Cam caps!!!
Cam caps!!!
....jesus helicoils aint that easy to install are they? ..Specially as i am simple .....needed 5 done.....The middle cam cap (YB) exhaust side the studs are slightly higher than the rest all in though and nuts torqued to 20ft/lb it wont matter will it?
Can you tell me the cam caps aint under massive stress are they?....I am sure all is ok but you cant do them too tight as the cam will where the cap?
Explain please.
Explain please.
Re: Cam caps!!!
Explain please.
Explain please.
The caps arent under much strain.
Best thing you could do with them installed (without the cams in) is to use a small dial gauge to check for ovality.
rule of thumb though:
providing they are visisbly making a circle still they will be fine, dont panic
Just so i understand...if you over tighten the cam caps what would happen?...Especially the first one that goes over the front cam seal?...(Previously everything was over tightened hence the need for helicoils)
sorry to hi jack but on the same topic, why are the two holes in each cap different sizes. from memory they are 8mm + 8.5mm and this allows some movement of the cap, its almost like they use the cam for cap location!
...just so paranoid that a stud will snap or a nut comes off...helicoiling is an arse..i had to tap the studs lightly to line up with the cam cap...I locktited them in and on all the nuts so hopefully no issues...If they aint under much load then i guess not much can go wrong..even if over tightened etc!
If they did start coming loose, i would expect you to hear a rattle like a lifter was shagged as the clearance would be too big suddenly, i guess if you were really unlucky the cam itself could snap too, but even that rarely result in any bottom end damage
Moderator
Oh get a room you two!!
Ps believe me i've been over & over this subject!! Proper drama queen & i'm as simple as you!
Thats strange...as the only reason i changed the followers is because of a top end rattle...and found studs turning!
Perfectly possible there is nothing wrong with the lifters.
Originally Posted by JTECHSAFF
did you guys drill the head, then tap it, then fit the helicoil?
If so did you use a pillar drill?
There isnt any other way to fit a helicoil is there?
Can see where you are going with the pillar drill comment in terms of how "snugly" the caps fit the studs
Passion for Fords!
see!
if you had put the head on a level pillar drill ,and then drilled the hole dead straight it should have worked out fine, obviously you would still have room for error with the tapping, but drilling with a shonky black and decker hand drill isnt very accurate!
see!
as i say they all fitted, just very snuggly!
Oh well its done now, so have to live & learn.................. Oh and hope for the best!!
..i just a trusty Bosch drill whats a pillar ..All it said on my helicoil kit was use an 8mm drill bit!
Hopefully not enough to matter at all
Had mine helicoiled and the rattle came back a few months later so the second time I had bigger bolts fitted intstead.
Passion for Fords!
I hardly had to tap them TBH...
...cant be recommended to drill the cam cap holes bigger surely?
..only had to do 3 holes in the end for cam caps..seal caps i guess are not as critical.
07-10-2015 12:56 PM
