Can't find blue sensor on cossie - ECT sensor location??
Cossiemodo
Been told it's at the back of the head on the passenger side, it isn't!
I think I must be going mad, please help, anyone got a pic or an accurate description of the blue sensor.
4x4 Saff Cossie.
4x4 Saff Cossie.
Originally Posted by righthooker
back of the block behind the dip stick i belive
And you can get a longrange socket over it as i took mine out last week
Cossiemodo
mate of mine changed his 4by one at nat day last year and it was at the back of the block on the passenger side i am 99% sure
Football Cwazy
if you look from above at the back of the engine, you will see a water pipe that goes to the oil cooler modine, beneath this is the ECT, very awkward to change but do-able.
this is the passenger side of the bay near the dipstick
0-60 in 17 seconds (eek)
That's the one in the picture, right pig to get to... I found it best to drain coolant, remove the hose from above and then re-fit and refill.
Sounds long winded, but it's much quicker in the long run, unless if you 12" fingers and rubber forearms
You will only lose a small amount of coolant if you remove that coolant pipe with a cold engine! Remove it and get a long reach socket on the sensor as has been suggested already
kosienutter
31
22-08-2015 09:55 AM
CabrioTurbo
01-08-2015 11:04 AM
