My first cossie
#41
Agreed with comment above Sam, I hated the paddle clutch in mine...was one of first things I got taken out.
Meant to be ok if you go hydraulic clutch at same time but ruined the car for me!
#44
What can I use to handle the power this is current spec not idea what power but was thinking of going msd for the next chip up l8 is it? Need some advice really as don't know anything about cosies lol
Bosch light blue injectors*
T34b hybrid turbo*
Bd10 cams*
Pace rs500 intercooler*
Big Alloy radiator with fan**
L6 ecu with Collins board and chip*
3 bar Map sensor*
T34b hybrid turbo*
Bd10 cams*
3 bar Map sensor*
#45
T34b hybrid turbo*
Bd10 cams*
3 bar Map sensor*
T34b hybrid turbo*
Bd10 cams*
3 bar Map sensor*
#46
msged stu at MSD will take it up new year when ive fitted a new clutch and im back from China. He did say the compression at 125 was an issue so will have to get that looked in to by someone ;(.
#48
Update
waiting on hoses to fix boost leak from Roose made to fit the t34. Mike Rainbird been very helpful.
Will be looking to purchase alcon paddle clutch and helix cover when im back from holiday after much deliberation .
#49
Nice looking motor by the way pal
Cheers Paul
Cheers Paul
sambuca (18-11-2016)
#51
Not going for hydraulic clutch then? If you are going to be using the car a lot it is well worth considering.I have been very happy with my conversion, it is so much lighter and has much more "feel" to it than the cable operation.
#52
So called "cheap" performance tyres have got so much better now there really is no need to spend shit loads on big name brands. I have Federal 595RSR 215/40/17s on my Saff and find them very good and a reasonable price. As you have said with your Nankangs they are also very good.A lot of " tyre snobs" will wrongly dismiss ours as rubbish without really knowing anything about them apart from the low price!
#53
Seems the alcon + helix cover is ok though?
#54
Its just personal preference regarding hydraulic clutch conversion, For me with a 6 paddle clutch it was awful with the original cable operation, very heavy and virtually no control . It was either engaged or dis engaged all within an inch or less of travel.When I was stuck in long traffic hold ups it was a nightmare. I now find even getting reverse is easy with no crunch which on a T5 is unusual. I am a convert and just wish I had done it years ago!
#55
Alcon or Helix clutch and cover will be good.
Do you have a centre push bearing type or an external type slave cylinder?
Cheers Paul
#56
The only visible thing you see in the engine bay which looks neat and tidy.
#57
Hi Paul I got mine from Reyland Motorsports. I did need to get a second hand bellhousing which I sent to them and they welded a new bracket on for the external slave cylinder. At the same time I got a lightened flywheel and a Helix 6 paddle clutch kit from them.
sambuca (24-11-2016)
#60
not much to report on it really. got some work to do on it before spring going to do a few trips with the mrs.
Had a quote from PJ motorsport for all the work i need doing as they are local and heard good things. I would go MSD but it is really far.
Things to be done are full service.
New clutch and reground flywheel
remapped.
Still need to find a 2wd mongoose with 4inch rolled tailpipe to finish it off.
remapped.
#61
Finally ordered my parts. Mongoose exhaust. AP organic clutch.
PJ Motorsport going to give it a full service change clutch do my flywheel. Then tune it. So hopefully be ready to roll in a couple of weeks needs a good clean too.
funkyboozer
13-08-2016 03:53 PM
