Few questions about the XR3
Hello all,
thanks for looking a family member just bought a XR3i
First off i was expecting this intake (pic from google)
But it has a different intake, it looks like an RS Turbo inlet manifold with a black pipe over the rocker cover but goes to the drivers side of the car no the passenger side, this black pipe is also a Y-shape if i remember correct any ideas?
is it actually and XR3i inlet?
Also how do i remove the steering wheel i have removed the ford badge from the middle of the wheel and the horn etc is under it, how do i remove it.
Thanks all
Thanks all
having a mid life crisis
Can not answer about the inlet sorry
But regarding the steering wheel do you have a four prong wheel brace,find the one that fits the nut hold and turn it will come off,you might find it easier for someone to hold the steering while you do this.Will only take a couple of seconds to remove the nut and then just lift the steering wheel up
It is a 1990 on a G reg.
When i looked at it i thought it was all correct as it was the EFI, the family member who i was with was trying to tell me it was wrong as should be as above.
So thanks for the confirmation there.
Regards the steering wheel its getting access to the nut that is proving difficult, the horn is in the way i managed to take the "Ford" center cap part out and the horn is of course situated underneath, i did not want to try and pull it out incase i broke it
thanks for replies lads
Dan
Out of many, we are one.
As said above. The black plastic piece you've reached just needs to be prised out with a flat head screw driver. Next, disconnect the horn wires (if you connect them the horn will sound - might be easier to wrap one with some insulting tape). Now you reach the nut - leave the steering locked you can open the nut easier but make sure when you come to remove the steering wheel (I'd leave as suggested a few threads of the nut still on there so when you pull the wheel it doesn't fly out and take your front teeth out) you open the steering as there is a bolt that "locks" it.
Has your inlet got EFI stamped into it?
just to add, iirc the wheel is spring loaded so as above under 90% then pull the wheel towards you letting the tension go then you can undo the rest to remove the wheel
