500 Intercooler to hart inlet manifold....
Went to Santapod today and a few runs in my boost hose split.
It was never a great fit so after something better if possible.
I have an RS 500 style airtec 70mm cooler going to a regular 2wd throttle body on and hart/autospecialists inlet.
The intercooler has previously been modded but never seeing it standard I'm not sure how well,
It's not a straight line to the throttle body and also offset fractionally too.
So what hoses are people using with this setup?
Cheers Paul
Cheers Paul
cossie fan (unluckerly)
I had the same issue with my 500 style cooler it fitted shit. Had it modded still was not right. I got lucky and picked up a second hand spec r top feed cooler that gives a perfect straight run between the two
turbotrev (30-10-2016)
Does your spec r meet the tb pretty good then?
Cheers Paul
That's a really short hose!
Cheers Paul
Cheers Paul
turbotrev (31-10-2016)
turbotrev (02-11-2016)
I have just ordered one of those swedish plenum ones to try.
I have currently got a piece on there but not 100% happy with it.
Mine is as short as Ajamesc
Toby
Toby
