Ford XR Range This forum is for discussion of all things pertaining to the Ford XR Range of cars.
zetec wont run
Old 19-12-2011, 08:43 AM
keaton23
keaton23's Avatar
Default zetec wont run
hi there ive just fitted a 2.0 zetec in my mk 4 xr3i after a lot of hassle it finally starts. but after its reved a few times cuts out. this has only been happenin since i fitted the alternator. also if i connect the wire for the battery light it wont start at all.
Any ideas????
Old 19-12-2011, 11:21 AM
Fordmad!
Fordmad!'s Avatar
Check the battey to see what your getting off that when its charging.
Old 19-12-2011, 12:29 PM
keaton23
keaton23's Avatar
Its charging fine has had new alternator and battery not long ago
pretty sure its going to have something to do with wiring, but all wires are on and in the right place
Old 19-12-2011, 06:32 PM
steve4i
steve4i's Avatar
you earth'd it too the gearbox properly?
Old 19-12-2011, 08:01 PM
keaton23
keaton23's Avatar
fink so have earth from battery to body then earth from gearbox and engine to body. then alternator and starter should earth through them right?
Old 25-12-2011, 06:29 PM
fordsod
fordsod's Avatar
Wink zetec 2,0 to esco mk4
Hi! Sorry a late reply. What ECU do you use this wire series?
Do you own the original fuel relay with cables?
I have my own similar project start-up yet but perhaps I start later this spring.
Old 28-12-2011, 07:39 AM
keaton23
keaton23's Avatar
using the zetec ecu and wiring loom just had to cut and join a few wires.
and yes using the original fuel pump relay.
good luck with yours mate
Old 29-12-2011, 12:45 PM
wedge07
wedge07's Avatar
you should have an earth from gearbox directly to battery mate, maybe the problem?
Old 11-01-2012, 08:46 PM
johnnysash
johnnysash's Avatar
Yeah as wedge07 said. Quick fix to check will be to use a jump lead from your engine lifting eye to the battery negative terminal.
JK12
33
26-04-2021 12:09 PM
03-11-2015 04:08 PM
xrmalin
13-09-2015 06:52 PM
Churtz
15
13-08-2015 06:40 PM
turbobill
09-08-2015 05:21 PM
Quick Reply: zetec wont run
