Cosworth Anti Camber shims
Old 24-10-2016, 12:20 PM
timsrs
timsrs's Avatar
Default Cosworth Anti Camber shims
I am after some Anti camber shims for the rear axle on a saph cosworth.
Has anyone some for sale or where's the best place to buy them.
Old 24-10-2016, 01:39 PM
Adam-M
Adam-M's Avatar
I'm sure I seen some on R&B Motorsports website
Old 24-10-2016, 04:03 PM
timsrs
timsrs's Avatar
R@B are the toe in shims. Not camber.
Old 24-10-2016, 04:14 PM
Adam-M
Adam-M's Avatar
http://pages.ebay.com/link/?nav=item...d=172006176351
Old 26-10-2016, 08:31 AM
R4N SS
R4N SS's Avatar
mine were better than the ebay link and off someone on here years ago - work very well on my saph. Am yet to try a set on the 3dr
Old 26-10-2016, 10:24 AM
Ade
Fast Ford snapper
Ade's Avatar
Git them on mine, well made, and do help a good bit.
Did have a more extreme set years ago, but they made a very low car sit at almost zero camber, probably be overkill and go positive on a higher car!
Old 19-11-2016, 04:07 PM
nixon_2wd
nixon_2wd's Avatar
There are several designs out there that doesn't fit without the stub shaft rubbing (on 2wd anyways), so I designed and got a pair made. I designed these based on the drawings on here, but I found that the actual drawing of the part doesn't match the measurements on it lol.
The measurements are, however, accurate, and the design works. Will post a pic of my drawing later.
For those of you worried that the shims introduce bending moment on your bolts, simply fit some of these spherical washers. Bolts don't like bending, so they're a good fix.
https://www.ganter-griff.com/en/prod...-washers-Steel
The following 2 users liked this post by nixon_2wd:
Robmatheson (21-11-2016), rooos (04-12-2016)
Old 02-12-2016, 08:29 AM
nixon_2wd
nixon_2wd's Avatar
Here's the drawing I made:
rooos (04-12-2016)
Old 02-12-2016, 09:25 PM
boostn_capri
boostn_capri's Avatar
Hi thanks for posting 'Nixon_2wd' looks good, what does the 1.6 in bottom corner of the drawing mean? Also what sort of steel/alloy did you use? Cheers k
Old 04-12-2016, 04:18 PM
nixon_2wd
nixon_2wd's Avatar
Surface roughness. You can use whatever material you like. Mine are 6061 T6.
rooos (04-12-2016)
