IW-025 Weber Injectors
After having the 4 injectors in my 3DR flow tested and cleaned the leak I thought was coming from a bung o-ring on the fuel rail is actually coming from the top of the injector where the yellow plastic meets the steel body. From what I've read this doesn't seem to be fixable?
I don't suppose anyone here has one of the IW-025 injectors they want to part with? Would consider a set if need be as well.
Alternatively, if I had to replace all the injectors, what are my options? The car is standard.
