Original 2wd Bonnet
Original 2wd Bonnet
Can anyone tell me if there are any part numbers or ford stamps on an original cosworth 2wd Bonnet please. Any difference between cossie 2wd and normal saph bonnets at all? Cheers.
Yes,there are differences so beware.
You need a pre 1990 facelift bonnet as the edge of a pre 1990 bonnet is kicked up from n/s to o/s.
A later bonnet is kicked up for around 10 cm then goes flat,look at your 4wd bonnet,a post 1990 non vented bonnet is exactly the same and wrong for an earlier car.
Apart from that they are the same,prob finding 1 with an 1998/89 date stamp beside the latch will easily identify the right bonnet.
Very hard to find when you are looking for 1,when you stop there are loads ha ha.
Lee do you have any pictures of the difference as I've never noticed it before? Cheers
RSMK4TURBO (19-10-2016)
Right thanks for the info Lee, now see what you mean with regards to the differences in the bonnets,i will ask if it is date stamped and if i can have more pictures before i buy.
Cheers lee never noticed that before
