yb cossie timing
Old 01-08-2016, 10:06 PM
MARKYMARKONE
MARKYMARKONE's Avatar
Default yb cossie timing
Hi
I just want to check if ive timed my engine up correctly.
It turns over ok .
Mark
Attached Thumbnails yb cossie timing-20160801_193559.jpg   yb cossie timing-20160801_193546.jpg   yb cossie timing-20160801_193624.jpg
Old 02-08-2016, 08:22 AM
Thanasis
Thanasis's Avatar
Take one clear pic from crank pulley,the marks
Old 02-08-2016, 12:16 PM
wes
wes's Avatar
Your cam belt looks awfully close to the thermostat housing, that generally happens when you go the wrong way with the cambelt tensioner, the tensioner should only ever be turned clockwise (from loose) to tension the belt. Also the auxiliary pulley, the pointer needs to point to the centre of the half moon on the auxilary shaft cover (it looks like it is to the left edge of the half moon from your pictures).
Can't clearly see the crank pulley but it looks in the right sort of area, the pointer needs to be bang on the left edge of the lug.
Old 02-08-2016, 12:20 PM
wes
wes's Avatar
Old 02-08-2016, 12:21 PM
wes
wes's Avatar
Old 02-08-2016, 12:36 PM
Thanasis
Thanasis's Avatar
picture share
Old 02-08-2016, 01:49 PM
MARKYMARKONE
Cheers guys
Crank pulley pic updated on 1sr post
Mark
Old 02-08-2016, 04:00 PM
Bart
Bart's Avatar
Crank pulley looks correct on the pic.
Old 04-08-2016, 07:13 AM
Marc sierra
Marc sierra's Avatar
But it indeed looks like the tensioner pully is rotated the wrong way to tension the belt.
jessie_rs
03-08-2016 12:30 PM
Mk4 Rick
24-07-2016 11:31 AM
Dod IRL
18-07-2016 09:54 AM
Gmanvilla
16-07-2016 12:00 PM
AiToR51
08-07-2016 10:01 AM
Quick Reply: yb cossie timing
