dump valves
Old 23-12-2005, 09:35 PM
whitecossie
whitecossie's Avatar
Default dump valves
how many people run them ?
i havent had 1 on my cossie i use to like the chatter but it gets a bit to much sometimes ,ive tried my mates on today and it sounded class but ill proly get sick of that and go back with the chatter,
Old 23-12-2005, 10:23 PM
NUTTIN RILLA
NUTTIN RILLA's Avatar
Well mate i`ve always had a dump valve on my cossie, but i tried it without for the chatter which is good but now im stg3 the both sound great together, the debate could go on forever, but its so easy to change back to whatever you feel like, good luck
Old 24-12-2005, 11:48 AM
bazpro
bazpro's Avatar
i prefer the chatter myself but some people on here say it knacks your turbo.
Old 24-12-2005, 12:41 PM
filthyrichie
filthyrichie's Avatar
dump valve gets the heads turning i always find
Old 24-12-2005, 04:18 PM
G2 FSR
G2 FSR's Avatar
i had 1 fitted up until a couple of months ago. They say there not much cop for the turbo and that. But i have a graham goode kone air filter and that sounds wicked, much better than any dump valve
Old 24-12-2005, 04:49 PM
grunter
grunter's Avatar
ive gotta spec r one one mine sounds great and still get loads of chatter to
Old 24-12-2005, 04:50 PM
whitecossie
well ive managed today to make a old amal valve close the vacum off to the dump valve and open it at a flick of a switch so i dont even have to open the bonet to take the pipe off , i knew these missle swtich thingys would come in handy .the other 1 is for my fan it has been a right twat only working when it wants so i have put a overide on incase,
Old 25-12-2005, 08:35 AM
cossie604
cossie604's Avatar
Chatter????
Old 25-12-2005, 08:56 PM
whitecossie
ya the chatter off ya turbo when ya ant got a dv on ,
Old 25-12-2005, 09:27 PM
XR4Timan
XR4Timan's Avatar
You gotta be silly to run a Cossie w/o a dump valve, that's why Ford fit them standard - and Fords are cheap ass bastards!
If you have no dump valve, it will send air to your turbo to stall the blades. Also the trapped boost will try to escape through the easiest exit out, so it can blow your clamps off. Finally, it will slow down the turbo, since it's trying to stall the blades, whereas a dump valve will keep the compressor wheel running at speed, so there will be less delay in speeding back up.
Plus the sound of an atmospheric dump sounds great!! Tells everyone 'F@CK @FF I got a turbo, you slow-ass b!tch!"
Old 25-12-2005, 10:11 PM
whitecossie
lol like that bit
Old 25-12-2005, 11:38 PM
cossie604
cossie604's Avatar
Nah mate, that aint waste gate 'chatter'...its compressor surge and its generaly considered to be of ill health to your turbo...although many ppl do run their cars like that with out many probs.
Old 26-12-2005, 10:21 AM
XR4Timan
XR4Timan's Avatar
Problems aren't evident until they remove the intake hose to the turbo and discover excess play in the turbine shaft. Then rather blame the lack of a DV, they'll blame it on the turbo
Old 26-12-2005, 10:39 AM
JamesH
JamesH's Avatar
Not really
Ford fitted them as standard, because do you think business men would want their car making chatter noises all the way down the motor way?
Remember they were a rich businessman's car to start with (Sapphs)
However, you are right in principle, but it only applies to turbos T4 and bigger
Old 26-12-2005, 10:41 AM
JamesH
JamesH's Avatar
The two are very simiolar, but surge is far more severe
And I do believe he was originally talking about chatter, as it's only when you remove the dump valve he said
Old 26-12-2005, 11:44 AM
rabmc
rabmc's Avatar
I run no d/v ang get sommme flutter / chatter or whatever the correct term is for it , and dont think iL be changing , it would have to be one or the other though a bit concerned if its causing damage to my turbo
Old 26-12-2005, 03:36 PM
gym-rst
gym-rst's Avatar
Default Re: dump valves
Thats funny i just done the same thing myself on saturday just fancied hearing it dump again although i do love the sound of the chatter the air filter gives
Old 26-12-2005, 09:27 PM
whitecossie
sorry i did mean flutter well anyway that noise that comes out of ya airfilter,
Old 27-12-2005, 01:47 PM
m_nettleship
m_nettleship's Avatar
I am getting confused reading this, I have a brand spanking new turbo on mine, with no dv when u let off or change gear, I call it wastgate chatter, or a FLUTTER or somthing, sounded alot louder when I but a come filter on to when I had the air box on.
Old 27-12-2005, 02:22 PM
XR4Timan
XR4Timan's Avatar
Put a dump valve on it, to keep your turbo in top-shape then.
Old 27-12-2005, 09:39 PM
whitecossie
ive read a few post's on here about flutter etc and it think the phase u must use a dv applies to big boost cars and when ya running big bhp , please correct me if im wrong ,
Old 27-12-2005, 09:55 PM
JamesH
JamesH's Avatar
Very true mate. Only T4 turbo's or bigger.
Do you really think that Karl Norris would have mapped Tiff's old car with 32psi spike and 28psi held (on a T34), with no dump valve if it REALLY mattered? (Just an example)
Old 27-12-2005, 10:14 PM
XR4Timan
XR4Timan's Avatar
It does matter....obviously it matters more as the flow of air is increased (eg T4). You will see issues with the T4s more sooner then you would T3s (eg bigger blades resting on the same sized shaft). But it still causes an issue with T3s. Otherwise Ford would have not put one on a T3 producing 9 psi.
Obviously you don't have to listen to me at all, and do the f@@k you want mate, but I would rather side with caution methinks.
Old 27-12-2005, 10:51 PM
K500BHP
K500BHP's Avatar
if a t 34 is running 9 psi as standard and you up it to 30 psi then that must be classed as under stress so more prone to failure so the fitting of a dv to reduce stalling of the blades must help ???????????
Old 27-12-2005, 11:01 PM
rabmc
rabmc's Avatar
The bottom line is i think for 80% of people is...
Dump valves sound gay but love the flutter OR
Dump valves sound great
IMO
Old 29-12-2005, 02:56 PM
moonstone mike
moonstone mike's Avatar
cant hear my dump valve over my flutter, chatter what ever you want to call it
Old 29-12-2005, 08:33 PM
*Bri.4.b.Cos*
*Bri.4.b.Cos*'s Avatar
Well chatter gets my vote anytime, if it brakes ill fix it simple as!
Bri
Old 29-12-2005, 08:40 PM
JamesH
JamesH's Avatar
No need to be like that mate
Yes it matters, but nothing worth worrying about IMO on a T3, just my opinion!!!!
Ford put the re-circ dv on there as the customers at that time probs wouldn't appreciate chatter
Old 30-12-2005, 12:30 AM
XR4Timan
XR4Timan's Avatar
The last line I wrote was to be taken in humor, mate! Won't argue over a poxy issue like DVs!!
Old 30-12-2005, 04:50 PM
JamesH
JamesH's Avatar
OK be like that MATE
Old 30-12-2005, 09:33 PM
whitecossie
im sorry didnt mean to cause any bother like was just asking who ran 1 and who didnt ive got 1 on mine now if that makes any difference ,
Old 02-01-2006, 10:34 AM
rscozzysie
rscozzysie's Avatar
i,ve got one on mine.i'm running a t4.
Old 03-01-2006, 04:07 PM
JTECH James
Passion for Fords!
JTECH James's Avatar
a mate of mine had a stage 3 car t34, no dv. turbo stalled and the turbine shattered, sending all the pieces into the intercooler and a few found there way into the engine and killed it dead!
Air going the wrong way through a turbine can only be bad and cause damage, they just are not designed for that sort of abuse, if you run no dv the risk s all yours cos i dont want it!!! it may sound nice but so does running no air filter but it obviously isnt good for the turbo or engine.
I always run a dv!!
Old 03-01-2006, 07:11 PM
darr686
darr686's Avatar
Hi what type / brand D/V would you guys recomend ?
Old 05-01-2006, 08:17 AM
JTECH James
Passion for Fords!
Bailey all the way
Old 05-01-2006, 10:47 AM
Stealth Bomber
Stealth Bomber's Avatar
At the end of the day DVs do sound fucking GAY
Old 05-01-2006, 11:10 AM
moonstone mike
Not as gay as buying a new turbo !!!
They only sound gay on crap slow cars....when you see a cosworth on full song with a dump valve the sound dont matter!
Old 05-01-2006, 11:22 AM
JTECH James
Passion for Fords!
just fit a re-circulating unit.
Old 05-01-2006, 01:04 PM
Stealth Bomber
Whatever you say!
[img:400:261:aebd073c60]http://www.portalbaw.com.br/velho/vilage.jpg[/img:aebd073c60]
Old 05-01-2006, 01:14 PM
moonstone mike
Love the tash on the right
Quick Reply: dump valves
