Ford XR Range This forum is for discussion of all things pertaining to the Ford XR Range of cars.
XR3i brake upgrade help
Old 16-02-2013, 08:16 PM
Smudge374
Smudge374's Avatar
Default XR3i brake upgrade help
Hi guys, I am looking at upgrading my XR3i brakes and would like to know if there are any simple swaps, eg Sierra brakes that are a direct swap.
Cheers in advance, Lee.
Old 16-02-2013, 08:27 PM
doga-ot
wesskitzo
doga-ot's Avatar
mk3 Mondeo bud
Old 18-02-2013, 09:26 PM
Smudge374
Smudge374's Avatar
Are they a straight swap? any model in particular? I am assuming that its just a bigger drum on the back or are you just talking fronts?
Old 18-02-2013, 09:46 PM
doga-ot
wesskitzo
doga-ot's Avatar
Any mk3 mondeo bud front only, rs turbo rear drums on back as there bigger or if you go rear disk conversion make sure you fit a brake bias valve
Old 18-02-2013, 10:29 PM
Turbo Zetec
Engine Machinist
Turbo Zetec's Avatar
mk3 mondeo with st170 discs (mk3 mondy is 5 stud), sierra xr4x4 with rs turbo discs, cossie 4x4 with 2wd discs (i think). probably a few other easy ones too.
Old 19-02-2013, 12:01 PM
2wdsaph ben
2wdsaph ben's Avatar
All mk3 mondeo calipers are the same. Nice and cheap on ebay, or username big g sells kits which include calipers, st170 discs and pads and bolts and correct size spacers.
Old 19-02-2013, 12:53 PM
mentalasanything
mentalasanything's Avatar
If you're running Ford 15" wheels you'll need to take some meat off the Mondeo calipers to get them to fit. Other options are available as stated but Mondeo calipers are much cheaper than the cossie stuff.
I have Front:
Sierra Cosworth 2wd Disks
Escort Cosworth 4x4 Calipers
Rear:
Escort RS2000 4x4 Disks
Sierra Xr4x4 Calipers
My rears are fitted without any bias valve, they are perfectly balanced and have never locked up on me (XR3i Cabriolet without ABS).
Lee
Old 19-02-2013, 09:57 PM
Smudge374
Smudge374's Avatar
Guys, thanks very much for the help, it is very much appreciated. I will have a look for my new brakes now im armed with the information needed.
Regards, Lee.
Old 20-02-2013, 04:27 PM
xrmalin
xrmalin's Avatar
If your after a guide on the Cosworth brake conversion Lee have a read of the sticky at the top of the page in the RS turbo room it shows how to do both front and rear conversions
stephenb4506
33
02-10-2015 06:25 PM
muzzman1
30-09-2015 08:59 PM
Sp3no
27-09-2015 07:23 PM
Quick Reply: XR3i brake upgrade help
