7bar of fuel pressure
Old 25-07-2016, 11:13 AM
Michael Dunne
Michael Dunne's Avatar
Default 7bar of fuel pressure
Hi, my car is in a garage getting work done to it, the mechanic has said the engine will only run OK if he sets the fuel pressure to 7bar .
Does anyone know why it is needing double the pressure ?
Old 25-07-2016, 12:13 PM
Heitmann
Heitmann's Avatar
if he means it as his way of fixing it - I would change garage right away and never come back.... ever
Old 25-07-2016, 02:12 PM
Michael Dunne
He knows it's not fixed properly but it's the only way the car will run and drive somewhere near how it should.
At normal pressure it hardly drives, why would that be ?
Old 25-07-2016, 02:46 PM
Caddyshack
Caddyshack's Avatar
I think I would want to get the injectors checked and then all the basics of fuel reg, timing etc. Does sound odd.
Old 25-07-2016, 03:38 PM
matthart
matthart's Avatar
What car? If it's usually 3 BAR and he claims to have set it to 7 BAR, then the fuel pipe unions would probably explode. That or the fuel pump. And what sort of regulator would let you set 7 BAR anyway?
Sounds like he's talking out of his arse.
Old 25-07-2016, 10:34 PM
martysmartie
martysmartie's Avatar
It's not a good idea to set it that high in any case, it must be running rich?
You need to get it to a specialist ASAP before serious damage occurs!
Martin
Shaunc
Escort Range
08-05-2016 08:15 PM
cutch
12
03-04-2016 11:41 PM
Acac
28-03-2016 06:06 PM
bagginsRSturbo
11-03-2016 08:44 PM
3dr cossie
07-03-2016 05:23 AM
Quick Reply: 7bar of fuel pressure
