Ford XR Range This forum is for discussion of all things pertaining to the Ford XR Range of cars.
Help obsolete part required for my XR3i
Old 05-02-2015, 03:50 PM
no1fanofcolin
XR time warp
no1fanofcolin's Avatar
Default Help obsolete part required for my XR3i
Hi There.
My XR3i needs Idle control valve air flow for xr3i k series engine. None electronic.specific to year 1989, which is the best place to find one preferably new, plenty on E Bay, but Ford say the wrong ones
Help appreciated
Old 05-02-2015, 03:52 PM
Rob_DOHC
Rob_DOHC's Avatar
Is it the remote valve type or the one which sits on the side of the inlet manifold?
no1fanofcolin (05-02-2015)
Old 05-02-2015, 07:28 PM
no1fanofcolin
XR time warp
Not sure have asked Ford as they are sorting it, thank you for your response
Old 05-02-2015, 07:34 PM
Rob_DOHC
Rob_DOHC's Avatar
No worries... but honestly just open the bonnet and look, its either on the inlet manifold or remotely mounted on the bulk head Ford will want quite a bit of money I suspect. If the valve on ebay looks the same it will work. Ford only used a couple of variants and they all looked pretty different so you can't really go wrong.
Good luck
Rob,
Old 05-02-2015, 07:59 PM
no1fanofcolin
XR time warp
Bought this part on their request, but they say is wrong one
http://www.ebay.co.uk/itm/130749705417
Good luck
Rob,
Old 05-02-2015, 09:06 PM
nathansRS
c++
nathansRS's Avatar
this is the one
http://www.fordmanuals.org/page-1067.html
and there is a s/h one available
http://www.ebay.co.uk/itm/ESCORT-MK3...item1c4165ff83
TBH i'd be surprised if this was the cause of a non-start - it was just a late breather hack for when the heated screen etc loaded the alternator, reducing idle speed.
You can easily test the theory; when it fails to start, when you crank it over, apply appx 1+-cm of pressure on the accellerator and hold.
I think you would be better taking this to Tony @ turbosystems or Stu @ MSD, they would have this fixed with much less pain.
Good luck
Old 05-02-2015, 09:59 PM
no1fanofcolin
XR time warp
Thanks, pain you are right never had any probs with her over 26 years, never used her so much, but now over two years have gone from 30.000 to over 50.000 parts obviously wearing, hope prob sorted soon, just emailed suggestion to manager of Ford service who is doing his best to help part required is Idle control valve air flow for xr3i k series engine. None electronic this was part that came up on diagnosis
Originally Posted by nathansRS
this is the one
Good luck
Old 06-02-2015, 06:09 AM
jameswrx
jameswrx's Avatar
Nice to hear you've had it 26 years! And quite cool in a way that Ford still look after it.
Be good to see se pics, can't be many low mileage, (assuming?) one owner xr3i's about!
Old 06-02-2015, 10:12 AM
RSmark84
RSmark84's Avatar
What the hell is a k series engine?(sounds like you've stuck a rover engine into the car....?) I assume you mean the CVH engine? with K jetronic management........
Old 06-02-2015, 09:57 PM
Rob_DOHC
Rob_DOHC's Avatar
Yes I am getting a bit confused too lol The part you need will depend on whether you have mechanical or electronic injection. Think 89 will be MFI..?
Does you engine bay look like this:
Or like this:
Either way, best of luck and if Ford don't sort it I'm sure someone here can
Rob,
Old 06-02-2015, 09:59 PM
Rob_DOHC
Rob_DOHC's Avatar
this is the one
Good luck
I can't see where he has mentioned a non start
But if that is the case, and the car is MFI any air leak present when cranking can stop the metering unit flap being pulled down by the correct amount, pushing the throttle down wont help much. However pressing the large flap down by a few MM will.
Old 07-02-2015, 12:08 AM
botters
competant bodger
botters's Avatar
if its in evanshalshaw ford in preston dont believe anything they say they are fookin useless! lol
Old 07-02-2015, 10:27 AM
car help
car help's Avatar
Hi have you tried contacting burton power tel o208 518 9199 they may have the answer
Old 08-02-2015, 03:32 PM
no1fanofcolin
XR time warp
Thank you Nathan, seems to be the one as it is non electric, but need new one if possible
this is the one
Good luck
Old 08-02-2015, 03:34 PM
no1fanofcolin
XR time warp
Thanks, tried them, but no luck :-(
Old 08-02-2015, 03:37 PM
no1fanofcolin
XR time warp
The first one MFI
Or like this:
Rob,
Old 08-02-2015, 03:52 PM
no1fanofcolin
XR time warp
Yes one lady owner from new
Old 09-02-2015, 07:07 PM
nathansRS
c++
nathansRS's Avatar
Smile This thread is good for shits 'n' giggles
lol
lolz, I think Colin's no1 fan might not be a he
... but you never know ..
Here you go Rob
https://passionford.com/forum/genera...arm-start.html
pmsl, err...no. You're confused again - pull up for XR K and down for RS KE, remember... lolz
That is a really nice car, hope you get it all fixed soon
Old 11-02-2015, 10:53 AM
no1fanofcolin
XR time warp
http://www.amazon.com/gp/aw/d/B000CF3SIE
here is part unavailable
Old 11-02-2015, 04:06 PM
Rob_DOHC
Rob_DOHC's Avatar
No I don't remember, I have never owned or worked on an MFI XR3i. What I do remember is that any form of air leak will mean the flap does not move in what ever direction as intended at low load, ie idle/startup, air leaks on MFI cars are an incredibly common and often misdiagnosed problem.
Yes apologies, books covers etc. Appreciate you pointing my obvious mistake out though mate.
Rob,
Old 11-02-2015, 04:14 PM
Rob_DOHC
Rob_DOHC's Avatar
Hiya,
Yes that looks more like what I though you were talking about, it lives under the inlet manifold on the RS Turbo so I assume it is in a similar location on the XR3i. I doubt you will be able to buy a new one any where, however you should be able to find a good used one, annoyingly I had one attached to a manifold which I binned recently other wise you could have had it for free
For your info, and to help the search they were also fitted to Porsche 924's and some 944.
Here is a used one for sale, from a Corsa of all things!
http://www.ebay.co.uk/itm/VAUXHALL-C...25.m3641.l6393
Best of luck with the hunt.
Rob,
no1fanofcolin (11-02-2015)
Old 11-02-2015, 04:23 PM
no1fanofcolin
XR time warp
Thank you, just emailed Ford the link, finally persuaded them to fit second hand part as new one not available anywhere, oh that's a pity the manifold was binned with the part on
Hiya,
Rob,
Old 11-02-2015, 04:29 PM
Rob_DOHC
Rob_DOHC's Avatar
Good stuff, I hope they sort if for you
If they don't I would definitely go and see motorsport developments in blackpool, I suspect they know more about MFI in all of its forms than the majority of people at Ford.
http://www.motorsport-developments.co.uk/
Rob,
Old 12-02-2015, 06:35 PM
no1fanofcolin
XR time warp
Thanks Rob, part is ordered, hopefully will solve prob
Hiya,
Rob,
Old 12-02-2015, 07:18 PM
haz87
haz87's Avatar
Thats an auxiliary air valve.
If its jammed open (usual case) then you'd have a high idle.
It its jammed shut then the car will struggle to idle at very cold, but once warm the AAV shuts anyway (operated by a bimettalic strip).
So don't think this will be the cause of your non-running issues.
Old 12-02-2015, 07:25 PM
no1fanofcolin
XR time warp
This is the part that came up on Ford diagnosis, already have had starter motor and fuel pump relay, she starts. but struggles sometimes not 100% as Ford put it and once cut out on the road, just the once, first started when filling up at the petrol station after a 25 mile run, she struggled and had to wait a minute, that was when I had all the parts put in to rectify it
Old 14-02-2015, 04:07 PM
no1fanofcolin
XR time warp
Bought the part waiting for Ford to fit it someone on another site said it looked electrical, but Ford said it looked like the correct one so give it a try, oh do hope it is MFi been looking for it for weeks
Hiya,
Rob,
Old 14-02-2015, 04:11 PM
no1fanofcolin
XR time warp
Old 14-02-2015, 10:47 PM
Rob_DOHC
Rob_DOHC's Avatar
Best of luck! Let us know how it goes
Rob
no1fanofcolin (05-03-2015)
Old 05-03-2015, 12:35 PM
no1fanofcolin
XR time warp
Many Thanks Rob, the part you found worked and now my XR3i is finally back on the road
Hiya,
Rob,
Old 05-03-2015, 11:17 PM
Rob_DOHC
Rob_DOHC's Avatar
Fantastic news
Glad its all sorted and thanks for letting us know.
Rob,
no1fanofcolin (19-03-2015)
Old 19-03-2015, 05:55 PM
no1fanofcolin
XR time warp
Well she has been starting fine, first time filled with petrol no probs after a 5 min journey, but today filled with petrol after an hour journey and she hesitated, turned over twice, and had to pump the gas, I did not overfill what is it with filling petrol starting and hesitation, in her 26 years never had that prob lol got her back home turned engine off put on again and she started immediately
Old 19-03-2015, 06:14 PM
Rob_DOHC
Rob_DOHC's Avatar
Oh no I hope its a one off!
It is still very worth while getting the car setup every few years, the mechanical fuel injection can drift out of calibration with time. If your ever in Blackpool Motor sport developments would be able to do this very easily.
Rob,
no1fanofcolin (08-04-2015)
Old 19-03-2015, 06:28 PM
Thrush
Irritating c........
Thrush's Avatar
Deffo worth a trip over to Stu and James at Motor Sport Developments I think. Give the old girl a good going over (and yes, I am referring to the car!!! )
Old 20-03-2015, 08:11 PM
costina
Live long and prosper!!
costina's Avatar
I would have to agree. Prob needs injectors cleaning,new.fuel filter
And a set up.
Old 08-04-2015, 06:46 PM
no1fanofcolin
XR time warp
Well been on the road 3 weeks, running great and faster than ever, thanks again Rob the part you found solved the prob starting every time
Rob,
Old 08-04-2015, 10:16 PM
Rob_DOHC
Rob_DOHC's Avatar
Great news
Enjoy
Rob,
Old 10-06-2015, 05:34 PM
no1fanofcolin
XR time warp
Well she's been ok 2 months, on road every day, filled at petrol station today and took 10 mins to start, after 50 mile drive, she's not too keen starting up immediately after switching off was ok when engine cooled, had full service and MOT couple of weeks ago, passed first time
Great news
Enjoy
Rob,
Old 11-06-2015, 09:27 PM
Rob_DOHC
Rob_DOHC's Avatar
Happy days, thanks for letting us know its still working!
Old 20-06-2015, 06:31 PM
no1fanofcolin
XR time warp
She still has prob with warm start been ok since new part fitted, but now need fuel pressure regulator any links to where I can find one welcome, she is 1989 model MFI
IainRS1700T
25-09-2015 06:44 AM
oilman
Trader Parts for Sale.
23-09-2015 07:32 PM
Shaunc
Escort Range
23-09-2015 06:00 AM
jonnyenglish
21-09-2015 07:31 AM
phs84
15-09-2015 05:30 PM
Quick Reply: Help obsolete part required for my XR3i
