Ford XR Range This forum is for discussion of all things pertaining to the Ford XR Range of cars.
xr3i mfi wont acclerate or increase in revs
Old 26-05-2012, 02:55 PM
escort mad man
escort mad man's Avatar
Default xr3i mfi wont acclerate or increase in revs
hi , just got my van up & running with a xr3i mfi engine in , after finally getting the fuel pipes the right way round , i get it started & it wont acclerate or increase in revs ,
the revs will increase if i turn distributor but if i touch the throttle linkage it stalls as though it over fuels or to much air
also does anybody have pics or a diagram off where the vacuum pipes should go
Old 31-05-2012, 08:51 PM
JasonXR2Racer
JasonXR2Racer's Avatar
I reckon split vaccum pipe or inlet hose
check all your connections/jubilee clips are tight
also check everywhere for any plugs not on
make sure no fuel leaks on injection pipes and did you re-fit all your copper washers on both sides of your fuel unions
Old 31-07-2012, 09:33 PM
stevo123
stevo123's Avatar
Check the airflap is not stuck on the fuel metering unit too and you have good fuel pressure, pumps that are very buzzy can be very worn and produce poor pressure when flow is required
07-10-2015 12:56 PM
stephenb4506
33
02-10-2015 06:25 PM
morg65
Escort MK 5 / MK 6
23-09-2015 08:57 PM
Shaunc
Escort Range
23-09-2015 06:00 AM
stevierob
07-09-2015 07:09 PM
Quick Reply: xr3i mfi wont acclerate or increase in revs
