Ford XR Range This forum is for discussion of all things pertaining to the Ford XR Range of cars.
xr3i annoying rattle from engine bay
Old 12-01-2014, 07:45 PM
kandyman
kandyman's Avatar
Default xr3i annoying rattle from engine bay
ive recently acquired a mk3 xr3i cabby and have been doing a bit of tidying on it and usual oil filter and plugs change but i have now got an annoying intermitant rattle from the engine bay
on pressing the clutch down it stops
is this a clutch or gearbox problem and is it terminal?
im not very techy with cars so any help apriciated
Old 12-01-2014, 08:00 PM
Smudge374
Smudge374's Avatar
Mine does this too! However mine is running a racing clutch and has always done it, when was the last time it had a clutch? Where is the biting point? Any problems getting it into gear etc?
Old 12-01-2014, 08:08 PM
kandyman
kandyman's Avatar
unfortunately i have no idea when the clutch was last changed
the bite is right at the top of letting the pedal out
and no problems at all with selecting gears
Old 20-01-2014, 06:02 PM
Dave@dmc
Dave@dmc's Avatar
it's usually the diff bearings in the box, i wouldn't worry, they all do it
Old 20-01-2014, 08:31 PM
kandyman
kandyman's Avatar
the weird thing is i never heard it before. when i went to look at it or when i drove it or for the time is been parked up in the garage but regularly started up
i was thinking about having the clutch replaced as the pedal comes right up and having no idea when i was last replaced
hopefully will be on the road soon after some tlc
Old 24-03-2014, 07:59 PM
cozziegav
cozziegav's Avatar
Release bearing mate...
Nothing to worry about... Get the most use out of the clutch, when it dies, replace the lot...
Old 24-03-2014, 08:20 PM
whiskey
whiskey's Avatar
sounds like the release bearing to me, they can rattle for yonks and still be fine
bigryrs
28-03-2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
21-01-2016 09:54 PM
3drRich
13-09-2015 07:32 PM
RSmark84
20
24-08-2015 02:17 AM
track.focus'd
12-08-2015 05:53 PM
Quick Reply: xr3i annoying rattle from engine bay
