and 1's to me
#51
turboboss,
Sean,
Sean,
thanks simon i will email u tomorrow
#52
Hi guys,
Anybody know if the simon is alive? Finding his live monitoring software for cossie ecus but everything is closed, sites are down...etc.
Anybody have contact on Simon?
Thanks
Thanks
#62
I think you would be more likely to give birth to baby cheesus than getting help off Simon.
Good luck in trying tho.
And hello to gareth/ian.
I never got round to fitting ALS to the 3dr.. Or even driving it really. It got wrote off on the way home from passing the MOT by a pair of pikey cunts.
