Headlight issue
Headlight issue
Hi all, last night the headlights on my sapphire cosworth went off while driving but a couple of minutes later came back on. Main beam and side lights remained working fine,any idea?
Hi,
Most likely a relay. Difficult to tell when it's working through.
Different years had very different dip beam electrical systems depending on legislation at the time, eg dimdip...
Cheers,
Gavin
Cheers,
Gavin
RSMK4TURBO (12-10-2016)
Check In the fuse box. Had this happen to me and had corrosion and melting under the fuses. The damage cAme from the old cooling fan ones melting and causing havoc and damage.
Ok I will be checking all earth's, checked fuses Sunday night and they looked ok but will recheck. Which relay is for the headlights? Also seen on eBay rewire kits for headlights that feed directly from battery with they're own relays that use existing wiring for switching on lights.Anyone else done this.?
Looks to have been slight corrosion on the pins on the relay, so ive wiped all connectors clear of corrosion and lights are working perfect now.
delbee1
78
01-03-2017 11:05 PM
PAUL S
22-09-2016 09:11 PM
baz
17-09-2016 05:57 AM
